Topic: foo_run (Read 612178 times) previous topic - next topic
foo_run 0.3.7
Reply #225
Surround them with single quotes:
"C:\Program Files '('x86')'\appfolder\app.exe" -pram
foo_run 0.3.7
Reply #227
label: Cover-Paradise
path: http://cover-paradies.to/?Module=ExtendedSearch&SearchString=$replace(%artist%+%album%, ,'+')
I try to use this:
$button($eval({%_width%-440}/2+460),12,0,0,110,30,images\cp.png,/images\cp_h.png,'Cover-Paradise',TOOLTIP:"Search Cover-Paradise for %artist%")
,but no working.
Thanks in advance for any help and sorry for my bad english!
You have made a really bad mistake. The command must be /Run/Cover-Paradise instead of 'Cover-Paradise'
The Command was the mistake.
foo_run 0.3.7
Reply #228
I'd rather say Cover-Paradise instead of 'Cover-Paradise'.
foo_run 0.3.7
Reply #229
From the command reference:
$button(x,y,hotspot-x,hotspot-y,hotspot-w,hotspot-h,image,hover image,command,options)
A main menu item or context menu item from foobar2000's command group. For example, Play or Pause, Stop, Preferences, etc.). A definitive list of these items can be found in the drop-down list of the Panels UI configuration window, via the Main and Context buttons.
So it must be /Run/Cover-Paradise.
foo_run 0.3.7
Reply #230
Hi all, little problem with RateYourMusic
I just want to open the page for the album I'm listening to, for now I wrote this:
http://rateyourmusic.com/release/album/$replace(%artist%,' ','_')/$replace(%album%,' ','_')/
Problem is that RYM has all lowcase names in the url, anda I have no idea how to do it (avoiding the editing of ID3 tags of course  )
I'm kinda newbie in foobar coding, I don't know if exist a "lowercase" command, does it?
thank you
foo_run 0.3.7
Reply #231
Try this:
"http://rateyourmusic.com/release/album/$lower($replace(%artist%, ,_))/$lower($replace(%album%, ,_))/"
foo_run 0.3.7
Reply #233
I've just released foo_run 0.3.3!
Release notes:
CHG: improved usability of preferences page.
CHG: urls and paths are now also opened by the default application under Vista.
CHG: all paths containing blanks must be put in quotes now.
CHG: dropped support for Windows 2000.
FIX: menu item labels were not visible at some configuration dialogs of specific UIs.
You can get it from the first post of this topic.
Enjoy
foo_run 0.3.7
Reply #234
Thank you very much!
foo_peter
foo_run 0.3.7
Reply #235
I've just released foo_run 0.3.4!
Release notes:
FIX: preferences page was cropped when using large DPI settings.
Enjoy your large DPI settings
foo_run 0.3.7
Reply #236
Extremely useful....have been using it for a long time...makes things a lot more productive...thx for the update!
foo_run 0.3.7
Reply #237
Thanks Florian for update and the original
foo_run 0.3.7
Reply #238
i want to use foo_run with Art Album Downloader.
i put in service properties:
C:\Program Files (x86)\AlbumArtDownloader\AlbumArt.exe -ar "%artist%" -al "%album%" -p "$replace(%_path%,%_filename_ext%,)folder.jpg"
and it dont work. I use WIndows XP 64 Bit system. In 32 bit its works ok.
I also try mediainfo.dll 64bit version and dont work too.
any ideas?
foo_run 0.3.7
Reply #239
I use :
"C:\Program Files\AlbumArtDownloader\AlbumArt.exe" /artist "%artist%" /album "%album%" /autoclose /p "$replace(%path%,%filename_ext%,folder.jpg)" /sources "Amazon"
Sorry for the bad english, I'm french .
foo_run 0.3.7
Reply #241
Hi. Can I run 2 commands at once? I haven't been able to do it...
Ideally I'd like to do a search in songmeanings (I figured out that much), and then to create an empty txt file named 'artist - track - song.txt', or more easily, 'filename.txt' (and then I'll manually paste the lyrics text and save to my lyrics folder, but that can't be automated... if only.... )
Is this possible?
any help would be great thanks!
p
foo_run 0.3.7
Reply #242
You should be able to do it using a batch file, create search.bat containing:
start http://www.songmeanings.net/query.php?action=title^&query=%1
start notepad "%~dpn2.txt"
(I'm not sure if the carat ^ is needed but it is usually needed in DOS)
Then call it from foo_run with
path/to/search.bat "$replace(%title%, ,+)" "%path%"
I hope that gets you started.
foo_run 0.3.7
Reply #243
wow thanks for the quick reply
this does not "get me started", this is exactly what I wanted
thanks a lot!
edit: just a little thing. would it be possible to create the txt file in a different folder (where I have all the lyrics stored)? If not, it's just fine as it is
edit2: nevermind. I figured it out
foo_run 0.3.7
Reply #244
This is priceless. thanks.
http://www.freecovers.net/search.php?search=$replace(%artist%$if2( %album%,), ,$char(37)20)
Thats a code I use for a site I get a lot of covers from if anyone wants it.
foo_run 0.3.7
Reply #245
Discogs Artist, also works for The... artists.
http://www.discogs.com/artist/$if($strcmp($padcut(%artist%,4),The ),$replace($substr(%artist%,5,$len(%artist%)), ,+)','+The,$replace(%artist%, ,+))
foo_run 0.3.7
Reply #246
i ran into trouble trying to setup menu items to launch Mp3tag dir or file using the old posts.
Here's the code that I got working on my install - Vista 32-bit, foobar2000 0.9.5.3, Mp3tag v2.41:
Label:  Mp3tag '('dir')'
Path:  "C:\Program Files\Mp3tag\Mp3tag.exe" "/fp:$substr(%_path%,0,$strrchr(%_path%,'\'))"
Label:  Mp3tag '('file')'
Path:  "C:\Program Files\Mp3tag\Mp3tag.exe" "/fn:%_path%"
Hopefully it will save someone else some time.
foo_run 0.3.7
Reply #248
hi,
try this:
"C:\Program Files\Irfanview\i_view32.exe" "$replace(%_path%,%_filename_ext%,)folder.jpg"
replace the red-colored path with your program-path... whatever you use.
greets
