Topic: KUNG-FOO by Br3tt (Read 186837 times) previous topic - next topic
KUNG-FOO by Br3tt
Under the pause button the time is not there on my end, with the latest config. Your screen shot shows this, and i can't seem to fix this?
KUNG-FOO by Br3tt
is it he only thing that does not appear ?
do you launch foobar from a music file (under windows explorer for example) or do you launch foobar directly ?
KUNG-FOO by Br3tt
i launch foobar directly, desktop double click. as far as i can tell that time under the pause button is the only thing i can't see, i'm still testing the config out.
KUNG-FOO by Br3tt
well i can confirm this happens on the first release, and the current second release on my end. Anyone else experiencing this? " No time display under pause button," under the volume button time display is fine.
PROBLEM still present in v1.0c A screen shot of what i'm talking about is here, the green box is where a time display should be as yours is.
KUNG-FOO by Br3tt
Reply #32
v1.0c released, fix a bug (rating system hidden due to bad path for images (stars))
KUNG-FOO by Br3tt
Reply #34
RavenSoft thank you for replying, i see yours looks fine. i wonder if i need a special font for it too show, i used the original file with no mods to it, and it don't show. hmmm. will look into this  a little further. thank you for at least letting me know that it should work fine. take care
EDIT: in fact lcd font needed to be installed, seen that in the code, and changed that to my desired font and ALL IS GOOD NOW~ something as silly as me overlooking the lcd font name was a first, usually i find these things easy and fix them quick, thanks again though raven, got me thinking some how
KUNG-FOO by Br3tt
Reply #35
I figured I would also report that when I loaded 1.0c and tried to play music foobar2000 immediately crashed. When I restarted it, it seems to be working fine. Also if anyone has the optional font HelvCondensedCaps could you pm me? Either that or a very similar font as there is a reason falstaff is using it in his config. thanks.
KUNG-FOO by Br3tt
Reply #36
Great config!! Love it.
Problem for me though. Whenever i click on the arrow that reveals coveflow it disappears unless i scroll it with the mouse wheel. Then it disappears again. This only happens in windowed mode, even if it is stretched to the max. In fullscreen it works fine.
KUNG-FOO by Br3tt
Reply #37
nice dude. kinda bug i get is the tab to change the features like coveflow etc is missing,not permanently,but i need to click on it's place only to make it visible. after that it will vanish again
just a question :
directly. what i do to fix is reimporting the .fcl and it fix it. =)
KUNG-FOO by Br3tt
Reply #38
hum, surely a chronflow / 3Dvideo card problem.
KUNG-FOO by Br3tt
Reply #39
nice config, thx Br3tt
but what's wrong with rating? :/
Firstly, thank you so very much for this config!!!
It`s very strange, but I have the same problem and I`ve tried to reinstall windinds 2 font (I use Win.Vista)
Also, every time, then I restart foobar, it`s returns to the first position (elplaylist and track info).... so, but I like more third position (there can see three panels), how can I fix that?
Many thanks Falstaff !!!!
KUNG-FOO by Br3tt
Reply #40
Br3tt,
I've always enjoyed you configs, and find they make Foobar even more usable. One request, can you add a button that searches for covers using AlbumArtDownloaderXUI. It's a great tool and I think will even enhance your creation.
NH
KUNG-FOO by Br3tt
Reply #41
bah, damn you 8800gt card!!
Thanks once again. It's the first config that doesn't lag at all while scrolling through the playlist very fast.
KUNG-FOO by Br3tt
Reply #42
Br3tt,
NH
second that and im quite sure Br€tt had this feature in earlier releases.
KUNG-FOO by Br3tt
Reply #44
hi all,
take care with ELPlaylist versions, recents versions 0.6.x.x are slow on refreshing tracks (especially for covers like used in Kung-Foo in Album display)
1st post updated :
- ELPlaylist 0.6.1.0b or higher - but i recommand antieriors version like 0.5.x.xb (0.5.2.1b for example)
cause of lag when refreshing list on track change
(quite smooth line refresh )
KUNG-FOO by Br3tt
Reply #45
the playlist manager is not very handy...
KUNG-FOO by Br3tt
Reply #46
Very interesting setup! I like your technical approach very much, though i think the color config isn't too cool (gray on gray and white on white isn't too readable..) Anyhow some pretty cool stuff like the menu on the top and I love the switching of the graphical browser. Great!
KUNG-FOO by Br3tt
Reply #47
PREVIEW OF V1.1
added a pager alpha-index to jump easyly and fast in coverflow or playlist, ... works great (binded with playlist and coverflow)
KUNG-FOO by Br3tt
Reply #48
Can you please add the edit menu option please.
NH
KUNG-FOO by Br3tt
Reply #49
nice!
i like this one more.
can you do a plugin pack along with each release I think it will help out al ot of people
