Win2k or XP ?
Reply #20 – 2006-07-08 05:49:36
XP Pro is my suggestion. XP over 2k as the reasons for 2k are easily done away with in XP by a couple of right clicks. I have always removed WMP and MSN Messenger by going to the control panel, clicking on add/remove programs than clicking on the tab for Windows Components. Take the checkmark out of what I don't want, click next and its removed. No worries, no hassles, no voodoo required. Than again some people may not know about that existing and go for the harder route. Don't like the XP Themes (besides using Windowblinds, etc.), you can disable them by right clicking on the desktop, clicking on properties, going to the appearance tab in the Display Properties and selecting the Windows Classic theme...too easy. To further disable them, you can go to Control Panel and go to Services, go to the Windows Theme service and disable it. Done. Check for Slyck's Windows Guide or something akin to that and you can learn how to disable a slew of services that you don't or won't use.' date='Jul 7 2006, 21:53' post='409873'] Also, you might want to get the KLMega codec pack, at www.codecguide.com Too bloated for my recommendation...a user just needs a Codec pack with all the stuff to get the job done and nothing more. I recommend the CCCP Pack over K-Lite or K-Mega. any day. http://cccp-project.net/ K Packs tend to stick in several things to handle the same thing or sticking in three or four codecs to handle something instead of one. For Vid Players, I recommend Zoom Player (as you can adjust the screen and set presets with those adjustments and it works on my HDTV Out) or Gabest's Media Player Classic. Both players come with the CCCP Pack for Playback. Gom Player or Video Lan Player (VLC) is a suggestion if you can't install a codec pack...that is the only reason in my opinion. - Gow
