Topic: Columns UI appearance (Read 3316626 times) previous topic - next topic
0 Members and 31 Guests are viewing this topic.
Reply #1527
I'm using the outdated foo_uie_trackinfo_mod because it's the only such component I am capable of scripting with my limited skills
It starts with a case PNG, then puts up the album art, then overlays a second PNG for the glare. I got the case PSD from these forums someplace, you could find it with a bit of searching.
Reply #1528
This is how mine looks at the moment, but there are still a few things I'd like to do. I'm a big fan of having as much useful information on display as possible, so minimal space is wasted with album covers etc
Reply #1530
Could you PLEASE share the code and case/glare images? I installed the component but could only get some text information for now. Thank you.
In the province of the mind, there are no limits.
Reply #1531
May you tell me how you did that bitrate column?
Looks quite good overall, very clean and you can see everything you need at a glance.
Reply #1533
[a href="http://img809.imageshack.us/i/foobar20110110.png/" target="_blank"] At the moment I am trying to get a nice playlist handling and coverflow integration done.
Reply #1534
Still working on it, but I have all the important stuff done.
Here's my rating script. Works for columns and filters. Reads from the RATING tag, takes values from 0 to 100.
So if you want to give a song a 3.5 star rating, you put 70 in the tag.
$if(%rating%,$ifgreater(%rating%,4,$repeat($char(10),$put(r,$div($add(%rating%,5),10)))
$repeat(★,$div($get(r),2))$ifequal($mod($get(r),2),1,½,),$char(13)),unrated)
Reply #1536
to those interested in my config: i'm moving house tomorrow (to another continent) so i'm a bit swamped. it'll be a while before i can get my config ready for sharing.
in the meantime here are some resources.
much of the playlist script was adapted from a config called Whiteout posted a while back by Dirhael
http://www.hydrogenaudio.org/forums/index....st&p=643177
the case image used in the now playing was uploaded by Falstaff/Br3tt
http://www.hydrogenaudio.org/forums/index....st&p=470964
it's a pretty straightforward config if you know title formatting, nothing too revolutionary. but it is very much tied to the specific and sometimes unconventional way i tag my music, so even if i get it uploaded it will require a lot of tweaking before it will work for you. just saying
Reply #1537
Thanks for the response!  The parts I was particularly interested in were the stuff you seemed to be pulling from last-fm (the bios and whatever that other tab is for).  How did you do that?  And in the lyrics tab, is that pulled from the tags or dynamically being scraped from the web?
Reply #1539
I wanna thank you already for this  But i installed all required components, than I open foobar/STRG+P/ than I want to import the .fcl file and it tells: The layout import was aborted because the following required panels are not installed!
Name: Quick Search Toolbar.
Can anyone help me out.
Edit: Nevermind I solved it
Reply #1540
Hey guys, I made some nice progress, so I really want to show you my actual config:
Fullscreenview:
Reply #1541
dark and simple
Reply #1542
fullscreen config I whipped up. I went for a clean minimal interface (no button/panel switchovers) with some color  coordination...
Reply #1543
Spotifoo 1.2.0 - CUI config
[a href="http://img534.imageshack.us/i/previewspotifoo120.png/" target="_blank"]
Reply #1544
My new skin. Simple, nothing fancy.
Reply #1545
OK, here's my take. All best.
Reply #1546
Here's mine, I made it in 10 hours
im not an expert on theming.
I would like to change the color of the windows (i mean to that gray that separates the panels)
It uses:
peakmeter spectrum
NG playlist
lyric show 2
buttons (added by me , edited in PS)
artwork view
Reply #1547
Reply #1548
First post and it's my very plain configuration.
Reply #1549
