Topic: Track Info Panel with ability to change font (Read 732259 times) previous topic - next topic
Reply #425
Using $align() functions are completely optional however they can be very useful. By default everything just kind of flows like a normal old text editor and if all you want to do is display some basic playback stats this is fine.
However the image functions require absolute positioning, so if you start integrating images and text it's only a matter of time before you start wanting to $alignabs()'ing some text to make sure it flows properly with your images.
$alignabs() functions become rather powerful when you combine them with %_width% and %_height% because then you can have your text automatically position itself reletive to the size of the panel. This lets you use the same code for both full screen and windowed foobar layouts without having to go back and adjust the code.
$button(10,10,0,0,0,0,icons\png\mp3.png,,,)
$imageabs(20,20,icons\png\mp3.png,)
This is interesting. I tried your code and it appears to work but not in the way I expected:
Why is the first $button() image overlayed on to of the second $imageabs() function? I expected the opposite to be true given the order in which the code is written. I even went back and commented out each line to ensure I was seeing what I thought I was seeing.
so... 1) is maybe your second image being hidden under the first 2) can anyone explain why $buttion() is overlayed on top of $imageabs()?
Reply #426
My guess would be so that button clicks can be 'understood', if you like. If the button was drawn under the image, then I'm guessing there would be problems with clicking on them..?
Reply #427
I also find it odd that the transparency of the $button() isnt allowing the $imageabs() to show through (notice the grey "shadow")
EDIT: If I rearrange the lines of code so that the "bottom" image is drawn before the "top" image, the transparency works fine. The shadow effect must have something to do with how the $button() forces it's way to the top layer.
Reply #428
I want to display the current playlist number of the track playing and the total tracks on the given playlist in trackinfo mod.  I tried %list_index%/%list_total% and %playlist_number%/%playlist_total%, but this component does not seem to recognize these fields.  What are the fields to do this?
Reply #429
Thanks for your reply Yotsuya!
well thanks, I was actually clever enough to check that  ... I can easily push around the button changing the x and y settings, the image just doesn't show up, no matter where (x,y) and no matter if the button is in the code or no button at all. So: is not a matter of (x,y) and no interference with the button.
Anyone any other idea why the image doesn't show up? (see my last post)
Once the image shoes up here, I will try and see if I can help with that
Pretty sure you are right there. If I'd be faster to understand the syntax I would play with that already. But already having a problem with the image-function I prefer to go step by step and not mess up things too quick
Reply #430
I know of no way to pull the playlist index for the currently playing song from a context outside of the playlist, however I believe you should be able to pull the total number of items in the currently playing playlist with %cwb_playinglist_count%. This requires you install foo_cwb_hooks. Maybe you should consider stopping by the cwb_hooks thread and request something like a %cwb_playinglist_index%.
Reply #431
Thanks, and I so posted.  Also, although I read in the change log that global variables were implemented, I am having a strange problem with accessing them.  I tried to access hotness, and although the panel recognizes the variable, it is showing strange values for the variable.  Is this a bug or is there some special way to access global variables?
Reply #432
I'd like to display %path% but if it's too long and doesn't have any spaces, it doesn't know how to wrap it. It also doesn't display anything after that. Is this a bug?
Reply #433
here's mine...
i took some of Russell777's Code (thx man), modified it a bit and added some gfx... still working on it though.
Reply #434
Woah. Looks kind of neat.
Reply #435
Is there any way to scrolling text?
I want to use this panel to show lyrics, but with a background image.
Reply #436
the $button() is not work if without foo_run.dll
who can tell me how to use the function
Reply #437
Having a few problems getting text on my panel to span multiple lines without the colour changing, kinda frustrating. Here is a screenshot: http://img137.imageshack.us/img137/8477/tr...nfoprob1rx3.jpg
Notice how the 2nd line of the track field has reverted to blue. I've tried changing the default colour, as well as placing several changes to FFFFFF in many places but it still doesn't stay that correct colour. It's strange because the artist field has the same
The code in question (I'll post the whole panel if anybody wants to see it):
$if(%tracknumber%,DA9363'['FFFFFF%tracknumber%DA9363']' )
FFFFFF$if(%title%,$replace(%title%,'(','DA9363('FFFFFF,')',DA9363')'FFFFFF),
$replace(%filename_ext%,'(','DA9363('FFFFFF,')',DA9363')'FFFFFF))$char(10)$char(10)
$if(%artist%,DA9363Artist: FFFFFF$replace(%artist%,
$if(%album%,DA9363Album: FFFFFF$replace(%album%,
'(','DA9363('FFFFFF,')',DA9363')'FFFFFF)FFFFFF
$if(%date%,DA9363'['FFFFFF%date%DA9363']'))$char(10)
DA9363Total plays: FFFFFF%play_count%$char(10)$char(10)
EDIT: Wierd, removing the date tag from the file (therefor not displaying it) fixes it. Looks like I've already got a solution (stick the date in a new $if(%album%).
Reply #438
A small suggestion for a bitrate indicator:
The Code (If interested):
$puts(xcoord,10)
$puts(ycoord,178)
$puts(color,250-250-250)
$puts(bita,$div($mul($add(%bitrate%,-64),30),192))
$ifgreater($get(bita),30,$puts(bita,30),)
$ifgreater(0,$get(bita),$puts(bita,0),)
$alignabs($add($get(xcoord),5),$add($get(ycoord),-5),600,50,,)
$font(Arial,10,bold,$get(color))
$repeat(.,$get(bita))
$font(,10,,)
$drawrect($add($get(xcoord),6),$add($get(ycoord),10),117,1,brushcolor-$get(color) pencolor-null)
$alignabs($add($get(xcoord),5),$add($get(ycoord),4),600,50,,)י
$alignabs($add($get(xcoord),44),$add($get(ycoord),4),600,50,,)י
$alignabs($add($get(xcoord),83),$add($get(ycoord),4),600,50,,)י
$alignabs($add($get(xcoord),122),$add($get(ycoord),4),600,50,,)י
$font(,8,,)
$alignabs($get(xcoord),$add($get(ycoord),12),600,50,,)64
$alignabs($add($get(xcoord),36),$add($get(ycoord),12),600,50,,)128
$alignabs($add($get(xcoord),75),$add($get(ycoord),12),600,50,,)192
$alignabs($add($get(xcoord),114),$add($get(ycoord),12),600,50,,)256  kb/s
$alignabs($add($get(xcoord),131),$get(ycoord),200,20,,)bitrate
cwb_hooks plugin is needed.
Reply #441
Hey unart that's a nice idea for a bitrate indicator. I took your idea and ran with it a bit:
// -- Bitrate Bar -- //
$puts(bitratebar.width,200)
$puts(bitratebar.offsetx,10)
$puts(bitratebar.offsety,20)
$puts(bitratebar.text,26)
// Frame
$drawrect($get(bitratebar.offsetx),$get(bitratebar.offsety),$get(bitratebar.width),1,pencolor-233-233-233)
$drawrect($get(bitratebar.offsetx),$sub($get(bitratebar.offsety),6),1,12,pencolor-233-233-233)
$drawrect($add($get(bitratebar.offsetx),$get(bitratebar.width)),$sub($get(bitratebar.offsety),6),1,12,pencolor-233-233-233)
// Tick Marks
$drawrect($add($get(bitratebar.offsetx),$muldiv(11.11,$get(bitratebar.width),100)),$get(bitratebar.offsety),1,6,pencolor-233-233-233)
$drawrect($add($get(bitratebar.offsetx),$muldiv(22.22,$get(bitratebar.width),100)),$get(bitratebar.offsety),1,6,pencolor-233-233-233)
$drawrect($add($get(bitratebar.offsetx),$muldiv(33.33,$get(bitratebar.width),100)),$get(bitratebar.offsety),1,6,pencolor-233-233-233)
$drawrect($add($get(bitratebar.offsetx),$muldiv(44.44,$get(bitratebar.width),100)),$get(bitratebar.offsety),1,6,pencolor-233-233-233)
$drawrect($add($get(bitratebar.offsetx),$muldiv(55.55,$get(bitratebar.width),100)),$get(bitratebar.offsety),1,6,pencolor-233-233-233)
$drawrect($add($get(bitratebar.offsetx),$muldiv(77.77,$get(bitratebar.width),100)),$get(bitratebar.offsety),1,6,pencolor-233-233-233)
// Labels
$font(tahoma,7,,233-233-233)
$alignabs($sub($get(bitratebar.offsetx),4),$get(bitratebar.text),%_width%,%_height%,,)32
$alignabs($sub($add($get(bitratebar.width),$get(bitratebar.offsetx)),8),$get(bitratebar.text),%_width%,%_height%,,)320
$alignabs($add($get(bitratebar.offsetx),$muldiv(11.11,$get(bitratebar.width),100),-6),$get(bitratebar.text),%_width%,%_height%,,)64
$alignabs($add($get(bitratebar.offsetx),$muldiv(22.22,$get(bitratebar.width),100),-6),$get(bitratebar.text),%_width%,%_height%,,)96
$alignabs($add($get(bitratebar.offsetx),$muldiv(33.33,$get(bitratebar.width),100),-6),$get(bitratebar.text),%_width%,%_height%,,)128
$alignabs($add($get(bitratebar.offsetx),$muldiv(44.44,$get(bitratebar.width),100),-6),$get(bitratebar.text),%_width%,%_height%,,)160
$alignabs($add($get(bitratebar.offsetx),$muldiv(55.55,$get(bitratebar.width),100),-6),$get(bitratebar.text),%_width%,%_height%,,)192
$alignabs($add($get(bitratebar.offsetx),$muldiv(77.77,$get(bitratebar.width),100),-6),$get(bitratebar.text),%_width%,%_height%,,)256
// Bar
$if(%isplaying%,
$drawrect($add($get(bitratebar.offsetx),1),$sub($get(bitratebar.offsety),6),$sub($get(bitratebar.width),1),6,brushcolor-$ifgreater(%bitrate%,320,166-202-240,$ifgreater(%bitrate%,32,10-36-106,128-128-128)) pencolor-null)
$ifgreater(%bitrate%,32,$ifgreater(%bitrate%,320,,
$drawrect($add($get(bitratebar.offsetx),1),$sub($get(bitratebar.offsety),6),$sub($muldiv($muldiv(100,$sub(%bitrate%,32),288),$get(bitratebar.width),100),1),6,brushcolor-0-128-255 pencolor-null)
The bar will change colors if the bitrate falls out of range of the indicator and is rather easy to resize. I marked most commonly used bitrates.
EDIT: Code Optimizations
Reply #442
Is there any way to get playback buttons to work without using foo_run? I have some text and I want to overlay an invisible button to do what the text says.
I've used this code to position the button over the 'Play' text (and yes it is positioned correctly as it works when I use foo_run), but it doesn't want to work.
$button(0,0,$get(start_pos),12,$get(play_w),20,,,Play,)
</signature>
Reply #444
I posted this b/4, but I still am not sure of the answer.  The changelog indicates that global variables work, but when I access them I get strange values.  Does anyone know if this is a bug, or is there a special method by which one must access global variables?
Reply #445
globals should work here (not yet in single column playlist). what strange values are you getting?
updated- new $button2 and support for main menu commands.
an example of how to use $button2:
$if(%isplaying%,
$if(%ispaused%,
$button2(0,0,0,0,100,16,
'resume',
'$font(,,glow-0-0-0,255-255-255)resume',
play,)
'pause',
'$font(,,glow-0-0-0,255-255-255)pause',
pause,)
'play',
'$font(,,glow-0-0-0,255-255-255)play',
play,)
Reply #446
I am trying to access the %hotness% variable defined in my global variables.  The value for hotness is showing correctly in my playlist as a number from 1-100 but when I access it in track info mod I am getting values like .0789, etc.  All values less than 1.
Reply #447
does it work in the original trackinfo?
