Topic: foo_custominfo (Read 191365 times) previous topic - next topic
foo_custominfo
Reply #175
latest foo_playcount.dll 2.1.4. doas the similar job:
it uses %first_played%, %last_played%, %played_per_day%, %play_count%, %added% and %rating% in separate file (optional) "PlaybackStatistics.dat", only that it is not in sqlite format, and you can not add other custom tags.
too bad for foo_custominfo, i miss that component, as well
foo_custominfo
Reply #176
And where do you get foo_playcount?  I just exhausted the forum search and came up with nothing.
foo_custominfo
Reply #177
[deleted]
foo_custominfo
Reply #178
Any plans on updating this to work with the latest fb2k version?
Everything I've learned about space, I've learned from psytrance.
foo_custominfo
Reply #179
The original author has been AWOL from June last year till now, so likely won't happen.
foo_custominfo
Reply #180
If only I had the skill necessary ... anyway, I miss it too. I got "Live", "Cover", "Instrumental", "Mood", and others ... I am going back to the previous version
foo_custominfo
Reply #183
I highly doubt it would be compatible with foobar2000 by now anyway, 7 years later.
