Topic: Can Someone Update .La (Read 6928 times) previous topic - next topic
Hi, i was wondering if anyone could update this if allowed? I happend to like this format for some reason. I got this info from the docs that came with La. If anyone could shed some light. Or if they can contact Michael about it.
Helping out
One of the reasons I created the API is the hope that someone may take over work on the plugins, in particular the foobar2000 plugin, as foobar2000 tends to change its API rather too frequently for my liking. Also, the foobar2000 plugin could probably do with some work. I never found much documentation telling me how to do it properly so I just did what works. If you're interested in working on this then please contact me.
I personally have little time or interest to develop new plugins or update the existing plugins. The time I have I would rather spend on the compression engine. So any help in the plugins department would be appreciated.
I tried to make it today. However, there is some problems with the API of La, I'll contact the author to fixed the problem.
Edit: The author hasn't replied me since two weeks ago.
I've created a new component for foobar2000 0.9 successfully, download it here.
You must have the package from the La official site installed to get this works, or just put la-core.dll in the foobar2000 directory.
wow, it's been sometime now. Thank you very much for your hard work to make this. I am just surprised i really no longer use LA, but i have a hundred or so files that i tested them on and it works like a charm. Thanks, and do you use LA as well? or did?  thanks for the port
I never use LA, I made this for fun only.  btw, I built this with new SDK and VS2008 today, the result thing doesn't work, though it could be built without any change of code.
JackieKu, thank you very much! It works fine with 1.1 too.
