Topic: Missing masstagger (Read 11013 times) previous topic - next topic
Missing masstagger
Love foobar2000.
But since 0.9.5.1, they decided to no longer include MASSTAGER (you can still install as a component).
This is IMHO the worst decision, as the new "tagger" is nowhere as powerfull as the original.
I just hope they keep updating the masstager component.
Missing masstagger
Love foobar2000.
But since 0.9.5.1, they decided to no longer include MASSTAGGER (you can still install as a component).
This is IMHO the worst decision, as the new "tagger" is nowhere as powerful as the original.
I just hope they keep updating the masstagger component.
i suggest you have a look around on the foobar forum first, as more people have "noticed" this before actually looking around the new/reworked UI and finding out where the different functions are to be found now. (in somewhat more logical places, some might even argue)
anyway, the masstagger component is still available, if deprecated.. so i really don't see your point.
Missing masstagger
I suggest you have a look around on the foobar forum first, as more people have "noticed" this before actually looking around the new/reworked UI and finding out where the different functions are to be found now. (in somewhat more logical places, some might even argue)
I know where the new options are, and i have even tried them. They can not do 50% of what i can do with masstager.
My point is that is sad they have decided to deprecate one of the most compelling reasons, at least for me, to use fb2k.
Thankfully at this time, i can install the component by myself, but i wonder when it would no longer be compatible.
Missing masstagger
What functions do you miss?
I have many scripts i use to normalize my tags, for example:
%artist% = $trim($caps($replace($lower(%artist%),á,a,é,e,í,i,ó,o,ú,u,à,a,è,e,ì,i,ò,o,ù,u,â,a,ê,e,î,i,ô,o,û,u,_, ,  , )))
remove all values except for: artist;title;album;tracknumber;genre;disc;date;byme
format title using %title% '('%artist%')'
How would you do that with the new options, and be simple accessible over my right button.
Missing masstagger
$caps2(x)
%artist% =
these still require masstagger.
Properties Window, Ctrl+A, then Ctrl+click each wanted field, Press Delete
Do you mean format filename using %title% '('%artist%')'?
If so, File Operations ->rename to...
elevatorladylevitateme
Missing masstagger
There are cases where we might want to format title using title and some other field. Examples would be when adding (feat. ) information or appending things like (live), or (remix) to the end of the title.
However, all this can be done using the properties dialog.
Also, kwanbis, have you tried $ascii(x)? It can do the replacement of all those characters with umlauts and accents automatically.
Missing masstagger
Yeah, the "Format from Other Fields..." dialog is pretty handy.
Missing masstagger
$caps2(x)
%artist% =
I can see
All that clicking is no near as fast than just running a pre-wrote script.
No, i want to add the artist name, between () at the end of a song, like "whenever, whenever (shakira)".
exactly
Properties dialog is SLOW.
To be honest, the NUMBER 1, thing that drove me to fb2k, was the speed and usability of the masstager.
If it not for it, i would probably still be using winamp + the godfather.
No, i would check it.
You mean i can replace $replace($lower(%artist%),á,a,é,e,í,i,ó,o,ú,u,à,a,è,e,ì,i,ò,o,ù,u,â,a,ê,e,î,i,ô,o,û,u,_, , , ))" with $ascii($lower(%artist%)) right?
Again, handy, but slow. I have to click much more times.
Missing masstagger
)[/li][li]create the script[/li][li]run it[/li][li]edit the script if it did something wrong[/li][li]run it...[/li][/list]
Yes, I've gathered that you like the exact implementation of Masstagger. But for most people, the properties window/foo_fileops is easier to use. It's less automated, but it also is much less overhead. And when title formatting IS required, it's nice enough to show previews, so that files don't get mangled by poorly written scripts. I doubt Peter will do anything that breaks mass tagger any time soon, given it's popularity among power-users. However, he has created something much more usable for most people in every situation. And it's not unrealistic to expect power-users to DL something separate is it?
foo_fileops / properties window is as "powerful" as masstagger, in the sense that it can do 99.99% of everything mass tagger does, so your original point:
...isn't quite accurate. You just haven't taken the time to investigate it's possibilities.
Missing masstagger
I really wish that the DEV will just merge the thing in to one, so everyone will be happy.
Both of them (masstagger,properties page) have there strong point. Arguing about it is kinda pointless IMHO since masstagger still work so what's the problem? Once masstagger "break" sometime in the future (if that happen) and no another tool with same capable were given then go ahead, I will join too.
Missing masstagger
What's wrong with some of you people?
Masstagger still works, as for now there are no plans to introduce changes that would render it useless. I'm just not interested in adding new features or fixing bugs in it, hence it's not maintained anymore.
PS. Very few people prefer the Masstagger way of doing things over what you get with the Properties dialog. I don't want new users to try it before they've tried the Properties dialog, it's pointlessly complicated and requires way too much clicking for simple tag editing tasks.
Missing masstagger
Seems kinda silly that you'd want to do that to your tags, honestly. But yeah, if you had to, "Format from Other Fields..." would do it.
I do this because i name VA cds like this. For example, lets asume i have this VA CD:
SONG_ARTIST_1 VA_ALBUM Track1_TITLE
SONG_ARTIST_2 VA_ALBUM Track2_TITLE
SONG_ARTIST_3 VA_ALBUM Track3_TITLE
I like to name them like this:
VA_ALBUM DATE_OF_ALBUM_AS_ALBUM_NAME Track1_TITLE (SONG_ARTIST_1)
VA_ALBUM DATE_OF_ALBUM_AS_ALBUM_NAME Track2_TITLE (SONG_ARTIST_2)
etc.
Probably not for you, but for 95% of people it's faster (see below) and a heck of a lot easier.
I can agree with EASIER, but not with faster, once you have the scripts prepared. Not even close.
Yeah, now that you have your scripts already created, it takes fewer clicks, making it "faster". But for someone new wanting to do something they have to:
  • Digest the title formatting language (which may or may not be a small task, heck even you didn't know about $ascii()  )
  • create the script
  • run it
  • edit the script if it did something wrong
  • run it...
And i applaud Peter's decision to make it easier. But i wish both are maintained, because as of now, masstager IS compatible, but one day it may not be.
Again, i'm not against simplifying for the newbies. Me myself have changed MAREO many times, so it gets easier for the people.
I just wanted to raise my hand and say, "hey, i love masstager, please, don't deprecate it".
I'm glad to hear that.
I assume you are also a power user, may i ask if you also prefer the new way than the masstager then?
Haven't done any poll, but i can assume you are right.
Hehe, but you make me try it and learn its language
Missing masstagger
Masstagger is faster for automation, yes. For general-purpose tag editing, however, the Properties dialog is lightning-quick. The Masstagger can't really compare there.
They each have their niche. Masstagger still continues to work, so no need for panic. If Masstagger gets dropped for some inexplicable reason, I'll be among the first to start whining. But it's still available and still as awesome as ever.
Missing masstagger
I agree with you on that ...
I just wanted to raise my concern, cause if nobody does, then Peter would assume we are all happy without masstager, and could wrongly assume that if he drops it, nobody would miss it.
Just that.
So yes, i'm VERY HAPPY it still works.
Missing masstagger
Call me stupid but . . .
... where can I find the MassTagger now?
Missing masstagger
Erh, long time no see you're here. It's on foobar optional component official page.
