Topic: foo_lastfm_radio (Read 348791 times) previous topic - next topic
foo_lastfm_radio
Reply #375
Hard to tell if it is being maintained, actually.
foo_lastfm_radio
Reply #376
you what? it's had 4 updates since the foobar v1 SDK was released.
foo_lastfm_radio
Reply #377
I'll keep up the bug fixes (v0.5.7e fixed the album art issue) but I'm not currently working on further features.
I suspect the proxy setting would only be used to use the component in regions Last.fm don't offer the service. As the component is using a depreciated API I would expect that adding features like that would only hasten the API being discontinued completely, in which case no-one benefits.
foo_lastfm_radio
Reply #378
Hey guys, I've searched this thread and the internet up and down but i cant seem to spot an answer. Is there a way to stop the Playback Error window popping up when you hit songs on a lastfm playlist that are no longer valid, and to skip to the next/end of playlist/retrieve new playlist without bugging me?
foo_lastfm_radio
Reply #379
file -> pref -> advanced -> playback -> uncheck  show error message popups
Little question for the dev. Is that possible to have a quick access to the  "block" and "add to favorit"  music ?  or the api don't allow it ?
foo_lastfm_radio
Reply #380
Songs play for only like 5 secs, and then its skeeps to the other song and i get this error:
"Decoding failure at 0:00.000 (Unsupported format or corrupted file):
"FOO_LASTFM_RADIO://play.last.fm/user/b553f9ce307c6458cc4021de546ce1de.mp3LASTFM""
foo_lastfm_radio
Reply #381
sry, didn't see the the answer was already in the main post
Just reporting an incompatibility, the wave form seekbar plugin ( with http://www.foobar2000.org/components/view/foo_wave_seekbar).
I think it's a problem in the seekbar implementation, but I post it anyway. If the seekbar is enabled, it can load the waveform, so after 15 sec of playing, the player switch to the next song.
foo_lastfm_radio
Reply #382
I las tried to play those skipped songs on the official Last.fm radio, and they are available. So the reason these songs are skipping is not because of the unavailability.
Any help?
foo_lastfm_radio
Reply #383
The seekbar is definitely the problem that the songs skip. I disabled it and this plug in is working perfectly
Regards go to the creater of this plug-in.
foo_lastfm_radio
Reply #385
A note on Love/Ban
This functionality is part of a separate API, and additionally requires a corresponding audioscrobbler submission (see http://www.last.fm/api/show?service=260). It therefore won't be implemented in foo_lastfm_radio. Sorry.
maybe you could add in an optional macro of sorts that navigates to the last.fm page in your browser and love/ban's the song automatically for you...
foo_lastfm_radio
Reply #386
I'm getting "Error retrieving Last.fm radio playlist: An unknown error occurred." as a popup-message, and at same time in console "Last.fm Radio: Handshake successful."
Anybody knows what's wrong? I also tried with clean portable installation of foobar, but same messages occured.
foo_lastfm_radio
Reply #387
Hey. I'm running last.fm radio with the default GUI and I'm still getting Unable to resume decoding / Decoding failure messages almost on every track.    So I'm not sure the seekbar is really the problem.
Any other ideas?
foo_lastfm_radio
Reply #388
Hello,
Here is a bit unusual request. Given the last.fm staff plans to disable the api this component uses it is quite nice idea I think.
What about adding libre.fm support?
I can post some little differences comparing last.fm and libre.fm radio api:
1) ws.audioscrobbler.com is alpha.libre.fm,
2) track urls don't end in LASTFM,
3) What the api returns as the track urls is not the final url. Upon loading such an url the server returns:
Temporary redirect (307)
4) libre.fm streams ogg vorbis instead of  mp3 files.
There may also be other differences but I haven't managed to get more up to now.
foo_lastfm_radio
Reply #389
Hello nausea,
Thanks for all the work you have put into this addon.
Since you are not planning to continue development, maybe you could release the code on sourceforge? That way, maybe other people that have the time could continue your work?
Thanks again.
foo_lastfm_radio
Reply #390
I have just been experimenting a bit and I think this is not foo_lastfmradio limitation but foobar 2000s.
It corectly parses and loads the url but does not handle http code 307.
Do you think it's worth to request such a feature in fb2k's http reader?
Does it make sense for general usage or is this highly non-standard implementation at the jamendo's servers?
Can anyone think of some possible workarounds?
foo_lastfm_radio
Reply #391
Hello nausea,
Thanks again.
I hope you mean under a license that is not prohibitive & viral, like the GPL....
foo_lastfm_radio
Reply #392
Any other ideas?
I solved this by adjusting the settings of the playback statistics component in "Advanced" -> "Tools" -> "Playback statistics". Uncheck "Automatically synchronize...".
foo_lastfm_radio
Reply #393
Which makes me remember my number one wish list item of allowing advanced options to be available for buttons... having to open the preferences each time I listen to streams and again when I stop is irksome.
foo_lastfm_radio
Reply #394
Since today I am unable to open any last.fm streams, I always get "Problem retrieving Last.fm radio playlist: Empty playlist.". Might be that the last.fm finally dumped the old API, and the plugin won't work anymore?
foo_lastfm_radio
Reply #395
Same here. It's a shame if they did.
foo_lastfm_radio
Reply #396
I just checked some of my stations. No problems opening streams here...
Perhaps some short term technical problems on last.fm's side?
foo_lastfm_radio
Reply #397
^indeed...
http://status.last.fm/
Previous Issues
Last.fm radio streaming is currently unavailable. We are working on this issue at present. Apologise for any inconvenience caused.
Posted 10 hours ago by lozzd
foo_lastfm_radio
Reply #398
Phew, glad that it still works. I wonder when last.fm will axe the old API, though.
