Topic: Columns UI appearance (Read 3314923 times) previous topic - next topic
0 Members and 8 Guests are viewing this topic.
Reply #1125
if you have this error with WSH panel mod v1.3.0 or 1.3.1, it's that your system doesn't handle WSH at all, was WSH panels working on other config before your xchange install or is it the first try for you ?
are you under Windows XP ?
try to post your console log to WSH panel Mod topic, i'm sure TP Wang or someone else could brought to you a solution...
Reply #1126
@falstaff. your menu is completely broken. many commands do nothing and others trigger the wrong command. "view>console" opens the "playlist manager" being one example.
Reply #1127
@Falstaff: just trying it out for the first time :-) Wooowwww, what a great work, thx !!
Reply #1128
Thank you for your reply.
Actually, I'm using your previous Xchange 3.5.2 with Foobar 0.9.6.9 (also Foobar2000 1.0) and WSH panel mod 1.2.1 under Windows XP sp3.
In that case, there was no script error and I can enjoy your nice skin.
I found that if I upgrade the WSH panel mod version from ver 1.2.1  to ver 1.3.1 for Xchange 3.5.2 with Foobar 0.9.6.9, the script errors happen.
So, I'm still using the WSH panel mod ver 1.2.1 with Xchange 3.5.2.
Anyway, I'll post my console log to WSH panel mod topic to get some solution.
Thank you again for your kind reply.
Reply #1129
I'm sorry for this messy post.
I didn't follow the Falstaff's directions. And, I solved the problem by installing Xcange in the right directory.
There is no problem with Falstaff's Xchange and WSH panel mod.
To admin, please remove my previous posts & this post.
Reply #1130
yes, i've seen ... i've to check and fix that
@widerock
Reply #1131
to fix your menu (line 399)
menuman.ExecuteByID(ret - num);
Reply #1133
Reply #1134
I'm quite new when it comes to customizing foobar, so to learn a bit more I have tried to do everything from scratch this time. I have borrowed a few grouping scripts which I have customized, but everything else I've done myself:
Reply #1135
DarkOne v2.0
(if still anybody is interested in)
[a href="http://www.abload.de/image.php?img=darkonev2.08py8.jpg" target="_blank"]
Reply #1136
DarkOne v2.0
nice to see a new version of DarkOne
btw, feel free to support it on [a href="http://br3tt.online.fr/forum" target="_blank"]MyFoorum[/url], the Skins section is made for this and i'm sure many people are interested by this new version and have for sure some questions for you
Reply #1137
@Falstaff
Done
Reply #1138
@tedgo
Many people are interested in your configuration! Thank you for the update!
Reply #1140
This is fun! Some very amazing themes have been posted here, it's really interesting to see what can be achieved. Everybody has such a different setup too.
Mine's very simple... Everything's small cause I like to tile my windows, so Foobar usually takes 1/4th of my screen. Hotness displayed as colorized titles (going from dark red to yellow)... Lyrics panel (it's the old one, works fine for me!). Last.fm syncing works perfectly, I even cheat last.fm into accepting mosaic.wav.
Reply #1141
After using Xchange for a long time, I decided to get to something way more minimalistic. So this config  contains everything I need, plus a little bit of eye candy and nothing more.
Only the broken foo_uie_lyrics2 plugin and the fact that I can't seem to integrate the playcount into the playlist keep the config away for suiting my the best.
Reply #1142
Loving WSH Panel!  Ported my default UI config to columns for a slightly cleaner look.
Reply #1144
I have something stolen from your idea, but it realy usefull, the result:
Reply #1148
Here is mine. Clean, simple & functional
sometimes it is the best, not to say anything
