Topic: Columns UI appearance (Read 3306379 times) previous topic - next topic
Reply #1150
Just a simple iTunes shaped setup. Looking for any tips or suggestions!
Reply #1151
Here's my layout.
The neat part about the status bar on the top is that I've configured it to update independent of playback time, so the bar's sliding motion is nice and relatively smooth. It updates every 50ms.
Reply #1152
Your seek/status-bar looks really great !
Could you upload your script? Thanks in advance
Decalicatan Decalicatan
Reply #1153
Sure, let me document / beautify the code and I'll pop it on here.
It's pretty messy right now
Edit: Okay, here's the code.
// Info Bar 0.1.2
// Copyright ©2010 Lediur
// Completely rewritten from the stock WSH Panel progress bar script.
// Licensed under BSD License
// License bits
// This script is considered an addon for WSH Panel Mod.
// WSH Panel Mod is free software: you can redistribute it and/or modify
// it under the terms of the GNU General Public License as published by
// the Free Software Foundation, either version 3 of the License, or
// (at your option) any later version.
// WSH Panel Mod is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
// GNU General Public License for more details.
// Basic functions
// Evaluates color input
// INPUT: 3 values, RED GREEN BLUE;
//        4 values, RED GREEN BLUE ALPHA;
// RETURNS: Byte value representing the selected color
function RGB(r,g,b){ return (0xff000000|(r<<16)|(g<<8)|(b)); }
function RGBA(r,g,b,a){ return ((a<<24)|(r<<16)|(g<<8)|(b)); }
// Evaluates time from seconds
// INPUT: 1 value, SECONDS
// RETURNS: A formatted string representing the desired time.
function TimeFmt(t){
var zpad = function(n){
var str = n.toString();
return (str.length<2) ? "0"+str : str;
var h = Math.floor(t/3600); t-=h*3600;
var m = Math.floor(t/60); t-=m*60;
var s = Math.floor(t);
if(h>0) return h.toString()+":"+zpad(m)+":"+zpad(s);
return m.toString()+":"+zpad(s);
// This is a "separation value" I found helpful for
// separating the "artist/album" and "title" displays.
// It is dependent on the size of these two displays (font size),
// which is modified in the UpdateSize() function.
// Please see the documentation for UpdateSize() for more info.
var factor = 10;
// String variables
var title;
var artist;
var status;
var time;
// Fonts
var g_titlefont = gdi.Font("Arial", 32, 1);
var g_artistfont = gdi.Font("Arial", 32, 1);
var g_statusfont = gdi.Font("Arial", 24, 1);
var g_timefont = gdi.Font("Segoe UI", 28, 2);
// Title Formats
var g_title = fb.TitleFormat("%title%");
var g_artist = fb.TitleFormat("%artist% / %album%");
var g_time = fb.TitleFormat("%playback_time%/%length%");
var g_status = fb.TitleFormat("♥%rating% ♪%play_count% %codec% %samplerate%Hz $caps(%channels%) %bitrate%kbps");
// Boolean variables for seek-checking
var g_drag = 0;
var g_drag_seek = 0;
// Gradient settings
var c_progtop = RGB(0,150,255);
var c_progbot = RGB(0,50,200);
var c_proglead = RGBA(0,30,255,255);
// Timer for updating progress bar and other items
var f_timer;
function on_paint(gr){
var ww = window.Width;
var wh = window.Height;
var pos = 0;
var length = fb.PlaybackLength;
    gr.SetTextRenderingHint(4);
// Evaluation of information
if(length > 0){
if(g_drag){
pos = window.Width * g_drag_seek;
title = "Seeking: ";
            time =  TimeFmt(g_drag_seek * length) + " / " + TimeFmt(length);
else{
pos = window.Width * (fb.PlaybackTime / length);
title = g_title.Eval();
            artist = g_artist.Eval();
            time = g_time.Eval();
            status = g_status.Eval();
// FillGradRect ( Starting X, Starting Y, Width, Height, Gradient Rotation, Starting Color, Ending Color )
    // Background Bar
gr.FillGradRect(pos, 0, ww-pos, wh, 90, RGB(0,0,0), RGB(11,22,32));
    // Progress Bar
gr.FillGradRect(  0, 0,    pos, wh, 90, c_progtop, c_progbot);
    // Progress Bar Leader
    gr.FillGradRect(pos-3, 0, 50, wh, 180, RGBA(0,0,0,0), c_proglead);
    // Right Gradient
    gr.FillGradRect(ww-100, 0, 250, wh, 0, RGBA(0,0,0,0), RGBA(17,66,170,255));
// DrawString ( Output String, Output Font, Color, Starting X, Starting Y, Width, Height, Hex Values )
// /!\ NOTICE
// These values were determined through trial and error.
// They work fine on my computer and resolution, but
// you might want to tweak them to fit your taste.
// Unfortunately, I don't have documentation for the hex values.
// Here's what I figured out so far, though.
// 1: Alignment (0: left, 1: center, 2: right)
gr.DrawString(title, g_titlefont, RGB(255,255,255), wh/4, -wh/5.7 + factor, ww-250, wh, 0x01000000);
    gr.DrawString(artist, g_artistfont, RGB(255,255,255), wh/4, wh/4.5 - factor, ww-250, wh, 0x01000000);
    gr.DrawString(time, g_timefont, RGB(255,255,255), 0-wh/6, -wh/6.5, ww, wh, 0x21000000);
    gr.DrawString(status, g_statusfont, RGB(254,168,0), 0-wh/6, wh/4.5, ww, wh, 0x21000000);
// Resizes the text in the info panel
// INPUT: WSH Panel HEIGHT, WSH Panel WIDTH,
// /!\ NOTICE
function updateSize(){
    var font_size;
    // ====== TITLE SIZE COMPENSATION ======
font_size = (window.Width - 50) / 30;
    factor = (window.Width - 400) / 100;
// Upper-bound font size limiter
if(font_size > 36)
font_size = 36;
// If we don't check for this we get the JavaScript
// equivalent of a NullPointerException.
if (title != null){
        font_size -= title.length / 100;
// Upper-bound width limiter
if(window.Width > 800) {
factor = 0;
// Lower-bound width limiter
        if(window.Width < 300)
font_size += window.Width / 70;
// Try to check for excessively long titles
if(title.length > 50)
font_size -= title.length / 7;
if(title.length > 70)
font_size -= title.length / 50;
g_titlefont = gdi.Font("Arial", font_size, 1);
    // ====== ARTIST SIZE COMPENSATION ======
    font_size = (window.Width - 50) / 50;
if(font_size > 24)
font_size = 24;
if (artist != null){
font_size -= artist.length / 120;
font_size += window.Width / 90;
if(artist.length > 80)
font_size -= artist.length / 22;
if(artist.length > 120)
font_size -= 6;
g_artistfont = gdi.Font("Arial", font_size, 2);
    // ====== TIME SIZE COMPENSATION ======
    font_size = (window.Height - 5) / 2;
    g_timefont = gdi.Font("Arial", font_size, 2);
    // ====== STATUS SIZE COMPENSATION ======
    font_size = (window.Height - 5) / 4;
    g_statusfont = gdi.Font("Arial", font_size, 1);
// Some of this stuff may be redundant,
// but it works fine on everything I've listened
// to so far.
function on_size(){
updateSize();
function on_focus(focused){
//fb.trace("focus " + focused);
function on_key_down(key){
//fb.trace("key " + key);
function on_mouse_lbtn_down(x,y){
g_drag = 1;
function on_mouse_lbtn_up(x,y){
if(g_drag){
g_drag = 0;
g_drag_seek = x / window.Width;
g_drag_seek = (g_drag_seek<0) ? 0 : (g_drag_seek<1) ? g_drag_seek : 1;
fb.PlaybackTime = fb.PlaybackLength * g_drag_seek;
// Allow for seeking
function on_mouse_move(x,y){
if(g_drag){
window.Repaint();
function on_mouse_wheel(delta){
//fb.trace("wheel " + delta);
// Create a timer for updating the bar.
// Change the timer interval to have the bar
// update more or fewer times per second.
function on_playback_starting(cmd, paused){
    f_timer = window.CreateTimerInterval(50);
// Update information, repaint on new track.
function on_playback_new_track(info){
updateSize();
    window.Repaint();
// Playback Stop
function on_playback_stop(){
// CPU usage saver
    if(f_timer){window.KillTimer(f_timer);}
updateSize();
window.Repaint();
// Repaint every time we seek
function on_playback_seek(time){
window.Repaint();
// Changes the color of the bar based on the pause state.
function on_playback_pause(state){
    if(state){
    } else {
        f_timer = window.CreateTimerInterval(100);
    c_progtop = state ?  RGB(100,100,100) : RGB(0,150,255);
    c_progbot = state ?  RGB(60,60,60) : RGB(0,50,200);
    c_proglead = state ?  RGB(5,29,84) : RGBA(0,30,255,255);
    window.Repaint();
// Repaint every tick
function on_timer(){
    window.Repaint();
//EOF
For a version without terrible indenting: http://files.lediur.com/up/data/Current.js
The sizing algorithm could be better, but it works for everything except ridiculously long tags, so I'm not in a hurry to change it.
I'm currently running this cleaned version in my own player, so I'll put up some updates if there are any problems.
Enjoy!
Reply #1154
A wild guess would be that the flags map to the ones listed in Flags.txt.
Stay sane, exile.
Reply #1155
That makes sense. I saw bits of flags from this file elsewhere in the sample code, but they never seemed to match up to each other.
I only see reference to GdiDrawText as opposed to DrawString, though.
Reply #1156
Wow, that seekbar is pretty awesome .
Reply #1158
Here's my config. It's almost complete, I need to fix the volume bar and add repeat button. It's still Columns UI!
http://yfrog.com/5xversion3ap
http://yfrog.com/7bversion3bp
http://yfrog.com/5vversion3cp
http://yfrog.com/b5version3dp
How did you get Aero to draw on the actual application area? I'm pretty sure ColumnsUI doesn't allow loading external DLLs (the way I know how to do it requires access to DwmApi.dll)
Reply #1159
+1 to know how you have done, that looks good
Reply #1160
@ lediur
thx for sharing your awesome script.
I would like the panel to repaint on initialization
ie. switching between layouts.
Could you please help me with that?
What I have accomplished so far works but it drives my CPU usage
to the roof ...
thx
Reply #1161
I've added an DwmExtendFrameIntoClientArea function to WSH Panel Mod so I could control the Aero effect through my tab bar script depending on the open tab.
Reply #1162
@DarkJedii
You, Sir, are awesome!
<insert signature here>
Reply #1163
Found inspiration here
Reply #1164
Here's mine
Reply #1165
My modified mono_lite skin
credits to originals for like the love track button by marc2003
also top left click is for context menu (which i more like then showing the menu bar in the mono_lite hybrid since its a extra click xd)
and those buttons there is for preferences, console, eq, open cd, playlist filter, album list, nfo generator, preview mode
Where can i find those buttons in top left?
Reply #1167
Could you elaborate on "initialization"? The panel already repaints when a new song is loaded.
Also, what do you mean by switching layouts?
I assume this means using VB instead of Javascript.
I'm not too good at VB, only C# and similar
Reply #1168
I have a new text-resizing algorithm that I've been working on for the past 3 hours which I'd like to submit for public beta:
Here's the new script for my little progress bar, text resizing algorithm and all (and a few extras )
http://files.lediur.com/up/data/InfoBar0.3Beta.js
As you can see, long tags are no problem!
Here's a small changelog:
[+] Method to change playback order without toolbar: scrolling will toggle between Sequential, Shuffle, and Repeat.
[+] Animated playback order indicator
[+] Animation timing allows for CPU savings while providing smooth animations for the indicator.
[~] Changed update timing from 50ms to 100ms to save CPU usage.
[+] Added animation timing of 5ms to allow for smooth animation.
[-] Old, inaccurate method for calculating Title and Artist strings
[+] New method (using GDI's MeasureString) of accurately determining an appropriate width.
[!] This method also adds an unintentional animation while finding optimal size (it's not a bug, it's a feature!)
Please provide feedback / comments / suggestions / complaints.
Reply #1169
thanks man ill check it out
Reply #1170
Here is my new skin in progress
Reply #1171
Well, its based on br3tt's code from x-change config and right now the code is in a bad mess because of my "modding"... I will clean it and share it in 1-2 weeks if Br3tt doesn't have a problem...
Could you please share it now, Mr. Pacman? I like your modding as much as br3tt's new yin yang theme if not more....
Reply #1172
Reply #1173
Initialisation means start of program.
(I want to show some text so that the panel isn't empty when foobar2000 starts.)
I've already managed to do it by declaring two new variables.
I don't really know why but it works...
var title= "foobar2000";
var artist= "htpc mod";
title = "foobar2000";
artist = "htpc mod";
updateSize();
window.Repaint();
Switching between layouts is something you can do
in columns ui. You can have different configurations (layouts) and switch
between them via keyboard shortcut. It's like program startup
with an already playing track.
Situation:
Track is playing->press shortcut->panel in other config doesn't gets updated.
I was trying for hours with no luck.
Reply #1174
How are people getting custom filter panels?
All I seem able to get is the standard album/artist/genre
