Topic: MP3 Embedded Album Art (Read 16608 times) previous topic - next topic
Is there a program that can add mass album art to mp3's without having to do it track be track with "Mp3 Tag Tools"?
I just stumbled across the fact that my psp shows embedded album art, but the only way I can get the album art is to embed it each track at a time.
With the amount of music tracks I have that would take ages!
I have some tracks that have gone through WMP11 and have album art embedded but thats about 2 of my CD's
I can't get it to do the rest of them (I don't know why it did the first few anyway!?)
(I did a search and found nothing  )
Helium Music Manager ...maybe Godfather too, but I don't use it
dannyb37,
Do you have the mp3 files organized as albums and in separate album folders?
Do you already have the needed image files in the album folders?
If yes, how are the image files named?
Edit:
Do you have other image files in the same folders?
dannyb37,
Edit:
I have them organised as
"My Music"\Artist\Album\Artist - Track.mp3
I have a album cover in that folder but its hidden (WMP11 puts it there)
Edit: I'll give iTunes a shot, (I already have it installed, but don't use it!  )
EDIT:
Thanks for all your help, but I got SonicStage to do it!  But If you have any better suggestions, I would like to hear them!
OK, I have a similar issue--
I am using Windows Media Center (which of course uses WMP) to rip my hundreds of CDs (via the Sony 200 dvd/cd changer).
It works fine as long as it can find the album art.  MCE uses the thumbnail images in it's 10' interface.
But if it can't, I get a generic icon instead.  While I can use several programs (currently playing with MediaMonkey) to choose the correct cover art image from Amazon, I have no idea how to download / create the proper images for the folders, so everything shows up in MCE.
It embeds all the pics in the MP3s.
1.  Is there some program which allows you to save the album art to the folder as well as the MP3 and...
2.  Is there a program which can extract the album art from the MP3 into the folder?
Much obliged for the assistance.
Scott.....
Danny,
Check out MediaMonkey!
I'm lovin' this as an MP3 manager... it does everything I want.
And not only can you add artwork to a bunch of files in one move, it also.... wait for it.... gives you the option to embed the artwork into the ID3 tag!! Woo-bloody-hoo!
Love that.
That way, the artwork goes wherever the MP3 goes. Sweet.
Bruce.
www.audio2u.com
The home of quality podcasts
(including Sine Language, a weekly discussion on all things audio)
hi,
i tried mediamonkey it works fine but u have to click on every album.
is there a program that will do it automatically in batch mode.
all my images are called folder.jpg are in within the directory:
h:\Artist\album\
someone mentioned godfather but i read you have to use a script. I looked but every link i found for a script is http 404.
any1 have ne ideas?
You can use http://mp3tag.de/en/index.html
Load your files, select them, press Shift+Alt+5 and choose "Import cover from file"
Then just enter folder.jpg as format string and let it work.
thanks i'll try it when my new ipod arrives
Im having a similar problem.
In my "Shared Folder" there are various artists. I wanna hard embed album art into each mp3 file because adding a folder.jpg folder in the "My Shared Folder' does not work.
I'll second the vote for mp3tag. Using the above method you can tag your whole library in one step, it's very easy.
I generally allow WMP11 to download the album art for me, and then use mp3tag to embed the art in the files. This process allows the art to be displayed on my Samsung T9.
Will this program also allow a wildcard to represent the directory name in the format string? Each of my albums has a low-res (120x120) "folder.jpg," but also a higher-resolution cover with the same name as the directory (as in the example below).
    - M.
Beatles, The/(1967a) Sgt. Pepper's Lonely Hearts Club Band/
             01 Sgt. Peppers Lonely Hearts Club Band.mp3
             02 With a Little Help from My Friends.mp3
             03 Lucy In The Sky With Diamonds.mp3
             04 Getting Better.mp3
             05 Fixing a Hole.mp3
             06 She's Leaving Home.mp3
             07 Being for the Benefit of Mr Kite.mp3
             08 Within You Without You.mp3
             09 When I'm Sixty-Four.mp3
             10 Lovely Rita.mp3
             11 Good Morning, Good Morning.mp3
             12 Sgt Peppers Lonely Hearts Club Band (Reprise).mp3
             13 A Day in the Life.mp3
             14 run out groove.mp3
There are many placeholders available, like %_directory% for your case.
You must have organized the album art files and your MP3s in some decent directory structure. Or else, If you have tagged all your MP3s correctly, you can organize them into directories using MP3TagStudio.
Once you do that, use metamp3 along with the script in this thread.
