Topic: mp3 or mp4 (AAC) (Read 2859 times) previous topic - next topic
mp3 or mp4 (AAC)
can any one tell which one is best?
nowadays mp4 (AAC) comes with nero5510.
thanx.
mp3 or mp4 (AAC)
Hi, maybe you would also like to take a look at the two AAC boards on this forum, the threads there should answer most of the questions a newcomer might have. Another good source of information is http://www.audiocoding.com, especially the Wiki section and the forum.
To answer your question: AAC/MP4 is better than MP3 at all bitrates, meaning that it can deliver the same sound quality as LAME or Fraunhofer MP3 with a lower bitrate because of its higher efficiency. The differences between these two formats are explained very well in a PDF file from Karlheinz Brandenburg (one of the main developers at FhG for both formats) called "MP3 and AAC explained". You can find a link to this document in the Wiki mentioned above under "Simple technical info for novices".
ZZee ya, Hans-Jürgen
BLUEZZ BASTARDZZ - "That lil' ol' ZZ Top cover band from Hamburg..."
INDIGO ROCKS - "Down home rockin' blues. Tasty as strudel."
mp3 or mp4 (AAC)
thanx all of u,for right path.
