Topic: Batch m3u playlist creation for all folders (Read 19819 times) previous topic - next topic
I've been trying to find an easy way to do this, but I can't seem to find exactly what I need. I just want a simple way to:
  • go through all my folders recursively
  • for each folder with mp3s and oggs, making an m3u for each
  • have the m3u in the actual folder, not the root folder
  • name the m3u just like its containing folder.
Any help is appreciated.
This script should sort you out:
Const ForReading = 1, ForWriting = 2, ForAppending = 8
delete = false
set args = WScript.Arguments
if args.Count > 0 then
    if LCase(args(0)) = "-d" then
        delete = true
    end if
end if
set fso = createobject("scripting.filesystemobject")
wscript.echo WriteM3u(fso.GetAbsolutePathName("."), delete) & " files written"
function WriteM3u(path, delete)
    dim count
    set fdr = fso.GetFolder(path)
    if fdr.SubFolders.Count = 0 then
        m3u = path & "\" & fdr.name & ".m3u"
        if fso.FileExists(m3u) then
            if delete then
                wscript.echo "... deleting existing file"
                fso.DeleteFile m3u
            else
                wscript.echo "... renaming existing file"
                fso.MoveFile m3u, m3u & ".old"
            end if
        end if
        wscript.echo "... writing """ & fdr.name & ".m3u"""
        set m3ufile = fso.OpenTextFile(m3u, ForWriting, True)
        for each f in fdr.Files
            if right(f.Name, 3) = "mp3" or right(f.Name, 3) = "ogg" then
               m3ufile.WriteLine(f.Name)
            end if
        next
        m3ufile.Close
        count = 1
    else
        count = 0
        for each subfolder in fdr.subfolders
            wscript.echo "Searching """ & subfolder.path & """"
            count = count + WriteM3u(subfolder.path, delete)
        next
    end if
    WriteM3u = count
end function
Just save it to "WriteM3u.vbs" and stick it in the root directory of your mp3 and ogg files. To run, type:
cscript WriteM3u.vbs
By default it will rename any existing m3u files it finds. If you would rather delete them, just add "-d" to the end of the command-line, i.e.
cscript WriteM3u.vbs -d
-Paul
TAG can also do this from the command line. I use Speek's tag frontend, as the number of switches can be quite intimidating.
Thank you Paul, this is a nice and useful script
Yeah, thanks, it's awesome. If you wrote it yourself, maybe you could help me make one modification to it? It doesn't work right for albums with multiple CDs, because my folder structure for them looks like this:
Foldername\Disc 1\
Foldername\Disc 2\
Right now the script writes:
Foldername\Disc 1\Disc 1.m3u
Foldername\Disc 2\Disc 2.m3u
Is there any way to make it write (ideal):
Foldername\Disc 1\Foldername (Disc 1).m3u
Foldername\Disc 2\Foldername (Disc 2).m3u
or:
Foldername\Foldername (Disc 1).m3u
Foldername\Foldername (Disc 2).m3u
or even:
Foldername\Foldername.m3u (with files from both folders)
This would make the script supremely useful for me, hope you can do it
Foldername\Disc 1\
Foldername\Disc 2\
No problem zambaretzu. Try this:
delete = false
        delete = true
    end if
end if
    dim count
        if len(fdr.Name) = 6 and left(fdr.Name, 5) = "Disc " then
            m3uName = fdr.ParentFolder.Name & " (" & fdr.Name & ").m3u"
        else
            m3uName = fdr.Name & ".m3u"
        end if
        m3u = path & "\" & m3uName
            if delete then
                fso.DeleteFile m3u
            else
            end if
        end if
        wscript.echo "... writing """ & m3uName & """"
        set m3uFile = fso.OpenTextFile(m3u, ForWriting, True)
               m3uFile.WriteLine(f.Name)
            end if
        next
        m3uFile.Close
        count = 1
    else
        count = 0
        for each subFolder in fdr.SubFolders
            wscript.echo "Searching """ & subFolder.Path & """"
            count = count + WriteM3u(subFolder.path, delete)
        next
    end if
    WriteM3u = count
end function
Thanks a lot masterofimages.
There's still a small issue: for some albums, I have artwork, stored under \Foldername\art\. The script writes an empty \Foldername\art\art.m3u but no \Foldername\Foldername.m3u like it should.
So it does  And then there was... version 3 - with added comments for extra juicyness!
' Parse command-line arguments
delete = false
        delete = true
    end if
end if
' Write m3u files for current directory tree
set fso = CreateObject("Scripting.FileSystemObject")
' Recursive function to write m3u files for a given path
    count = 0
    ' Write m3u file for each subfolder
    if fdr.SubFolders.Count > 0 then
        next
    end if
    ' If no files found in subfolders, write m3u file for this folder
    if count = 0 then
        wscript.echo "Scanning """ & fdr.Path & """"
        ' Build list of mp3/ogg files
        mp3List = ""
               mp3List = mp3List & f.Name & VBCrLf
            end if
        next
        ' If any files found, write m3u file
        if mp3List <> "" then
            ' Multi-disc folder handling
            else
            end if
            ' Existing m3u file handling
                if delete then
                    fso.DeleteFile m3u
                else
                end if
            end if
            ' Write new m3u file
            m3uFile.Write(mp3List)
            m3uFile.Close
            count = 1
        else
            wscript.echo "... no mp3/ogg files found"
        end if
    end if
    ' Return m3u file count
    WriteM3u = count
end function
Thank you, thank you!
Thanks for the great script!! Is it possible to make it name the playlists Artist - Album.m3u using the name of the album's containing folder?
I had been looking for an automated way to create folder based  playlists for over 4 years. Today I got lucky and came across this thread. The script kindly shared by masterofimages worked beautifully and solved my problem.
Thank you so much.
It would be perfect if the files were order by name.
This script produce a caual (not ordered) list of mp3 files inside the folders, producing an inconsistent playlist.
I would like to add my thanks to masterofimages
Here's a variation of their code that:
  • generates a playlist for a folder containing audio files where those folders also have subfolders that contain audio files. The original script only generates the playlist for the deepest folder (that had no further subfolders). I've simply commented out the if count statement and endif for this aim.
  • indents the log output according to depth of the folder
  • searches for flac audio files too (m3u playlists can be used with these file too)
' credits:
' http://www.hydrogenaud.io/forums/index.php?showtopic=46167
' http://www.hydrogenaud.io/forums/index.php?showtopic=46167&st=0&p=408550&#entry408550
delete = false
        delete = true
    end if
end if
wscript.echo WriteM3u(fso.GetAbsolutePathName("."), delete, 0) & " files written"
function WriteM3u(path, delete, depth)
    wscript.echo Space(depth*2) & "WriteM3u ( path = """ & path & """" & " delete = " & delete & ")"
    count = 0
            depth = depth + 1
            count = count + WriteM3u(subFolder.path, delete, depth)
            depth = depth - 1
        next
    end if
   ' if count = 0 then
        wscript.echo Space(depth*2) & "Scanning """ & fdr.Path & """"
        mp3List = ""
            if right(f.Name, 3) = "mp3" or right(f.Name, 3) = "ogg" or right(f.Name, 4) = "flac" then
            end if
        next
            else
            end if
                if delete then
                    wscript.echo Space(depth*2) & "  ... deleting existing file"
                    fso.DeleteFile m3u
                else
                    wscript.echo Space(depth*2) & "  ... renaming existing file"
                end if
            end if
            wscript.echo Space(depth*2) & "  ... writing """ & m3uName & """"
            m3uFile.Close
            count = 1
        else
            wscript.echo Space(depth*2) & "  ... no mp3/ogg files found"
        end if
    'else
    '    wscript.echo Space(depth*2) & "files found in subfolders"
   ' end if
    WriteM3u = count
end function
Found this nice script, but missed the sorting of dirs. So I included it (and created an account for this site, which annoyingly took me somewhat longer).
Furthermore I suppressed all the requesters for each subdir (I do want to sort some hundred dirs!). You can reactivate them by the verbose flag (-v) in the command line. Or just change "shutup = false" at the beginning of the script.
Be aware I used the last script, but didn't check much. There are some funny commented lines...
Here comes the code:
' credits:
option explicit
' Set shutup = false if you really want to torture your mousebutton
shutup = true
delete = false
        delete = true
    end if
    if LCase(args(0)) = "-v" then
        shutup = false
    end if
    end if
set dirsort = CreateObject("System.Collections.ArrayList")
    if not shutup then
    end if
    count = 0
            depth = depth + 1
            depth = depth - 1
        next
    end if
   ' if count = 0 then
        if not shutup then
        end if
        ' Build list of mp3/ogg/flac files
        ' 1st: create array
                dirsort.Add f.Name
            end if
        next
        ' 2nd: sort array
        dirsort.Sort()
        ' 3rd: generate mp3list:
        mp3List = ""
        for each f in dirsort
            mp3List = mp3List & f & VBCrLf
        next
        ' 4th: prepare next list (empty this array)
        dirsort.clear
            else
            end if
                if delete then
                    if not shutup then
                    end if
                    fso.DeleteFile m3u
                else
                    if not shutup then
                    end if
                end if
            end if
'            wscript.echo Space(depth*2) & "  ... writing """ & m3uName & """"
            m3uFile.Close
            count = 1
        else
        end if
    'else
   ' end if
    WriteM3u = count
end function
Some days later I didn't find an edit button any more... so here comes a new version which should work better.
(I did include a "option explicit" and didn't check it properly as I was running an old version... sigh).
Improved the flag parsing and added a "prefix" constant for naming of the m3us if someone is interested.
' credits:
option explicit
Const PreFix = ""  ' Set this string if you want your playlists with a given prefix (like "- classical - ")
dim shutup, delete, args, argc, fso, dirsort
shutup = true
delete = false
for argc = 0 to args.Count-1
    if LCase(args(argc)) = "-d" then
        delete = true
    end if
    if LCase(args(a)) = "-v" then
        shutup = false
    end if
next
wscript.echo WriteM3u(fso.GetAbsolutePathName("."), 0) & " files written"
function WriteM3u(path, depth)
dim mp3List, count, fdr, subFolder, f, m3u, m3uName, m3uFile
    if not shutup then
        wscript.echo Space(depth*2) & "Working in path = """ & path & """" & " delete = " & delete
    end if
    count = 0
            ' Recurse into subfolders
            count = count + WriteM3u(subFolder.path, depth + 1)
        next
    end if
    if count = 0 then
        if not shutup then
        end if
        ' 1st: create array
            if lcase(right(f.Name, 3)) = "mp3" or lcase(right(f.Name, 3)) = "ogg" or lcase(right(f.Name, 4)) = "flac" then
                dirsort.Add f.Name
            end if
        next
        ' 2nd: sort array
        dirsort.Sort()
        mp3List = ""
        next
        dirsort.clear
                m3uName = PreFix & fdr.ParentFolder.Name & " (" & fdr.Name & ").m3u"
            else
                m3uName = PreFix & fdr.Name & ".m3u"
            end if
                if delete then
                    if not shutup then
                    end if
                    fso.DeleteFile m3u
                else
                    if not shutup then
                    end if
                end if
            end if
            if not shutup then
            end if
            m3uFile.Close
            count = 1
        else
        end if
    else
        if not shutup then
        end if
    end if
    WriteM3u = count
end function
