Topic: Nero Digital Audio+ 1.1.34.2 released (Read 83452 times) previous topic - next topic
2007-08-06 - Version 1.1.34.2
  • neroAacEnc:
    • Linux version
    • New q value mappings
    • Retuning of almost all bitrates
    • Fix in HEv2 encoder/decoder delay
    • Fixed incorrect streamlength written in MP4 files
    • Significant speedup
    • Removed -hinttrack option
  • neroAacDec
    • Linux version
    • Fixed a memory leak
  • neroAacTag
    • Added -hinttrack option
Is this essentially the same package that was released for the listening tests, or is it different?
the one in the listening tests was 1.1.34.0 and this one has a .2 so i doubt it
1) q mapping fix for mono
2) q mapping fix for -q 1.0
Thank yooou.
This is pretty awesome.  The last two changes were fixes to bugs pointed out by members of our very own HA community prior to official release!
Just goes to show that some public beta testing isn't necessarily a bad thing.
Copy Restriction, Annulment, & Protection = C.R.A.P. -Supacon
As there is a Linux version now, would it be difficult to get it to run on OS X?
Every night with my star friends / We eat caviar and drink champagne
Sniffing in the VIP area / We talk about Frank Sinatra
Do you know Frank Sinatra? / He's dead
Dang it, I ripped a CD with the old version just a few minutes before I saw this.  Hopefully this release doesn't have any notable improvements.
Seriously though, thanks for updating the free encoder.  Linux support in particular is much appreciated.
Hmm, it's strange - SSE build doesn't want to run on Athlon 64 with full SSE support under 32-bit WinXP .
C:\Bin>neroAacEnc_SSE.exe
Fatal Error : This program was not built to run on the processor in your system.
Some info about processor (from CPU-Z):
  CPU-Z version 1.38
Processors Information
Processor 1 (ID = 0)
Number of cores 1
Number of threads 1 (max 1)
Name AMD Athlon 64 3200+
Codename Venice
Specification AMD Athlon™ 64 Processor 3200+
Package Socket 939
CPUID F.F.2
Extended CPUID F.2F
Brand ID 4
Core Stepping DH-E6
Technology 90 nm
Core Speed 1006.3 MHz (5.0 x 201.3 MHz)
HT Link speed 1006.3 MHz
Stock frequency 2000 MHz
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
L1 Data cache 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 512 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
max FID 10.0x
VID range 1.100V - 1.450V
K8 Thermal sensor yes
K8 Revision ID 4.2
Attached device PCI device at bus 0, device 24, function 0
Attached device PCI device at bus 0, device 24, function 1
Attached device PCI device at bus 0, device 24, function 2
Attached device PCI device at bus 0, device 24, function 3
Plain version works well. Are Athlon processors unsupported by the SSE build or it's just a bug?
Same problem here.
Name				AMD Athlon 64 3400+
Code name NewCastle
Specification AMD Athlon™ 64 Processor 3400+
Family/Model/Stepping FC0
Extended Family/Model F/C
Brand ID 4
Package Socket 754
Core Stepping DH7-CG
Technology 0.13µ
Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE, SSE2, x86-64
None at all. It's a pure bugfix release. Encoding in stereo mode using any setting besides -q 1.0 leads to bit-identical results with both versions, as was stated in another thread.
Same problem here.
It might be an Intel compiler related problem:
http://www.swallowtail.org/naughty-intel.html
AFAIK, we do not use Intel compiler for producing those binaries.
We'll check this out tomorrow.
I really appreciate the Linux version. Now I can finally see how much better it is than FAAC.
Now like another guy said, what's the chance of a Mac OS X version?
Thanks, you guys are great!
Great work guys!
I'll throw my hat in for an OS X version of the encoder.
Indeed  Thanks again to our beta testers!
That is probably as easy as getting an OS X development machine here... so I can try, but I don't promise anything
Actually, for this release we do use the Intel compiler. I didn't know about this issue, will be better for next release.
Anyway, I think our current non-SSE build is faster than the old SSE build.
neroAacEnc_SSE.exe is builded with OpenMP support (libguide.lib included in exe). Is it SSE or SSE2 build (because processors with SSE doesn't support multithreading)???
What is the new q value for approximately 100 Kbps VBR when used for DVD soundtracks? Previously I have been using 0.35
Does this page need to be updated to reflect the neq Q values?
http://www.hydrogenaudio.org/forums/index....showtopic=44310
No, that table should be more valid now than before (on average). It can always deviate, it depends a lot on what you're encoding.
I can confirm this. I recently encoded 2727 tracks using the 1.1.34.0 version, mainly Metal and Hard Rock genres. Though there are also a few Classical recordings, the majority of my CDs is quite competitive for an encoder to process. Hence, the whole bunch's average of exactly 100 kbit/s (calculated by foobar) is a very good result for -q 0.34 (usually ~96 kbit/s).
No improvements to multichannel encoding? : (
Thanks for the update!
PC Dom: Sydney On Site Computer Support
No unfortunately, the next release will have huge (because there is room for that  ) improvements for multichannel support.
