Topic: Columns UI appearance (Read 3306340 times) previous topic - next topic
Reply #1100
My Config
Reply #1102
yeah, concrete gray + orange, I got impressed by that colors
Reply #1103
Here is my second view on the latest "win phone 7 tribute" i did...
[a href="http://img32.imageshack.us/i/40475016.jpg/" target="_blank"]  I like it flat...
Reply #1104
Looks great Mr. Pacman.  How do you add the progress bar to the track that is playing?
Reply #1105
add this to the PerSecond section of your elplaylist:
$puts(percent,$muldiv(%playback_time_seconds%,100,%length_seconds%))
$puts(width,$muldiv(%el_width%,$get(percent),100))
$drawrect(0,0,$get(width),%el_height%,0-0-255,0-0-255,)
Reply #1106
I'm finally happy with my own layout, and here's what it looks like. The custom (smooth) seekbar & volume bar are the latest additions.
The last element I'd like to customize would be the playlist's scrollbar, but it'll do for now.
Reply #1107
hey nardin,
looks good, just one question: how do you make the extra space between the groups (i suppose this is ng playlist)?
Reply #1108
Hi slowmotion,
for the extra space look here for example: ngplaylist - change album name and line color?
With this above I set up a second "Grouping Script" with any content, e.g. %artist% or something else. Because I set the background color under "Playlist view" - "Globals" to white (look at the link) every text will be white without $rgb-specification. Also "unvisible" in my case.
Greets
Reply #1109
Hi slowmotion,
Greets
Bollerkopp is almost right. Actually my tracks are grouped twice with the same script, and the first grouping line is the same color as the background.
And yes it is NG Playlist. Other components used are the Panel Stack Splitter and the WSH panel mod.
Reply #1110
Hi slowmotion,
Greets
Thx guys, to use the grouping twice - is nice :-)
Reply #1111
foo_wave_seekbar, foo_uie_library_tree, channel spectrum panel (color mode: simple-line), NG playlist
Reply #1112
I love it! could you please share the config?
Reply #1113
Well, its based on br3tt's code from x-change config and right now the code is in a bad mess because of my "modding"... I will clean it and share it in 1-2 weeks if Br3tt doesn't have a problem...
Reply #1114
I've made a few adjustments on my Columns UI config:
"I never thought I'd see this much candy in one mission!"
Reply #1116
I just have to say /mnt, wow, 894 kb/s???
That's usually a good bitrate i get with  compressed lossless files, such as FLAC.
?he "telephone call" is underrated...its a very nice track IMO...
I have to agree it was a underrated track, but IMO i find the other half of the track to sorta drag along.
I was supposed to given it a 4 rating, but i forget update my play statistics on my MP4 tags.
Reply #1117
---- Big Edit ------
Started a change on my old layout. Like it pretty much as it is now =).
Now playing tab
Playlist tab
Made a Dual graphic browser, so they line up to eachother on the different tabs, could probably make that ''1'' instead of ''2'' graphical browsers, but just testing this look out.
Reply #1118
Xchange 3.6.0 for foobar2000 1.0
[a href="http://img38.imageshack.us/img38/1705/xchange360promo.png" target="_blank"]
Reply #1119
Just my normal full screen setup.
Small Version
Reply #1120
@falstaff:
what are those numbers next to the track titles?
Reply #1122
thanks falstaff
Reply #1123
Thank you for the update Falstaff! ..."X-Change" is your greatest work / concept IMO...the only problem i always had with it, was that it uses valuable space above the windows (because of the min/max buttons etc).
Reply #1124
According to your instructions within your installation manual, I unchecked the "safe mode" in the WSH Panel Mod.
But, unfortunately I've got several script errors still after importing your fcl like this.
Error: WSH Panel Mod (GUID: 305E4E48-FAA0-4D8C-9992-64751C8364C2): Microsoft JScript Runtime Error:
Could you fix this? I really want to use this Xchange skin with Foobar2000 1.0.
