Topic: old FLAC to new FLAC 1.1.4 (Read 20367 times) previous topic - next topic
I can run it, and do the task but I have a few questions about it.
1. It's set up for 1.1.3, I do not know if something has changed in 1.1.4 that can affect the output files.
2. Except the highest compression ratio is anything else changed ?
To answer your first question, nothing has changed in the 1.1.4 version of FLAC that will negatively effect the batch file that Synthetic Soul created. The second question, I'm not completely certain what you are asking. If you are asking if anything besides the highest compression ratio has changed in FLAC 1.1.4, you can view the changelog here: http://flac.cvs.sourceforge.net/*checkout*.../changelog.html.
(offtopic)
@ jcoalson
I have and would recommend the fish book (O'Reilly Bash Book) to anyone who wants to learn the Bash shell. I learned bash scripting etc. on UNIX, but I still go back to the fish book for reference occasionally.
(/offtopic)
Why don't you try OmniEncoder?  It's a nice simple frontend.  Drag and drop your main directory to the window, set up the encoding options (bare necessity defaults  only are available, which is what you want), and use the option to mirror your directory structure to the new location.
Version 1.3 still has flac 1.1.3, so just replace flac.exe and metaflac.exe with the new 1.1.4 versions from the flac homepage.  Omni just uses default settings, so there should be no problems.
HA thread - http://www.hydrogenaudio.org/forums/index....showtopic=51093
For your earlier question about creating just directory structure, you can use xcopy to do this (included in your windows installation).  Say your music is located in C:\music\ and you want to mirror your directory structure to D:\music\, at a command prompt type -
xcopy C:\music\*.* D:\music\*.* /T /E
/E will copy empty directories as well.  If you don't want that, leave it out of the commandline.  Type xcopy /? for a list of all available commands.  Hope this helps!
Looking forward to a new FLAC 1.1.4 version of OmniEncoder! Remember that not all users here know how to replace files in the OmniEncoder distro. But thanks for pointing this user to OmniEncoder.
To be a little more specific, flac.exe and metaflac.exe are located in the main OmniEncoder directory, wherever you choose to install it.  Download the new version of flac 1.1.4 -
http://umn.dl.sourceforge.net/sourceforge/...c-1.1.4-win.zip
Open the archive and extract flac.exe and metaflac.exe from the 'bin' directory to your Omni directory.  Answer yes to overwrite the files.  No bubbles no troubles
1. No.  If you are using FlacGetV with the script to check the version (it doesn't sound like you need to) then you would need to ensure the config uses SET flacVersion=114. The version I uploaded recently already states that.
2. You can just amend SET flacOptions=-8 to SET flacOptions=-5 or SET flacOptions= (nothing after the equal sign) to use default compression.  Nothing else is specifically changed.
If you don't need all the safety aspects of my flac-113 script and you just want to re-encode from one drive to another you could just use:
FOR /R X:\ %%G IN (*.flac) DO FLAC -o "Y:%%~pnxG" "%%G"
If you copy the above code into a text file and save it with a .bat extension you can double click it and it will re-encode any FLAC file on drive X: to drive Y: using the exact same folder structure.  Be warned though: any file that is corrupt, or confuses FLAC.EXE, will not be re-encoded, so you run the risk of losing files if you don't compare the directories afterward.  The benefit of the flac-113 script is that it can recognise some issues and will report all files that failed re-encoding after the whole process has completed.
I'm on a horse.
Reply #30
you can reencode in place with a simple script that finds all flac files and then reencodes them one at a time.  in bash it's just
find /top/level/directory -name '*.flac' -exec flac -5Vf {} \;
I am hesitant to add functionality like this that is so easily accomplished with scripts.
Josh
Synthetic Soul, thanx I understand that
But this Josh said, is it just few steps?
If so, can anyone tell me how
Same as what Synthetic Soul told me?
Thanx a lot wraithdu
I knew about OmniEncoder and how to change flac exe etc... in the program directory.
But I never knew it has the option to mirror a directory.
About xcopy, I never knew it does that.
Is it possible to include smaller files?
Tried OmniEncoder now, for 10 mins nothing happens
I did copy FLAC 1.1.4 (flac.exe and metaflac.exe) to the installed directory.
Mirror the directory to E:\ but nothing happens for +10 min, not even the directory is created.
Gonna try Synthetic Soul tip now.
isnt there flac -f option that should just rewrite old files in 1.1.4 (with a nice batch file)? (then just copy things in 2nd step)
Reply #33
here is what I get with the bat file
It worked, but only on 1 flac file that already was encoed with FLAC 1.1.4
297GB free space
06 One Million Miles Away.flac: ERROR initializing encoder
                                init_status = FLAC__STREAM_ENCODER_INIT_STATUS_E
NCODER_ERROR
                                state = FLAC__STREAM_ENCODER_IO_ERROR
An error occurred opening the output file; it is likely that the output
directory does not exist or is not writable, the output file already exists and
is not writable, or the disk is full.
Reply #34
xcopy.exe D:\ E:\ /T /E
worked perfectly to copy the directories.
thanx wraithdu
Also what Synthetic Soul suggested, works.
But only if the directories are created.
ignore the error!
Thanx everyone!
Reply #36
Is there any appreciable benefit to re-encoding files encoded with an old version with FLAC 1.1.4?  I tested with several albums encoded late in 2004, and found that the difference was on the order of several MB - not exactly earth shattering percentages.
Reply #37
depends on your material, someone else reported 6% gain.
Reply #38
Did you get a progress bar that said 'Decoding Tracks'?  I think that Omni decodes all files to WAVs in your temp directory before creating any directory structure or encoding.  Watch your temp directory for activity.  This seems a little silly, as you could run out of disk space very easily.  Maybe I'll make a request to the developer to do this one file at a time.
Anyways, this is probably why after 10 minutes you saw no activity.
Reply #39
Maybe, but it's a little silly to not have the output directory as temp directory.
Have my windows temp set on partition D:
what Synthetic Soul suggested is done, all converted.
But now I am left wondering how to move all cue, log etc... files.
Is there a way for this to or do I have to do it manually?
Edit:
Actually it did not solve everything.
Have 4078 FLAC files in the old directory, and 3932 in the new
How can I compare?
Edit 2:
Comparing now with WinMerge
http://winmerge.org/
Reply #40
That would be a question for SS, as I think he said his batch file checks and reports errors.
I tested something with Omni this morning, and I'm having other problems as well, so it's better you used the batch file (or foobar if you want to set it all up).
As far as copying log files, etc., it's basically the same process with xcopy as creating the directory structure.  Say you have folder.jpg in each album directory for album art, then using your example before you'd type -
xcopy D:\*folder.jpg E:\*.* /S
the * will search for folder.jpg in all directories below D:\
/S copies all subdirectories to keep structure (similar to /t above but actually copies files)
you can add on /F to show full paths of files copied
/L will just show you all the files that will be copied, without actually copying anything (useful to make sure you have the right command line and it finds all your files)
You can substitute anything for *folder.jpg, like *.cue to copy all cue sheets.
Reply #42
ok
I used xcopy.exe D:\*.cue E:\ /S
for log and cue files
Edit:
WinMerge can do this just perfectly
Thanx a lot wraithdu!
Reply #43
Yeah, I kinda realised after posting, that WinMerge has the ability to copy missing files both ways between the directories.  Well it's good to know how to do it both ways, especially if you want to batch the whole process.
Reply #44
With the recent release of FLAC 1.1.4, I'm sure a lot of people are having to deal with transcoding their old files. I personally find dbpoweramp R12 batch converter very useful for this purpose, as I too am a GUI kind of person. It can be set to mirror the old directory structure in the way you suggest. However, only the Reference edition has this feature. Also, since the FLAC codec for this edition is still at 1.1.3, you'll need to use the CLI codec to configure 1.1.4's FLAC.exe, so you'll need some familiarity with the command line ;-)
