Topic: 256 vs 320 (Read 5870 times) previous topic - next topic
256 vs 320
Hi all!
I just wanted to know why I should encode at 320 instead of 256 (which is cd quality)? Any good arguments? I just wanna know any good arguments so I can decide =)
cyaz
256 vs 320
Why do you think 256kbps is CD-quality? It's not (you probably got that idea from r3mix.net?). There are many cases  (mostly transients/attacks) when MP3 is not transparent even at 320kbps.
There are even more cases when there's audible quality increase from 256->320kbps...
Juha Laaksonheimo
256 vs 320
mp3 is not subband coder - so
if you're coding on bitrates over than 200
you're not have quality much higher.
If you want to lissen realy fine
quality sound - use MPC (MP+)
format.
If mp3 format so impotent for you
use -abr 200
256 vs 320
I don't quite agree with this. MP3's quality does increase pretty nicely still from 200->320kbps. Another thing is, that it can't reach as high quality as MPC, but MP3's quality does scale at high bitrates.
Juha Laaksonheimo
256 vs 320
ok, ill take a look at MPC, im mostly concerned with quality, even though my current speakers/soundcard/ears (hehe) can't hear any difference between a 128 kbit or a 320 kbit mp3 =)
But lets for the sake of an example say that 256 is cd quality (only hypothetically) then why would i need 320? (because 320 isnt cd quality either???)
256 vs 320
how much can you buy for 10$ compared to 12$?
If what you want to buy costs 10$ what can you get for 12$?
Jan.
256 vs 320
how to understand this Jan? I don't get it
256 vs 320
Some more idioms......
Why is it that if someone tells you that there are
1 billion stars in the universe you will believe them,
but if they tell you a wall has wet paint you will have
to touch it to be sure?
:confused:
256 vs 320
Heheh, well I wouldn't believe the bit about the stars either.
There's more like 200 billion stars in our galaxy alone.
But it doesn't really matter, from a practical point of view.  Only the golden-eyed pretend they can count them ;-)
ff123
256 vs 320
Well for one thing, I don't think I'd even say that MP3 at 256kbps is CD Quality even hypothetically.  I'd just say, it can be "high quality" and leave it at that.
However... even when you encode a file at 256kbps cbr, there are many frames which use more than 256kbps via something called the bit reservoir.  Basically what happens is it accumulates extra bits that where not used in preceding frames and stores them for use later if another frame needs them.  This works fairly well, but it is not as good of an approach as just picking the bitrate you need per frame (VBR) instead.  The reason for this is because there are some practical restrictions and limitations on how the bit reservoir can be used.
So the reason you see 320kbps frames, and why you should allow them, is because these are probably the frames that normally would have used more bits from the bit reservoir if you were encoding with CBR, but it more than likely wouldn't sound as good as it is going to with by just using a 320kbps frame instead.
256 vs 320
ahh thanks, that explains it =)
