Topic: TAK 1.0.1 Final (Read 62819 times) previous topic - next topic
TAK 1.0.1 Final
The final release of TAK 1.0.1 ((T)om's lossless (A)udio (K)ompressor).
Download links removed. TAK 1.0.2 has been released.
1. TAK Applications 1.0.1
containing the GUI and command line compressor:
2. TAK Winamp plugin 1.0.4 (Updated 2007-05-15)
containing the playback plugin for Winamp:
3. TAK SDK 1.0.3 (Updated 2007-04-28)
containing the SDK documenation and the decoding library dll for developers:
4. TAK Decoding library 1.0.4 (Updated 2007-04-25)
containing only the decoding library dll which is part of the SDK. It's provided for end users using third-party applications utilizing the library, who want to update the library to the current version:
Comments and discussion should go into the thread TAK 1.0.1, where you also find a changelog.
After some days these archives will be moved to rarewares.org.
History
2007-04-25
Replaced TAK Decoding library 1.0.2 with 1.0.4, which was previously available in a separate thread in the upload section.
2007-04-28
Replaced TAK SDK 1.0.2  with 1.0.3, which contains the TAK Decoding library 1.0.4 (instead of 1.0.2). No other changes.
2007-05-15
Repaced the Winamp plugin 1.0.2 with 1.0.4, which fixes a bug when using the in_zip plugin.
TAK 1.0.1 Final
I found the Winamp plugin doesn't allow me to decode the .tak back to .wav, is there any library that I can make use of (either Winamp or Foobar2000) which can decode .tak back to .wav ?
TAK 1.0.1 Final
Foobar's built in converter can convert taks to wavs (or any other format you have the executable of)
