Topic: Track Info Panel with ability to change font (Read 730595 times) previous topic - next topic
Reply #325
Hi
Thanks to the new functions of foo_cwb_hooks i wanted to try to do a new kind of progress bar
A sort of scrolling timeline.
$puts(x,$muldiv(%playback_time_seconds%,%_width%,%length_seconds%))
// NOW PLAYING ////////////////////////////////////////////
$drawrect($sub(0,$get(x)),,%_width%,%_height%,pencolor-112-112-128 brushcolor-5-0-5 width-5)
$puts(b25,$muldiv(%_width%,25,100))
$drawrect($sub($get(b25),$get(x)),0,2,$muldiv(%_height%,20,100),pencolor-112-112-128)
$puts(b50,$muldiv(%_width%,50,100))
$drawrect($sub($get(b50),$get(x)),0,2,$muldiv(%_height%,30,100),pencolor-112-112-128)
$puts(b75,$muldiv(%_width%,75,100))
$drawrect($sub($get(b75),$get(x)),0,2,$muldiv(%_height%,40,100),pencolor-112-112-128)
$alignabs($sub(0,$get(x),10),5,%_width%,%_height%,right,top)
$font(Arial,16,bold,192-144-255)
[%playback_time_remaining%]
$alignabs($sub(0,$get(x),10),0,%_width%,%_height%,right,middle)
$font(Arial,12,bold,64-0-128)
['['%date%'] '][%album%][' [cd'%disc%'] ']
$alignabs($sub(0,$get(x),10),-5,%_width%,%_height%,right,bottom)
[%artist%]
$alignabs(10,0,%_width%,%_height%,left,middle)
$font(Arial,18,bold glow-128-0-255 glowblur-5,16-0-32)
[%title%]
// NEXT SONG ///////////////////////////////////////////////
$drawrect($sub(%_width%,$get(x)),,%_width%,%_height%,pencolor-112-112-128 brushcolor-64-64-64 width-5)
$font(Arial,46,bold shadow,64-64-64)
$alignabs($add($sub(%_width%,$get(x)),10),0,%_width%,%_height%,left,middle)
'COMING NeXT'
$font(Arial,16,bold shadow,112-112-112)
$puts(th,$calcheight(%cwb_next_artist%))
$alignabs($add($sub(%_width%,$get(x)),10),$sub(%_height%,$get(th),5),$sub($max($get(x),20),20),$get(th),right,bottom)
[%cwb_next_artist%]
$font(Arial,18,bold shadow,128-128-128)
[%cwb_next_title%]
Requirements:
- Vertical & Horizontal padding : 0
- Minimum height: 75
- Update every second: checked
- foo_cwb_hooks.dll
Works only for default playback order
Reply #326
Very nice! If only the onscreen programming guide on my cable box did something like this :)
Reply #328
ok i get it working as a progress bar but the code has 100 lines... any chance to get it shorter?
Reply #329
Other Image for same stuff, you can find here
Looks like so:
((((( Strictly4me )))))
Reply #330
Sihkih:
Is this the sort of thing you are looking for?
$imageabs($sub(%_width%,102),$sub(%_height%,102),images\progress.circle\count$muldiv($muldiv(100,%playback_time_seconds%,%length_seconds%),40,100).png,)
*note: copy count40.png to count0.png
Reply #331
terrestrial: any plans on adding the $imageabs2() function to this component like you did with singlecolumnsplaylist?
I would like to know this, too.
Reply #332
Sihkih:
yes thank you
Reply #333
Yotsuya:Thanks
Edite: I found I can keep both but now I have installed all the components but can't see the
new foo_uie_trackinfo_mod in the Columns UI Panel with the old trackinfo I only see the old one not the new one.
I have .net and c++ installed and all the fonts and what not installed why Can't I see the foo_uie_trackinfo_mod?
Reply #334
It would be excellent if .jpg were supported, and I'm sure this was probably already suggested...
That would do a good job of eliminating my need for an album art panel.
Great job on this. I'm definitely looking forward to the switch in $imageabs to $imageabs2. Keep it up.
Reply #335
$imageabs2 supports .jpg files, so it's being requested
Reply #336
xchaser: as long as you are using a recent version of foo_uie_trackinfo_mod.dll, the two will coexist peacefully and maintain their own settings.
Chase: foo_uie_single_column_playlist.dll supports .jpg in $imageabs2(), hopefully terrestrial will bring the same functionality to this component.
Reply #337
updated.
here is some sample code for ratings:
$puts(rating,$if(%rating%,%rating%,0))
$button(0,0,0,0,25,25,images\$get(rating).png,images\1.png,Set Rating = 1,)
$button(0,0,25,0,25,25,images\$get(rating).png,images\2.png,Set Rating = 2,)
$button(0,0,50,0,25,25,images\$get(rating).png,images\3.png,Set Rating = 3,)
$button(0,0,75,0,25,25,images\$get(rating).png,images\4.png,Set Rating = 4,)
$button(0,0,100,0,25,25,images\$get(rating).png,images\5.png,Set Rating = 5,)
Reply #338
+ added support for cwb_hooks callback notifications
+ buttons - $button(dstX,dstY,x,y,w,h,image,hover image,command,options)
Yay! Buttons! Thanks for your continued dedication to these wonderful components terrestrial!
Reply #340
Nice update
I see that $imageabs2 has also been added..
Maybe you should note in the changelog about the updates that have come from single_column, not really necessary, but could be helpful for some?
Reply #341
I started playing around with $button() but all my images appear to be experiencing some cropping on the bottom and right edges. Is anyone else experiencing this?
parameters 3-6 don't appear to be having any effect at all.
Reply #342
Yea, I was just testing, and the images seem to be cropped to a limited size.
Parameters 3-6 are for the 'hotspot', i.e. the point where the button can be clicked, and the x and y values are relative to the top-left of the image used..
Edit: Thinking about it, I don't even know if the images need to be drawn by the button command, surely you could just draw an image with imageabs/imageabs2, and then draw the button over the top of it, setting the 'hotspot' to same x/y/w/h as the drawn image and it would give the desired effect..?
Reply #343
I don't seem to get any cropping here... can you post the code which you're using.
Reply #344
Yea, this was the code:
$button(0,0,0,0,16,16,C:\Program Files\foobar2000\images\silk\zoom.bmp,C:\Program Files\foobar2000\images\silk\folder.bmp,Set Rating = 5,)
The images are regular 16x16 24bit bitmaps. Also, they seem to be a slight bit zoomed in aswell as cropped..
I'm guessing it was the bitamps, it seems to work with png files..
Reply #345
I havnt tackled the command part yet, but I was trying to start with a basic button. I'm experiencing cropping on the bottom and right sides.. and I think I need to work on the hotspot bit.
$if(%isplaying%,
$button(10,10,10,35,25,15,images\button.pause.png,images\hover.pause.png,Pause,)
$button(10,10,10,35,25,15,images\button.play.png,images\hover.play.png,Play,)
images used:
example of cropping:
O.o is there some sort of resizing going on?
Reply #346
That's exactly what I was getting when using the bitmap files, but I changed to 2 png files (different sized), and they displayed fine..
Strange..
Reply #347
ah.
its the dpi on the images... it should be equal to the dpi windows is running at or gdi+ does some scaling. windows normal dpi is 96. or I think you can remove the dpi info form the png altogether, and you won't get scaling.
Reply #348
1) How would one go about removing or modifying the dpi settings of the png from photoshop or irfanview? (I've never done that before)
2) Can you give an example of how to access a "command" from regular foobar main menu commands.. or is it limited to scripts?
Reply #349
1) I don't have photoshop installed, but I'm pretty sure it has a setting. It should be something like image attributes...
2) right now its limited to items from the context menu.
edit: I went ahead and uploaded a new version which ignores the dpi in the images.
and you can use this code
$if(%isplaying%,
$button(10,10,0,0,0,0,images\button.pause.png,images\hover.pause.png,Pause,)
$button(10,10,0,0,0,0,images\button.play.png,images\hover.play.png,Play,)
(although the buttons don't do anything )
