Topic: foo_httpcontrol (Read 950995 times) previous topic - next topic
foo_httpcontrol
Reply #775
I've installed httpcontrol and can access it on the same machine that foobar is running on, but am unable to access it from any other machine on my lan. Current foobar, Windows XP. I punched a hole in my firewall at tcp 8888, but a call to http:\\192.nnn.nnn.nnn:8888\ goes unanswered.
Pointers appreciated,
John
foo_httpcontrol
Reply #776
I have a request for the masters of javascript and ajax here (vakata if you read this  )
Do you think it is possible to make a carousel from all the album arts in in foobar's media library using the jquey plug-in jcarousel ( http://sorgalla.com/jcarousel/ )
I think it would be a great add-on to vakata's and ajquery 's templates and a simple way to add an album to the playlist ... just a thought.
If I had the programming skills, i would have given it a shot but I think I still have a lot to learn to make it work ...
foo_httpcontrol
Reply #777
is there a way to add archives (ZIP/RAR) to the playlist? this works with foobar, but not with httpcontrol.
love this plugin so much i even run it in linux using wine (works nice), only thing missing here is archives for me, since i have a lot of albums as archive files.
foo_httpcontrol
Reply #778
Solved? No remote access worked until I turned logging on, now all remote access works whether logging is on or off.
Happy, but puzzled.
Thanks for a great component.
    John
foo_httpcontrol
Reply #779
this kind of weird stuff requires writing a new component.
It seems that regardless of archive reader component(s) presense, archive formats are not listed in supported file types list within the foobar2000 "Add file..." dialog. my component uses this list to remove unplayable files while adding. I could hardcode support of zip and rar extensions, but it wouldn't be too beautiful (and I doubt it will help considering the current way I'm doing the adding). I'd like to use more generic approach of which I'm clueless at the moment. EDIT: I'll add a workaround in next version.
it couldn't be logging as it's completely unrelated to the problem you had - it's just a bit deciding whether to log requests to foobar2000 console or not.
foo_httpcontrol
Reply #780
hey, iv noticed some rather strange behaviour today.
in 2 of the skins i use (vakata2 & ajquery), when i enqueue a track they don't immediatley show as qued until something updates in foobar (ie, playback stats, playlist, track change). this behaviour is not apparent in the default skin (but as far as i can tell, it uses a different method to enqueue).
i tried downgrading this plugin & resetting the settings but to no avail.
i'm currently using the latest version of foobar with the latest version of this plugin & iv never had this issue before until today.
a thought however, i think my java plugins have been updated (i dont quite recall im afriad) & i'm almost certain this behaviour only started after then.
sorry to bring that to your attention if its unrelated.
EDIT: doesnt appear to be related, just disabled said add-ons & http control still behaves the same
if i can provide anymore information please dont hesitate to ask.
thank you for a great & often used plugin
EDIT2: tried accessing foobar through http on my Ubuntu install, still the same problem.
Also, installed the component to foobar on my laptop & got the same issue from that. hope this is of some help to you
foo_httpcontrol
Reply #781
EDIT: fixed in 0.96.12.1
foo_httpcontrol
Reply #782
may it be that you have 'stop after queue' feature disabled? it might be the case. anyway, try this.
if it doesn't help, try using a different browser.
that was it, must of got disabled from the update today. tried the version you just posted & works a treat when "stop after queue" is enabled or disabled!
just to clarify, "Enable Stop After Queue Feature" was enabled in the preferences page, but not enabled under the "Playback" menu.
problem was present in both Firefox 3.6.3 & IE 8.
thanks alot oblikoamorale for your time, now i can put my hair back in
foo_httpcontrol
Reply #783
Thank you so much for this wonderful plugin. It has really rocked my world. Like any new user who has not acclimated to a new system, I have some insight as to a possible improvement: would it be possible to have a setting so that I may hide the "home directory" on the landing page? The use of credentials is perfect but I would not like specific paths, especially ones containing usernames to the local machine, exposed by default for any visitor who happens to land on the site. Thanks!
foo_httpcontrol
Reply #784
you cannot specify directories forbidden for browsing, but you can define a list of allowed directories: use "Allowed paths" field in preferences, multiple values should be separated by |.
I don't consider exposing the component to whole internets a good idea. I don't know what possible vulnerabilities are crawling around in my code and, especially, jnetlib. use another layer of protection like firewall check if you really have to access the component from the outer world.
foo_httpcontrol
Reply #785
John
Did you solve your problem? It does not work for me neither but I don't even know how to "punch a hole in my firewall"... Is there a tutorial somewhere for that?
foo_httpcontrol
Reply #786
Hi, is there any way to put into the httpcontrol page a visualisation plugin like the spectrogram via the foo_httpcontrol ?
Thanks, Federico
foo_httpcontrol
Reply #787
??????? ??????????? ?? ???????, ???? ??? ?? ?????? ?????? – ?? ??? ???? ??????????,  ????????? ??? ? ?????? ????????. ????????? Firewall  ? ?.?.
??? ???, ???? ??????? ????????? foobar(??) ????? ????????, ?????? ? ???? ? ?????? ??????? ??????????? ip-?????, ?????? ???????????? - ?????????!
???????? ???????????? ????? ip-?????  ?? ? ????.
??????? ?? ???????????????????? ????? ???. ???????? foobar(??) ????? ????????.
foo_httpcontrol
Reply #788
Is there a way to get httpcontrol to skip forward in the currently playing track by say 10 or 20 seconds? All I could find in the instructions was the ability to seek for a given percentage of the track length. (This is possible via a foobar2000 hotkey so I am probably missing something obvious.)
foo_httpcontrol
Reply #789
not at the moment. I'll add command with this kind of behaviour in next version.
foo_httpcontrol
Reply #790
Hello.
Small bug : in the 0.63 version of the ajquery template, you added shift+[ or shift+] to resize playlist height but for me, shift+[ doesnt work while shift+] works well. foobar2000 1.03; foo_httpcontrol 0.96.12.1; firefox 3.63
foo_httpcontrol
Reply #791
@oblikoamorale: Thanks, that would be great!
foo_httpcontrol
Reply #792
Баги у foo_httpcontrol_0_96_13.
foo_httpcontrol
Reply #793
the newest version.
Only IE can open correct,but Chinese characters display as garbage.
foo_httpcontrol
Reply #794
duh, somehow generation of proper content-type went down the drain. hopefully fixed in 0.96.13.1
foo_httpcontrol
Reply #796
http://127.0.0.1/ajquery/index.html
Error loading template configuration file:
foo_httpcontrol_data\ajquery\config
Show installed templates list
Firefox 3.6.3
Foobar 1.0.3 portable
foo_httpcontrol 0.96.13.1
ajquery template 0.64
What do I do not so?
foo_httpcontrol
Reply #797
Has understood.
I should fill a field Home directory.
foo_httpcontrol
Reply #798
That would be totally ACE if you could do that!
foo_httpcontrol
Reply #799
I should probably add console message with full path of file that component tries and fails to open.
EDIT: frogworth: it's already done
