Topic: iPod manager (Read 2269962 times) previous topic - next topic
[seemingly abandonware] iPod manager
Reply #3075
Any chance of getting per iPod settings. I sync four iPods and they all get different playlists, conversions, etc. Trying to remember what each should be is a bit of a pain.
Reply #3076
The Artwork column in Manage Contents is blank.
I have my iPod Features option "Additionally use foobar2000 built-in artwork reader" checked.  I thought that meant it would use the art I already set up in Foobar using title formatting (through ColumnsUI).  Did I misinterpret this?  I have a couple formatting strings because of the way I store it, so I couldn't fit it all in the "Source Script" field.
Reply #3077
Yes sounds like it - it refers to the foobar2000 core's reader rather than Column UI's - you can specify the settings for it on the "Display" preferences page in foobar2000 1.0 and newer.
Reply #3078
Hi, first off nice work on the plugin! Works great.
Question, is there anyway to have synched songs Artists changed to whatever they have for Album Artist? This would be a godsend for me!
Reply #3080
Thanks that did the trick!
Reply #3081
Are you going to host this and your other components on the official components site to take advantage of the new updater?
I hadn't even realized my foo_dop was a few version behind.
elevatorladylevitateme
Reply #3082
Probably not.
Reply #3083
Is there plan of update to support iPad/iPhone 4?
Reply #3084
Well it is this whole business of database signing. I know a few people seem to have worked it out but sadly I do not belong to that elusive club. So there is no definite answer, but we'll probably get there eventually.
Reply #3085
Just a small request - could you make the progress bar more... describing? Or add another one  for each task? It's usually /stuck/ on the task it's currently performing, which is either "Removing files" or "Copying files (x of y left)".
Reply #3086
I am getting the following error when trying to send tracks to my iPod "SQLite command failed: PRIMARY KEY must be unique".  I'm running Foobar2000 1.1 beta 1.
Thanks.  I couldn't find any info by searching.
Tim
Reply #3087
I'll keep it in mind.
Have you been using any other third party iPod managers? Anyway the database is broken; looks like something has assigned the same ID to multiple tracks. I would just do a restore at this point (other than that removing all tracks and resending them should sort it).
Reply #3088
I have been using MediaMonkey to manage my iPod.  I need to become more familiar with Foobar before making the switch.  I need to figure out how FB handles auto playlists and saved playlists
Thanks,
Tim
Reply #3089
Hi.  I posted this in the foo_audioscrobbler thread but was directed here by Fangs404. Is there any possibility of a feature that remembers previously synced iPods?  Thanks musicmusic.
Hello.  Is there a way to disable scrobbling on a specific iPod?  I use this plugin in conjunction with foo_dop in order to scrobble my iPod tracks.  However, when I connect my wife's iPod to transfer music, her tracks get scrobbled as well.  I would prefer not to have tracks on her iPod scroblled.  Thanks Florian.
I can tell you that the current answer is no.  What would need to happen is that foo_dop would need to remember all previously synced iPods.  If this were done, Florian's plugin could be updated to select the iPod(s) to allow scrobbling.  So basically, you need to ask the foo_dop developer.
Reply #3090
Hi.
I just upgraded to 0.6.8.2 and now on foobar startup I receive the following message:
iPod manager: Failed to query registry for Apple Application Support directory - Impossibile trovare il file specificato.(*)
(*)Unable to find the specified file (more or less).
Nothing relevant in the console, AFAICS; and the previous version was working fine, of course.
Thanks for any suggestion.
Alessandro
Reply #3091
I'll think about it.
Looks like you don't have Apple Application Support installed, recent versions removed the Quicktime fallback. Try (re)installing Apple Application Support.
Reply #3092
Hello musicmusic,
Thank you for your awesome plugin!
Future request:
Could you provide an option to perform synchronisation in "Quiet mode" when the only action is adding new files to iPod (i.e. no files are removed from the device)? Have you thought about this?
Regards
pmj
Reply #3093
I am getting this error every time i am trying to remove songs from the ipod.....
Error reading iTunesDB : I/O Error: AFCFileRefOpen returned: 2 Path was: /iTunes_Control/iTunes/iTunesCDB
i reset all foobar settings and then retried and everything was ok, then i reconnected my device and the problem is still here...... Sometimes i try first to import songs and everything goes right, then if i try to remove a song the error occurs and after that i can't do noting with the ipod (i get other errors...) :/
Btw really thanks for your effort in this plugin its great
Reply #3094
I do see where you are coming from but I'm not too sure on the necessity. I'll think about it but also I'll probably rename the option to something sane.
That is a protocol related error, so that is mighty suspicious. It won't be anything directly to do with the component, but there is a large number of things it could be. First can you give me some information about your set-up i.e. iTunes version, iOS version, motherboard and then I'll suggest some things.
Reply #3095
Of course i can, first of all my ipod is an Mc Model 2G (it must be 2G cause its the 8gb version...) with ios4 installed. Itunes version is 9.2.1.4 and i have an asus p5k mobo. I am running windows 7 with foobar 1.0.3
I found a workaround to import and export songs to the ipod with playlist sychronizing, but still if i try to do smthn manually the problems start.....
Reply #3096
The only relevant difference between 'Sync' and 'Remove files' is that the former checks if a database exists; if not it creates a new one..
So does say 'Load library' trigger the error? Can you keep the device system log open (Shift + File/iPod/System log viewer) and trigger the error; what is outputted to the log?
Reply #3097
Nope, Load Library always works fine with no error. The error still occurs when trying to remove but in the log viewer there is nothing new reported :S... in the console too... Well there are some errors reported but nothing after trying to remove or update or something....
Here is the output
Thu Jul 29 06:37:57 unknown SpringBoard[26] <Notice>: MultitouchHID(20af60) uilock state: 1 -> 0
Thu Jul 29 06:37:57 unknown SpringBoard[26] <Notice>: MultitouchHID(225e10) device bootloaded
Thu Jul 29 06:40:41 unknown afcd[575] <Error>: NSDescription="send" NSDebugDescription="Broken pipe" AFCFileLine="570" NSUnderlyingError="32" AFCFileName="platform.c" AFCCode="-402636795" AFCVersion="118.09999999999999"
Thu Jul 29 06:40:41 unknown afcd[575] <Error>: NSDescription="recv" NSDebugDescription="Connection reset by peer" AFCFileLine="483" NSUnderlyingError="54" AFCFileName="platform.c" AFCCode="-402636796" AFCVersion="118.09999999999999"
Thu Jul 29 06:40:41 unknown afcd[575] <Error>: packet read error -402636796, errno 54
Is it possible that the problem is caused by other components?
EDIT:
Here is a successful send to ipod command log:
Thu Jul 29 06:48:54 iG SpringBoard[26] <Notice>: MultitouchHID(20af60) uilock state: 1 -> 0
Thu Jul 29 06:48:54 iG SpringBoard[26] <Notice>: MultitouchHID(225e10) device bootloaded
Thu Jul 29 06:59:44 iG MobileMusicPlayer[600] <Warning>: *** MLSSqliteVFS AllWrites DISABLED ***
Thu Jul 29 06:59:50 iG SpringBoard[26] <Warning>: MediaPlayer: Message fetchArtworkForSizeValue:item: timed out.
Thu Jul 29 06:59:51 iG SpringBoard[26] <Warning>: ITDBPrepServerPostProcessRun: [BEGIN] looking up itdbprepserver.
Thu Jul 29 06:59:52 iG itdbprepserver[605] <Warning>: starting up.
Thu Jul 29 06:59:52 iG itdbprepserver[605] <Warning>: acquired iTunes sync file lock.
Thu Jul 29 06:59:52 iG itdbprepserver[605] <Warning>: acquired itdbprep file lock.
Thu Jul 29 06:59:52 iG itdbprepserver[605] <Warning>: posting com.apple.itdbprep.notification.willBegin
Thu Jul 29 06:59:52 iG itdbprepserver[605] <Warning>: BEGIN processing command: com.apple.itdprep.command.runPostProcess
Thu Jul 29 06:59:52 iG SpringBoard[26] <Warning>: ITDBPrepServerPostProcessRun: [-END-] looking up itdbprepserver.  success = 1
Thu Jul 29 06:59:52 iG itdbprepserver[605] <Warning>: [BEGIN] ITDBPostProcessController...
Thu Jul 29 06:59:52 iG com.apple.itdbprep.server[605] <Notice>: warning: Could not compile statement SELECT value FROM _SqliteDatabaseProperties WHERE key = ?;: no such table: _SqliteDatabaseProperties
Thu Jul 29 06:59:52 iG itdbprepserver[605] <Warning>: Skipping iTunes Commands (commands already run).
Thu Jul 29 06:59:53 iG itdbprepserver[605] <Warning>: [BEGIN] Post Processing...
Thu Jul 29 06:59:53 iG itdbprepserver[605] <Warning>: Running Misc Commands...
Thu Jul 29 06:59:53 iG itdbprepserver[605] <Warning>: Running Create Triggers...
Thu Jul 29 06:59:54 iG itdbprepserver[605] <Warning>: [-END-] Post Processing.
   Stats
      totalMLSITDBPostProcessing=(0.67) 0.670 s
      triggers=0.536 s
      misc=0.103 ss
      icuSort=0.000 ss (MLS_icu_data=0.000 ss, MLS_icu_sec_data=0.000 s, dropIdx=0.000 s, normalize=0.000 s, update_orders=0.000 s, tStatsICUOther1=0.000 s, createIndex=0.000 s)
Thu Jul 29 06:59:54 iG itdbprepserver[605] <Warning>: Initializing MusicLibrary and loading purchases...
Thu Jul 29 06:59:54 iG itdbprepserver[605] <Warning>: saved file to: /var/mobile/Media/iTunes_Control/iTunes/GeniusPlaylist_0.plist
Thu Jul 29 06:59:54 iG itdbprepserver[605] <Warning>: saved file to: /var/mobile/Media/iTunes_Control/iTunes/OnTheGoPlaylist_1.plist
Thu Jul 29 06:59:54 iG itdbprepserver[605] <Warning>: *** STARTING: DB Backup (CREATE-NEW) ***
Thu Jul 29 06:59:55 iG itdbprepserver[605] <Warning>: *** FINISHED: DB Backup (CREATE-NEW, time = 0.51s) ***
Thu Jul 29 06:59:55 iG itdbprepserver[605] <Warning>: [-END-] ITDBPostProcessController.
   Stats
      totalTime=3.04s
      ensureIndices=0.00
      updateSortMap=0.31
Thu Jul 29 06:59:55 iG itdbprepserver[605] <Warning>: DONE processing command: com.apple.itdprep.command.runPostProcess
Thu Jul 29 06:59:55 iG itdbprepserver[605] <Warning>: Releasing locks.
Thu Jul 29 06:59:55 iG itdbprepserver[605] <Warning>: exitServerWithReason com.apple.itdbprep.notification.didEnd
Thu Jul 29 06:59:55 iG itdbprepserver[605] <Warning>: exiting now.
Thu Jul 29 06:59:57 iG MobileMusicPlayer[606] <Warning>: Skipping iTunes Commands (commands already run).
Thu Jul 29 07:00:58 iG SpringBoard[26] <Notice>: MultitouchHID(20af60) uilock state: 0 -> 1
Reply #3098
First log looks related.
There aren't really any significant differences between 'Remove files and 'Load library' up until the point they open the database file...
What if you do 'Load library' twice?
If that works, can you make a new clean portable install of foobar2000 and see if that makes any difference.
Also, can you reinstall Apple Mobile Device Support in case some files weren't updated for some reason. Close foobar2000 first.
If it is still happening after all that, can you try uninstalling any software firewalls (if you are using any)?
Reply #3099
Double library load triggered the error :O:O
What should i do in this case
