Topic: Home stereo display (Read 273204 times) previous topic - next topic
Home stereo display
Reply #375
Well mine does too but I was refering more to the need of one in the display, especially since the volume control indicater has memory issues and makes the volume control less responsive.
and yes that is with the latest cwb hooks
The volume indicator doesn't cause the high cpu usage,you can remove it ("Rating Mood Volume" section of the code) and you will see no difference at all.Again,turn off the callback notifications of cwb hooks.
Actually it does have in impact on memory but thats not what I'm saying. I said that with it in my code when I use my keyboard to adjust the volume the volume is not as responsive as when that section of the code is not in it
I think the simplest solution to this debate is if you do not like the volume display, simply remove it from the code.  I am in the process of releasing a substantially tweaked version of the 1.8.1 VIP which has been modified to meet my needs.  Russel's code is very clean, well organized, and clearly labeled so that it should not be that difficult for one to adjust it to meet one's needs.  If you are stuck and cannot figure out how to tweak a portion of his code to your liking, Russel and others are very responsive to such issues and simply post your problem here, and I am confident that it will be timely responded to with the assistance you request.  I indicated to Russel that I did not need the volume indicator in the new version b/c I use kernal streaming and therefore do not adjust foobar volume through the computer.  However, Russel decided that he wanted to have such a display, which clearly is his entitlement as the creator of this code. The volume indicator is easily removed from his code and can be replaced with whatever information one desires to display (on my moded version, I am playing around with displaying total tracks in the Queue in place of the volume display and/or hotness and have removed the buttons feature, decreasing rating code, track number display, and several other portions of Russel's code).  The beauty of foobar is you can customize it as you see fit to meet your needs.
Home stereo display
Reply #376
Yep,i agree.I think the best way for those who don't need certain features is to wait for an alternative version from Stuart.Maybe he will be so kind to pull an alternative version for V 1.9 too (if you ask him nicely).
Favourite artist:CD-R
Favourite album:700MB
Home stereo display
Reply #377
I'm not complaining as I mod it to suite my needs and taste anyways. I'm letting you know of some issues I've come across with it, thats all
Home stereo display
Reply #378
No problem at all, and I think constructive comments, like yours, benefit us all because they only improve the end result.  I just wanted to interject the rather obvious point that arguing about whether the display should or should not have certain information displayed does not advance anything and is really a personal issue which should be addressed by tweaking the code to a person's particular preferences.    I will release my version as soon as it is done (very soon).
Home stereo display
Reply #379
I havnb't tried out the latest version with the on screen editing of mood etc. But will it be possible to allow onscreen access to adjust the progress bar?
Home stereo display
Reply #380
Only when it will be possible to access main section commands via trackinfo mod buttons,I'm dying to get rid
of the scrollbar too.
Home stereo display
Reply #381
I´ve installed al the requested fonts, and i'm using Vista Inspirat theme config for the display, and i've updated all the necessary components,but i can't seem to discover how to fix the font type used so it doesn't look like this. Can you help me,plz?
Home stereo display
Reply #382
It's obviously that LCD fonts and Symbolix aren't installed on your system.Open charmap.exe and check that you have these fonts installed:LCD,LCDmono,LCD2,LCDmono2 and Symbolix.
Home stereo display
Reply #383
For some reason, I didn't have the LCD fonts installed. I've installed the LCD fonts and that did it! Thx Russell777
Home stereo display
Reply #384
here's mine...
i took some of Russell777's Code (thx man), modified it a bit and added some gfx... still working on it though.
(accidentally posted in 3rd Party Plugins - (fb2k) forum so im posting this here again... thx again Russell777)
Home stereo display
Reply #385
here's mine...
Amazing!Mind sharing it?
Home stereo display
Reply #386
here's mine...
Dito! Truly awesome.  Would love a copy of the code and the image.
Home stereo display
Reply #387
here's mine...
This brings many ideas to mind... Place some usable buttons in that sphere and you could have yourself a very small and almost skinned foobar.  Something like that with the inclusion of a Toaster-like component would be quite nice for day-to-day playback.
No mercy for the bandwidth impaired
Home stereo display
Reply #388
Well, when compared to Zetto's post, my contribution is, indeed, far less impressive.  But anyway, below is a screenshot and download link to my minor modifications to version 1.8.1 VIP.  Changes are detailed in the download, but generally removed volume display, the buttons, decreasing rating code, track number display, and added queue total, new quality indicator (same as 1.8 VIP) and alternative follow the cursor indicator.
Download
(Edit: Labeled relative quality indicator)
Home stereo display
Reply #389
Looking at the versions made by Zetto and Stuart60611 gave me an idea to release a
"Script development kit" (SDK) for home stereo panel,so that everyone could just easily take pieces of my code
and create their own home stereo panels with custom graphics,alignment,font sizes,backgrounds etc.
It will contain a variaty of txt files every of which containing some feature,like progressbar,verticalprogressbar,
playtime etc.The user will just take the pieces that he\she wants to use and put it inside their code.
I'm planning to release it on sunday,and i really want to see what you guys will come up with.Take care.
Home stereo display
Reply #390
that would be awesome for sure, Russell777. i highly appreciate your effort. respect !!
updated my version a little bit:
Home stereo display
Reply #391
It looks like you're one hell of a demon when it comes to gfx.I believe that if you share your config you'll get a lots of "thank you"s.
PS:Did you create the image yourself?
Home stereo display
Reply #392
re... ok here are the necessary files (images) for the setup:
http://www.szemke.de/TEMP/Zetto-Foo!.pics.7z
just extract the directory to your foobar install dir and thats it.
here's the code:
[codebox]
///Zetto's main Trackinfo-Mod window (thx to Russell777,
///for i have used pieces of his "Home Stereo Display" code -> GREAT WORK !)///
///my Page: www.szemke.de///
///dynamics///
$puts(fontColorInactive,$rgb(40,130,130))
$puts(fontColorActive,$rgb(0,255,255))
$puts(alt_font,georgia)
$puts(alt_font_size,9)
$puts(alt_font_options,italic)
$puts(alt_font_fix,-1)
$puts(symbolinfo,1)
$puts(scrollback,1)
$puts(windowAlbum,18)
$puts(windowTitle,60)
///bgImage///
$if(%isplaying%,$puts(tiPlayingNum,$add($mod(%_time_elapsed_seconds%,30),1))
$puts(count_path,myLayoutPics\tiPlaying$get(tiPlayingNum).png)
$imageabs(0,0,$get(count_path),),$imageabs(0,0,myLayoutPics\tiStopped.png,))
///in-/active colors///
$puts(fontColorAI,$get(fontColorInactive))
$if(%isplaying%,$puts(fontColorAI,$get(fontColorActive)))
///codec///
$alignabs(118,44,%_width%,%_height%,center,top)
$font(lcdmono2,10,,)
$get(fontColorAI)[%codec%]
///bitrate///
$alignabs(367,44,%_width%,%_height%,left,top)
$get(fontColorAI)
$if($stricmp($codec(),mp3),
$if($stricmp(%__extrainfo%,VBR),VBR,CBR),)
$char(32)['/' %__bitrate_dynamic%'kb']
///channels///
$alignabs(-78,64,%_width%,%_height%,right,top)
$get(fontColorAI)
$if(%__channels%,$ifgreater(%__channels%,2,%__channels%ch,$ifgreater(%__channels%,1,Stereo,Mono)),)$char(10)
///samplerate///
$alignabs(-13,64,%_width%,%_height%,right,top)
$get(fontColorAI)[%__samplerate% 'Hz']
///Rating Mood Volume///
$if(%rating%,$puts(rating,%rating%),
$puts(fix,$div($cwb_datediff(%cwb_systemdatetime%,%first_played%),
$get(decreaserange)))
$puts(rating,$sub($add(%play_count%,%play_counter%),$get(fix))))
$if($greater($get(rating),5),$puts(rating,5))
$if($greater(0,$get(rating)),$puts(rating,0))
$alignabs(319,$add($div(%_height%,5),54),%_width%,%_height%,,)
$font(wingdings,12,$get(font_options),250-250-250)
$get(fontColorActive)$repeat($char(171),$get(rating))
$get(fontColorInactive)$repeat($char(171),$sub(5,$get(rating)))
$alignabs(396,$add($div(%_height%,5),53),%_width%,%_height%,,)
$font(webdings,9,$get(font_options),250-250-250)
$get(fontColorActive)$repeat($char(89),%mood%)
$get(fontColorInactive)$repeat($char(89),$sub(3,%mood%))
$puts(volume,$substr($num(%cwb_volume%,4),2,4))
$font(webdings,9,$get(font_options),)
$alignabs(324,$add($div(%_height%,5),73),%_width%,%_height%,,)
$if(%isplaying%,$get(fontColorActive),$get(fontColorInactive))$char(88)$char(32)
$font(arial,10,bold$get(font_options),250-250-250)
$if($greater(1,$get(volume)),$puts(amp,12),
$if($greater(3,$get(volume)),$puts(amp,11),
$if($greater(6,$get(volume)),$puts(amp,10),
$if($greater(9,$get(volume)),$puts(amp,9),
$if($greater(13,$get(volume)),$puts(amp,8),
$if($greater(16,$get(volume)),$puts(amp,7),
$if($greater(21,$get(volume)),$puts(amp,6),
$if($greater(26,$get(volume)),$puts(amp,5),
$if($greater(33,$get(volume)),$puts(amp,4),
$if($greater(43,$get(volume)),$puts(amp,3),
$if($greater(58,$get(volume)),$puts(amp,2),
$puts(amp,1)
$if($stricmp(100,$get(volume)),$puts(amp,0))
$repeat($char(305),$get(amp))
$get(fontColorInactive)$repeat($char(305),$sub(12,$get(amp)))
$alignabs(392,$add($div(%_height%,5),76),%_width%,%_height%,,)
$font(7segment,8,$get(font_options),)$if(%isplaying%,$get(fontColorActive),$get(fontColorInactive)
)-$get(volume)Db
///date///
$alignabs(15,44,%_width%,%_height%,left,top)
$get(fontColorAI)[%date%]
///genre///
$alignabs(62,44,%_width%,%_height%,left,top)
$get(fontColorAI)[%genre%]
///album///
$alignabs(16,$add($div(%_height%,5),-57),%_width%,%_height%,left,middle)
$puts(title,
[%album%])
$if($get(symbolinfo),
$if($or($stricmp($substr($ascii($get(title)),2,2),?),
$stricmp($substr($ascii($get(title)),6,6),?)),$char(10)
$alignabs(21,$add($div(%_height%,5),55,$get(alt_font_fix)),%_width%,%_height%,,)
$font($get(alt_font),$get(alt_font_size),$get(alt_font_options)$get(font_options)
,250-250-250)$repeat($char(10),31),
$puts(title,
$lower($replace($upper($get(title)),-,$char(8208),&,+,À,a,Á,a,Â,a,Ã,a,Ä,ae,Å,a,
Æ,ae,Ç,c,È,e,É,e,Ê,e,Ë,e,Ì,i,Í,i,Î,i,Ï,i,Ò,o,Ó,o,Ô,o,Õ,o,Ö,oe,Ù,u,Ú,u,Û,u,Ü,ue,
ß,ss)))
$puts(alt_font_fix,0)
$font(lcdmono2,10,bold$get(font_options),250-250-250)$repeat($char(10),35)),
$get(font_options),250-250-250)$repeat($char(10),32))$get(fontColorAI)
$if($greater($len($get(title)),$get(windowAlbum)),
$if($stricmp($mod($len($get(title)),0),0),
$puts(title,$pad($get(title),$add($len($get(title)),1))),)
$puts(shift,$sub($len($get(title)),$get(windowAlbum)))
$if($get(scrollback),
$puts(mod,$mod(%_time_elapsed_seconds%,$add($mul($get(shift),2),2)))
$if($greater(3,$get(mod)),$substr($get(title),1,$get(windowAlbum)),
$puts(mod,$sub($get(mod),2))$puts(flag,$get(mod))
$if($greater($add($get(shift),1),$get(mod)),
$substr($get(title),$add(1,$get(mod)),$add($get(windowAlbum),$get(mod))),
$substr($get(title),$sub($mul($get(shift),2),$get(mod),-1),
$add($get(windowAlbum),$sub($mul($get(shift),2),$get(mod),0))))),
$puts(mod,$mod(%_time_elapsed_seconds%,$add($get(shift),2)))
$substr($get(title),$add(1,$get(mod)),$add($get(windowAlbum),$get(mod))))),
$alignabs(15,$add($div(%_height%,5),27,$get(alt_font_fix)),404,%_height%,left,top)
$get(fontColorAI)$get(title))
///time & tracknumber///
$alignabs(15,89,%_width%,%_height%,left,top)
$font(7 Segment,20,,)
$get(fontColorInactive)'88'
$get(fontColorAI)[%tracknumber%]
$alignabs(-338,89,%_width%,%_height%,right,top)
$get(fontColorInactive)'88:88'
$get(fontColorAI)[%playback_time%]
$alignabs(-300,90,%_width%,%_height%,right,top)
$font(7 Segment,10,,)
$get(fontColorAI)[%length%]
///progressbar///
$if(%isplaying%,$if3($strcmp(%playback_time_seconds%,0)
,,$drawrect(14,121,$muldiv(%playback_time_seconds%,$sub(%_width%,314),%length_seconds%),3,
pencolor-0-255-255 brushcolor-0-255-255 width-1)
///title///
$alignabs(0,$add($div(%_height%,5),34),%_width%,%_height%,center,middle)
$puts(title,
[%artist%][ '-' "%title%"])
$puts(title,
ß,ss)))
$if($greater($len($get(title)),$get(windowTitle)),
$if($stricmp($mod($len($get(title)),2),1),
$puts(shift,$sub($len($get(title)),$get(windowTitle)))
$if($greater(3,$get(mod)),$substr($get(title),1,$get(windowTitle)),
$substr($get(title),$add(1,$get(mod)),$add($get(windowTitle),$get(mod))),
$add($get(windowTitle),$sub($mul($get(shift),2),$get(mod),0))))),
$substr($get(title),$add(1,$get(mod)),$add($get(windowTitle),$get(mod))))),
$alignabs(0,-15,%_width%,%_height%,center,bottom)
///transpFgImage///
$imageabs(0,0,myLayoutPics\tiGlasses.png,)
Have Fun
Yes i did. maybe u want to visit MY PAGE for more stuff
Home stereo display
Reply #393
here's the code:
///dynamics///
$puts(symbolinfo,1)
$puts(scrollback,1)
///bgImage///
///codec///
///bitrate///
$get(fontColorAI)
///channels///
$get(fontColorAI)
$if(%__channels%,$ifgreater(%__channels%,2,%__channels%ch,$ifgreater(%__channels%,1,'
'Stereo,''Mono)),)$char(10)
///samplerate///
$puts(amp,1)
$font(7
)-$get(volume)Db
///date///
///genre///
///album///
$puts(title,
[%album%])
$puts(title,
ß,ss)))
///progressbar///
,,$drawrect(14,121,$muldiv(%playback_time_seconds%,$sub(%_width%,314),%length_seconds%),3,p
///title///
$puts(title,
$puts(title,
ß,ss)))
///transpFgImage///
Have Fun
Thank you,are the images from your site are yours too?They are truly amazing.Only one request:
in your post could you add "box" to the
 section ( ex: codebox) so it will be easier for ppl to copy your code?
Home stereo display
Reply #394
yes they are
Only one request:
done... sry first time posting code in a forum
Home stereo display
Reply #395
BEYOND AWESOME!
An idea would be making more colour schemes, but heck, I want to redesign my fooby for that now.
err... i'm not using windows any more ;)
Home stereo display
Reply #396
Whats the second progress bar underneath the time progress bar for??
Home stereo display
Reply #397
It's the "Relative format quality" indicator.It indicates the quality of playing item relatively to it's format.
For example mp3 320 kb/s will give you full bar as it's best quality available for mp3 format,but mpc 320 kb/s
will give you partly filled bar as it's not format's best quality.
Home stereo display
Reply #398
Home stereo display SDK is out (see the first post)
Well it took some time to turn the code into separate stand alone pieces,but finally it's here.
The script developing kit will allow you to create your own HSD with custom alignment,graphics etc.
It includes all the items used in current versions plus a couple from the past ones.It's the first version,
if i'll get some good feedback on this,i'll continue to develop it further.Have fun,and show the world
what are you capable of.
Home stereo display
Reply #399
I forgot to include this info in the SDK:in the end of "Globals" section insert this line:
$if(%isplaying%,,$puts(active,$get(back)))
