Topic: Corrupted file - missing portions (Read 3144 times) previous topic - next topic
The developers stored all OGG files in one big archive, so I extracted the data between two magic words ("OggS") manually with a hex editor. The start point of the file isn't the problem but since I didn't know when exactly the file ends I think this could be the cause. I ran it through ogginfo and it gave me this:
New logical stream (#1, serial: 0000002a): type vorbis
Vorbis headers parsed for stream 1, information follows...
Version: 0
Vendor: Xiph.Org libVorbis I 20020717 (1.0)
Channels: 1
Rate: 32000
Nominal bitrate: 42,001000 kb/s
Upper bitrate not set
Lower bitrate not set
Warning: Hole in data found at approximate offset 13500 bytes. Corrupted ogg.
Warning: sequence number gap in stream 1. Got page 4 when expecting page 3. Indi
cates missing data.
Warning: Hole in data found at approximate offset 27000 bytes. Corrupted ogg.
Warning: Hole in data found at approximate offset 36000 bytes. Corrupted ogg.
Warning: Hole in data found at approximate offset 45000 bytes. Corrupted ogg.
Warning: Hole in data found at approximate offset 54000 bytes. Corrupted ogg.
Warning: Hole in data found at approximate offset 63000 bytes. Corrupted ogg.
Warning: Hole in data found at approximate offset 72000 bytes. Corrupted ogg.
Warning: Hole in data found at approximate offset 81000 bytes. Corrupted ogg.
Warning: Hole in data found at approximate offset 90000 bytes. Corrupted ogg.
Warning: Hole in data found at approximate offset 99000 bytes. Corrupted ogg.
Warning: Hole in data found at approximate offset 103500 bytes. Corrupted ogg.
Warning: Hole in data found at approximate offset 112500 bytes. Corrupted ogg.
Warning: Hole in data found at approximate offset 121500 bytes. Corrupted ogg.
Warning: Hole in data found at approximate offset 130500 bytes. Corrupted ogg.
Warning: Hole in data found at approximate offset 144000 bytes. Corrupted ogg.
Warning: Hole in data found at approximate offset 153000 bytes. Corrupted ogg.
Warning: Hole in data found at approximate offset 162000 bytes. Corrupted ogg.
Warning: Hole in data found at approximate offset 171000 bytes. Corrupted ogg.
Warning: Hole in data found at approximate offset 180000 bytes. Corrupted ogg.
Warning: Hole in data found at approximate offset 189000 bytes. Corrupted ogg.
Warning: Hole in data found at approximate offset 193500 bytes. Corrupted ogg.
Warning: Hole in data found at approximate offset 202500 bytes. Corrupted ogg.
Warning: Hole in data found at approximate offset 211500 bytes. Corrupted ogg.
Warning: Hole in data found at approximate offset 220500 bytes. Corrupted ogg.
Warning: Hole in data found at approximate offset 229500 bytes. Corrupted ogg.
Warning: Hole in data found at approximate offset 238500 bytes. Corrupted ogg.
Warning: Hole in data found at approximate offset 243000 bytes. Corrupted ogg.
Warning: EOS not set on stream 1
Vorbis stream 1:
        Total data length: 114753 bytes
        Playback length: 0m:47.606s
        Average bitrate: 19,283788 kb/s
