Topic: Columns UI appearance (Read 3320448 times) previous topic - next topic
Reply #1450
Well, guys... I decided it wasn't needed to start a new topic just to ask this, but the question is: I have no clue about even how to start developing a new skin and I couldn't find one which fits what I'm looking for. Maybe you, foobar enthusiasts, could help me with a hint.
I don't know how to express what I'm looking for, but I see most of the skins displays the songs in a "continuous playlist", with all albums in it. I wish I could just select the album I want to listen in a panel or something. Also, it would be great if it showed the current album artwork while playing... and had clean light colors. Sorry if this sounded selfish, I just couldn't find a skin like this, and I'm almost sure there is one which fits it... Thank you for your attention and sorry for any inconveniences!
Reply #1451
Thats my simple config.
Wupi, I'm using your config. It was all fine but I've recently reformatted and I don't seem to have the font that shows the note when a song is playing. Where can I get that bad boy?
Cheers
Reply #1452
I don't know what you mean, but all fonts should be segoe ui. Maybe you can post a screenshot.
Reply #1453
As you can see I've changed it to a >, but before it was a note.
Reply #1454
You mean this right ? ♪ ♫
Reply #1455
Yes, it was coming up as a box before. Working now, cheers!
Reply #1456
Exactly, have fun with my config.
Reply #1457
Clean and simple works for me. Only fancy thing is WSH Panel-made statusbar, because I really wanted to see how long ago I listened to songs last time...
Laite,
I want to try this configuration, but it doesn't install. Foobar ask for "Tabbed stack mod panel" and "Lyric Show". After searching, I see that Tabbed stack mod panel could be "Foo uie tabs", but it's not. Same with Lyric Show, there are different components with this name, Lyric Show2 being the most modern, but it doesn't work also. Can you include those components in the pack?
Ys
Rozzo
Reply #1458
Laite,
Ys
Rozzo
Here: http://www.multiupload.com/4IG1SW6DNB
Reply #1459
Or instead of possibly violating the licenses of the components, link their original locations instead, allowing users to find updates and support.
Stay sane, exile.
Reply #1460
I really support this. Moderation may remove the link in my post if they think it's not appropriate (I can't seem to edit my own posts anymore).
foo_uie_tabs: http://wiki.hydrogenaudio.org/index.php?ti..._(foo_uie_tabs) (actually there seems to be newer version here: http://www.hydrogenaudio.org/forums/index....t&p=410247)
foo_uie_lyrics (crashware): http://www.hydrogenaudio.org/forums/index....showtopic=55691
Reply #1462
Since  I moved to win7 I really wanted my foobar to follow the aesthetics used everywhere else in the OS.
This is what I came up with:
@Sylph: wow! it's been a while since I used that. I was pretty new to the WSH Panel and JScript at that time, it must be really ugly code!
<insert signature here>
Reply #1463
Mind sharing it?
ps, Are u using playlist dropwdown? How did you edit it?
Reply #1464
LOL, could be!  Perhaps that's why it crashes a bit (read: a lot more than it should, and only in recent WSHs).
I thought you were going to improve on this one, I didn't know you were going for WMP look.
This one I really like.
Reply #1465
Pretty simple but it gets the job done very well.
Reply #1466
This is my foobar2000 right now:
A pretty functional Zune-ish looking config
Wow, you've got some awesome setups!
Can you post your configs for that one and these two too? lol. I just started using columns after a LONG time with DUI. I need to know how to make these complex layouts!
Amazing!
dark gray, stacked buttons of different heights
aero interface skinning
Reply #1467
"Black Glass Remake"
Design based on original old Panels UI config "Black Glass 3.0 CE" by Russell777.
Port to CUI, near fully rewritten code and some helpful improvements by me.
Reply #1468
Please share!!
ys
Rozzo
Reply #1469
Many thanks late, for this beautiful skin.
Sadfully, i am unable to make it work on my foobar latest portable installation.
This is what it says on the console :
WSH Panel Mod ({40E79DEC-C827-4592-945F-4DB9DBA531AE}): Parsing file "C:\Users\Prince Thierry\Downloads\Foobar\Foobar portable\scripts\marc2003\v2\common.js": Failed to load
WSH Panel Mod ({40E79DEC-C827-4592-945F-4DB9DBA531AE}): Parsing file "C:\Users\Prince Thierry\Downloads\Foobar\Foobar portable\scripts\marc2003\v2\tooltip_buttons.js": Failed to load
Error: WSH Panel Mod ({40E79DEC-C827-4592-945F-4DB9DBA531AE}): Erreur d'exécution Microsoft JScript:
'settings_path' est indéfini.
Ln: 42, Col: 1
<source text only available in compile time>
Filter Panel - Genre: initialised in 0.010 s
Filter Panel - Genre: initialised in 0.005 s
Filter Panel - Artist: initialised in 0.000 s
Filter Panel - Album: initialised in 0.001 s
WSH Panel Mod ({FF63FFB1-A8FF-46F8-84D6-77343F7EDB6B}): Parsing file "C:\Users\Prince Thierry\Downloads\Foobar\Foobar portable\scripts\marc2003\v2\common.js": Failed to load
Error: WSH Panel Mod ({FF63FFB1-A8FF-46F8-84D6-77343F7EDB6B}): Erreur d'exécution Microsoft JScript:
Objet attendu
Ln: 15, Col: 1
WSH Panel Mod ({B372D3B7-0915-42FC-96EB-06C92AC4E4BF}): Parsing file "C:\Users\Prince Thierry\Downloads\Foobar\Foobar portable\scripts\marc2003\v2\common.js": Failed to load
Error: WSH Panel Mod ({B372D3B7-0915-42FC-96EB-06C92AC4E4BF}): Erreur d'exécution Microsoft JScript:
Ln: 5, Col: 1
WSH Panel Mod ({5994EBDB-DED8-4D39-A222-90F2C1DA6966}): Parsing file "C:\Users\Prince Thierry\Downloads\Foobar\Foobar portable\scripts\marc2003\v2\common.js": Failed to load
Error: WSH Panel Mod ({5994EBDB-DED8-4D39-A222-90F2C1DA6966}): Erreur d'exécution Microsoft JScript:
Objet attendu
Ln: 14, Col: 1
WSH Panel Mod ({79CC1745-74F8-420C-82B7-4EAC6E0EA92F}): initialized in 4 ms
Failed to load the libpng library. Check that libpng13.dll and zlib1.dll are present in your foobar2000 installation directory. See "libraries" in preferences for further details.
failed loading image "C:\Users\Prince Thierry\Downloads\Foobar\Foobar portable\images\3468689816\redo_16.png"
failed loading image "C:\Users\Prince Thierry\Downloads\Foobar\Foobar portable\images\3468689816\rewnd_16.png"
failed loading image "C:\Users\Prince Thierry\Downloads\Foobar\Foobar portable\images\3468689816\pause_16.png"
failed loading image "C:\Users\Prince Thierry\Downloads\Foobar\Foobar portable\images\3468689816\fastf_16.png"
failed loading image "C:\Users\Prince Thierry\Downloads\Foobar\Foobar portable\images\3468689816\home_16.png"
failed loading image "C:\Users\Prince Thierry\Downloads\Foobar\Foobar portable\images\3468689816\foldr_16.png"
failed loading image "C:\Users\Prince Thierry\Downloads\Foobar\Foobar portable\images\3468689816\copy_16.png"
failed loading image "C:\Users\Prince Thierry\Downloads\Foobar\Foobar portable\images\3468689816\prtpv_16.png"
failed loading image "C:\Users\Prince Thierry\Downloads\Foobar\Foobar portable\images\3468689816\sinfo_16.png"
failed loading image "C:\Users\Prince Thierry\Downloads\Foobar\Foobar portable\images\3468689816\edit_16.png"
failed loading image "C:\Users\Prince Thierry\Downloads\Foobar\Foobar portable\images\3468689816\srch_16.png"
failed loading image "C:\Users\Prince Thierry\Downloads\Foobar\Foobar portable\images\3468689816\mp3tag.png"
Seekbar: taking Direct2D1 path.
Seekbar: Frontend initialized.
Startup time : 0:00.598570
As i am unable to understand the content, is this possible that you put your whole configuration in portable mode on megaupload or anything else.
I would be gratedfull for eternity.
Thierry.
Reply #1470
Rozzo, you can download it from here now:
Black Glass Remake (translated with Google)
And check for update when Foobar2000 1.1.1 released.
Reply #1471
my config.
