Topic: iPod manager (Read 2278935 times) previous topic - next topic
[seemingly abandonware] iPod manager
Reply #1275
musicmusic,
After using this plug-in for a little while, I've still found some bizarre behavior with my files on the iPhone losing the lyrics tags in the database.  The tags remain intact in the files on the device, but for some reason they stop being displayed when playing occasionally....this may be related to iTunes screwing with the files.
However, I have discovered a workaround: It appears that the device will display lyrics if they are included in the COMMENT field with a leading [LY] at the front of the field.  Would it be possible to include an option to map a title-formatting string to the comment field in the metadata tab?  It's been a long and frustrating struggle to take full advantage of the abilities of the iPhone without the need for let iTunes take control of my carefully tagged files, and this would be one step in that process.
Reply #1276
I tried creating a smart playlist based on rating > 3 but only one song is added to it.  I wonder if this has something to do with the fact that I use foo_custominfo for storing the rating tag?
Yes. I will fix it so it at least works with the official Playback Statistics component, which will probably fix it for you as well, and maybe a remapping when there is some space in prefs.
musicmusic,
Strings in the iTunesDB are limited to 500 characters - so it's not getting anything from there (unless your lyrics are really short..). The iPod reads lyrics directly from the file's tags, with regards to MP3 it needs "iTunes compatible" ID3v2 tags - enabling the compatibility mode in foobar2000 usually achieves that if you're tagging with foobar2000. I don't remember who (maybe you) but someone reported seeing random parts of the MP3 file instead of the lyrics on the iPod touch when they had ID3v2.4 tags..
Reply #1277
I have noticed certain strange behavior in the display of the lyrics when the tags are not written in compatibility mode too....but that's not really what's been happening here.
Sometimes, the lyrics show for some period of time, and then for no apparent reason the device decides it doesn't want to show them anymore.  They are still in the file, because when I load the library on my work computer, the foobar2000 lyrics display panel still shows them.  I guess there is a still a lot of "black magic" in the way the iPhone displays stuff.
Reply #1278
Can you make them reliably disappear and come back? The thing is, if it is having trouble reading the tag it can still give inconsistent results. If you can reliably make them disappear and come back, then you can try tagging a track with iTunes itself and see if that helps.
But anyway the extent of the component's involvement with lyrics is just setting a flag in the database to indicate whether a track has lyrics or not. So otherwise I guess your hope is new firmware..
Reply #1279
Yeah, if I send a file with lyrics, and then don't let iTunes do anything, they show up.  As soon as I allow iTunes to run, even though it's set to let me manually manage my music, and to NOT sync ANY files at all, the lyrics refuse to show up, even though they are still in the file.  If I remove them from the file on the iPhone, then re-add them and run the foo_dop "update metadata..." command, they come back until iTunes runs again.  So for whatever reason, iTunes is probably telling the device that no lyrics are attached, so the device isn't even looking into that tag as it runs.
The strange thing is that this problems seems to have come up somewhat recently, although I cannot pinpoint exactly when it started (maybe with the recent iTunes update about a month ago?).  Could have been with one of the minor updates in foo_dop...I really don't know.  However I can reliably make this problem arise and then dissapear.
....it's too bad that such a wonderful device as the iPhone has to be developed by the same company that forces you to use such a monumental piece of shiatt as iTunes.
Reply #1280
The plot thickens. I can reproduce this. With further investigation, it seems that along with that flag I mentioned iTunes is writing some other value into the database these days, which foo_dop doesn't and is causing iTunes to remove the other flag. So I need to work out what this value means, doesn't seem like anything obvious at first sight
Reply #1281
Well, I may as well update you on what I found out. It seems to be a 32-bit checksum/hash of the lyrics, also dependant on the filetype. I thought I was being paranoid, but any two MP3 files with same lyrics but other metadata different get the same value, and same length but different lyrics get a different value. Clearly the iPod doesn't care about this, since it displays lyrics without it, so what exactly this is for is beyond me. The algorithm is unknown to me; if it is anything like the main database hash it could also depend on one of the iPod's serial numbers and some magic bytes. The good news is that at first sight putting any garbage in this field seems to be enough to keep iTunes and my iPod classic happy, but the bad news is if it is really meant as a checksum this may not work forever or may have different results on an iPod touch.
I just can't see why they would try and protect a feature like lyrics like this: maybe it's to do with the fact that lyrics requires the January software update on the iPod touch? I think you are right though in that it must have started with a recent iTunes update.
Reply #1282
Maybe something to do with licensing?  Perhaps they are considering embedding lyrics into files downloaded from the music store, and want to be able to assure the record companies that this information is "secured".
Either way, I becomes increasingly weary with iTunes' overbearing control over the iPhone.....
Reply #1283
Version 0.6.0 released. See changelog for details.
Well, version 0.6.0 sets this field to some fixed value (for new tracks), which stops iTunes removing the lyrics flag. This doesn't affect the ability of my iPod classic to display lyrics, but I need confirmation that the iPod touch and iPhone are OK as well.
Reply #1284
Great, thanks for that.  I am currently in the midst of a move, so right now my computer is packed up and I am restricted to my iPhone for all computing needs.  I probably won't have it setup until this upcoming weekend, and I'll test it then to make sure it works.
Reply #1285
On the topic of lyrics, I have two questions:
1. What tag do the lyrics need to be in for the iPod (specifically the 80GB classic) to read them?
2. If the answer to question 1. is something OTHER than %lyrics% would it be at all possible for foo_dop to make the iPod read the lyrics from the %lyrics% tag instead (or make a custom mapping for it)?
I can't get my classic to display my lyrics, and I never have been able to .
EDIT: I just read on http://yuo.be/wiki/dop:notes that the lyrics need to be in the Unsynced Lyrics tag for MP3's, so my suggestion is that it be possible to map this to a different field such as %lyrics% if this is possible .
Song List: keikoniumboards.ke.funpic.org/files/songlist.html
Reply #1286
OK cool  If it works then I'll be happy to remove all previous versions of foo_dop (well, I already started there ).
[...]EDIT: I just read on http://yuo.be/wiki/dop:notes that the lyrics need to be in the Unsynced Lyrics tag for MP3's, so my suggestion is that it be possible to map this to a different field such as %lyrics% if this is possible .
I can't change what foobar2000 maps the USLT ID3v2 frame to. I can recommend the Linear+ view in the forum.
Reply #1288
Hmm, that sucks . So is there any way at all to make the classic read lyrics from the %lyrics% tag or am I gonna have to convert all the %lyrics% tags to %unsynced lyrics%?
Reply #1290
Thank you so much for the sync dialog! However, sync still only works as long as I completely avoid running itunes or doing transfers with any other program. I decided to completely format my ipod, then I used foobar to sync a bunch of tracks. Then, I ran itunes and it automatically started to determine gapless data and whatever else it does for the tracks on the ipod. Then, when I selected the same tracks in foobar to sync, it assumed they had all changed and wanted to delete and add them all. This doesnt happen if I dont run itunes. Its wierd because I checked the filesize, tags, etc. of the tracks before and after running itunes, and they seem identical.
I noticed that after itunes works it magic on the tracks, the transparent artwork problem for those tracks is fixed. Is foo_dop detecting a change in the artwork? Id think this is a database change only and wouldnt affect the syncing check.
Reply #1291
There's two possibilities:
1. If they are transcodes, it may be due to iTunes changing their ID in the database
2. Otherwise, the only thing it could be is iTunes changing the modified date for these tracks in the database. If this is the case, I can keep a track of it in the foo_dop database instead for just the iPod touch/iPhone. But if it is this case can you check what iTunes displays in the Date Modified column for these tracks on the iPod?
When iTunes does a scan for gapless data, it will reload the artwork, metadata etc. That is why the artwork changed. You can stop it doing this on foo_dop tracks if you want by enabling both gapless options in foo_dop prefs.
Reply #1292
Then I suppose there's no hope for those using APEv2 tags...?
Correct.
Please forgive my ignorance but I was wondering... I tag my MP3s with ID3v1/APEv2 tags only and ordinary APEv2 tags (eg. Album) are correctly transferred: how is this possible if foo_dop/iPod only handle ID3v2? Couldn't some sort of remapping be implemented?
Thanks for your attention.
Alessandro
Reply #1293
Nope, not transcodes but interestingly the Date Modified column in itunes is showing blanks. Maybe this is related to the problem?
Maybe what ill do is get a copy of the database before and after modifying it with itunes, and then you can compare them. This might also be a good way to figure out the transparent artwork problem.
Btw, I just got a crash after I hit stop in the middle of a sync:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 0165DEF5h
Access violation, operation: read, address: 00000000h
Call path not available.
Code bytes (0165DEF5h):
0165DEB5h:  17 00 00 8B 45 AC 8B 40 38 8D 1C CD 00 00 00 00
0165DEC5h:  8B 0C 18 8B 54 18 04 03 C3 89 8D C8 FE FF FF 89
0165DED5h:  95 CC FE FF FF 85 C9 74 0A 83 C1 04 51 FF 15 EC
0165DEE5h:  C0 6C 01 8B 45 AC 8B 55 90 C6 45 FC 10 8B 48 04
0165DEF5h:  8B 3C 91 8D 04 91 85 FF 74 09 8B 07 8B 50 04 8B
0165DF05h:  CF FF D2 89 BD 38 FF FF FF 33 C9 B8 34 F2 6C 01
0165DF15h:  89 4D A0 89 4D A4 89 4D A8 89 45 9C 89 8D 6C FC
0165DF25h:  FF FF 89 8D 70 FC FF FF 89 8D 74 FC FF FF 89 85
Stack (0B5FE55Ch):
0B5FE53Ch:  004C8D95 0012FB8C 0063D940 5A0F0A1F
0B5FE54Ch:  FFFFFFFE 00631EFB 004CB625 0012F95C
0B5FE55Ch:  979CD6B9 0B43B180 0B61F008 0B61F088
0B5FE56Ch:  09F20E7C 71AB4D1F 00000008 000003AC
0B5FE57Ch:  001F30D0 00000000 0B5FE5B0 71AD2EA3
0B5FE58Ch:  000003AC 0B5FE5A8 00000001 0B5FE5C0
0B5FE59Ch:  0B5FE5BC 0B5FE5D8 016B47DF 00000031
0B5FE5ACh:  0B5FE5D8 016B499C 00000000 00000000
0B5FE5BCh:  0B5FEEE4 016B49A9 0B5FEEE4 016B8901
0B5FE5CCh:  00000000 0B5FEEE4 00000000 0B5FE604
0B5FE5DCh:  016B2CA0 0B5FE674 0B5FFC20 0B5FE720
0B5FE5ECh:  00000000 016E1434 00000001 0B5FEEE4
0B5FE5FCh:  00000000 00000000 0B5FE628 7C9032A8
0B5FE60Ch:  0B5FE674 0B5FEEE4 0B5FE720 0B5FE714
0B5FE61Ch:  0B5FEEE4 7C9032E3 0B5FEEE4 0B5FE9F0
0B5FE62Ch:  7C90327A 0B5FE674 0B5FEEE4 0B5FE720
0B5FE63Ch:  0B5FE714 016B2C73 00000001 0B5FE674
0B5FE64Ch:  0B5FEEE4 7C92ACAD 0B5FE674 7C90D04C
0B5FE65Ch:  7C92ACD6 0B5FE720 00000000 00000001
0B5FE66Ch:  0B5FEF64 016D8900 C0000027 00000002
Registers:
EAX: 0B61F088, EBX: 00000000, ECX: 00000000, EDX: 00000000
ESI: 0B61F07C, EDI: 00000000, EBP: 0B5FEE4C, ESP: 0B5FE55C
Crash location: "foo_dop", loaded at 01640000h - 016FC000h
Loaded modules:
foobar2000                      loaded at 00400000h - 00527000h
ntdll                            loaded at 7C900000h - 7C9AF000h
kernel32                        loaded at 7C800000h - 7C8F6000h
COMCTL32                        loaded at 773D0000h - 774D3000h
msvcrt                          loaded at 77C10000h - 77C68000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F02000h
Secur32                          loaded at 77FE0000h - 77FF1000h
GDI32                            loaded at 77F10000h - 77F59000h
USER32                          loaded at 7E410000h - 7E4A1000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7D1D7000h
ole32                            loaded at 774E0000h - 7761D000h
shared                          loaded at 10000000h - 1002A000h
COMDLG32                        loaded at 763B0000h - 763F9000h
IMM32                            loaded at 76390000h - 763AD000h
AirfoilInject                    loaded at 00390000h - 003B8000h
winmm                            loaded at 76B40000h - 76B6D000h
dsound                          loaded at 73F10000h - 73F6C000h
VERSION                          loaded at 77C00000h - 77C08000h
fgmgr                            loaded at 00ED0000h - 00EDD000h
WININET                          loaded at 42C10000h - 42CE0000h
Normaliz                        loaded at 00EE0000h - 00EE9000h
iertutil                        loaded at 42990000h - 429D5000h
MSCTF                            loaded at 74720000h - 7476C000h
msctfime                        loaded at 755C0000h - 755EE000h
foo_abx                          loaded at 01160000h - 01191000h
foo_albumlist                    loaded at 011C0000h - 01226000h
foo_appcommand                  loaded at 01250000h - 01266000h
foo_autoplaylist                loaded at 01290000h - 012C0000h
foo_cdartdisplay                loaded at 012E0000h - 01311000h
foo_cdda                        loaded at 01340000h - 01378000h
foo_converter                    loaded at 013A0000h - 01406000h
foo_cwbowron                    loaded at 01430000h - 01458000h
gdiplus                          loaded at 4EC50000h - 4EDF6000h
foo_cwb_hooks                    loaded at 01490000h - 014DC000h
foo_dbsearch                    loaded at 01500000h - 01570000h
OLEAUT32                        loaded at 77120000h - 771AB000h
foo_discogs                      loaded at 01590000h - 01624000h
WS2_32                          loaded at 71AB0000h - 71AC7000h
WS2HELP                          loaded at 71AA0000h - 71AA8000h
foo_dop                          loaded at 01640000h - 016FC000h
SETUPAPI                        loaded at 77920000h - 77A13000h
UxTheme                          loaded at 5AD70000h - 5ADA8000h
foo_dsp_continuator              loaded at 01720000h - 01736000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
MSVCR80                          loaded at 78130000h - 781CB000h
foo_dsp_crossfader              loaded at 01760000h - 01790000h
foo_dsp_skip_silence            loaded at 017B0000h - 017D3000h
foo_dsp_soundtouch              loaded at 01800000h - 01826000h
foo_dsp_std                      loaded at 01850000h - 01896000h
foo_dsp_vlevel                  loaded at 018C0000h - 018E4000h
foo_dts                          loaded at 01910000h - 019E0000h
foo_etc                          loaded at 01A00000h - 01A35000h
CLBCATQ                          loaded at 76FD0000h - 7704F000h
COMRes                          loaded at 77050000h - 77115000h
vbscript                        loaded at 73300000h - 7336A000h
SXS                              loaded at 7E720000h - 7E7D0000h
foo_exvar                        loaded at 01A80000h - 01AAE000h
foo_facets                      loaded at 01BD0000h - 01C51000h
MSIMG32                          loaded at 76380000h - 76385000h
foo_fileops                      loaded at 01C80000h - 01CC6000h
foo_freedb2                      loaded at 01CF0000h - 01D30000h
foo_func                        loaded at 01D50000h - 01D96000h
foo_highlightplaying            loaded at 01DB0000h - 01DD1000h
foo_input_mslive                loaded at 01E00000h - 01EF9000h
WMVCore                          loaded at 15110000h - 1536A000h
WMASF                            loaded at 11C70000h - 11CAA000h
foo_input_reverse                loaded at 01F20000h - 01F47000h
foo_input_std                    loaded at 01F70000h - 02097000h
foo_input_wma                    loaded at 020C0000h - 020EE000h
foo_listeningto                  loaded at 02110000h - 02120000h
foo_lyricsgrabber                loaded at 02130000h - 02183000h
foo_masstag                      loaded at 021B0000h - 021FF000h
foo_masstag_addons              loaded at 02220000h - 02241000h
foo_masstag_replace              loaded at 02270000h - 022A1000h
foo_menu_addons                  loaded at 022D0000h - 02315000h
foo_minimize_on_close            loaded at 02340000h - 02356000h
foo_misc_addons                  loaded at 02380000h - 023AD000h
foo_mlt                          loaded at 023D0000h - 023DA000h
foo_navigator                    loaded at 023F0000h - 02421000h
foo_playlist_bind                loaded at 02450000h - 02475000h
foo_popupplus                    loaded at 02490000h - 02519000h
RICHED20                        loaded at 74E30000h - 74E9D000h
foo_pqview                      loaded at 02540000h - 0256D000h
foo_prettypop                    loaded at 02590000h - 025DD000h
mscoree                          loaded at 79000000h - 79046000h
msvcm80                          loaded at 7C4C0000h - 7C53D000h
mscorwks                        loaded at 79E70000h - 7A3FF000h
mscorlib.ni                      loaded at 790C0000h - 79BF6000h
mscorjit                        loaded at 79060000h - 790B6000h
rsaenh                          loaded at 68000000h - 68036000h
foo_preview                      loaded at 04A70000h - 04A91000h
foo_quicktag                    loaded at 04B30000h - 04B64000h
foo_random                      loaded at 04B90000h - 04BCD000h
foo_rgscan                      loaded at 04BF0000h - 04C4B000h
foo_run                          loaded at 04C70000h - 04C9E000h
foo_snap                        loaded at 04CC0000h - 04CD6000h
foo_tlbRC                        loaded at 04D00000h - 04D20000h
foo_trackpos                    loaded at 04D40000h - 04D5F000h
foo_truephase_hq                loaded at 04D80000h - 04D9E000h
foo_uie_lyrics_art              loaded at 04DC0000h - 04E6E000h
foo_ui_std                      loaded at 04E80000h - 04F53000h
foo_unpack                      loaded at 04F80000h - 04FAD000h
foo_utils                        loaded at 04FD0000h - 05014000h
foo_winamp_ipc                  loaded at 05040000h - 05062000h
foo_winamp_spam                  loaded at 05090000h - 050AF000h
WINTRUST                        loaded at 76C30000h - 76C5E000h
CRYPT32                          loaded at 77A80000h - 77B15000h
MSASN1                          loaded at 77B20000h - 77B32000h
IMAGEHLP                        loaded at 76C90000h - 76CB8000h
CoreFoundation                  loaded at 18000000h - 18110000h
WSOCK32                          loaded at 71AD0000h - 71AD9000h
YSFileShim                      loaded at 05670000h - 0567A000h
icuuc36                          loaded at 09590000h - 09658000h
icudt36                          loaded at 09660000h - 09D67000h
icuin36                          loaded at 09D70000h - 09DFD000h
pthreadGC2                      loaded at 09E00000h - 09E0F000h
libobjc.i386.A                  loaded at 22200000h - 2229D000h
iTunesMobileDevice              loaded at 09F10000h - 0A024000h
QuickTime                        loaded at 66800000h - 6785D000h
System.ni                        loaded at 7A440000h - 7AC2A000h
mswsock                          loaded at 71A50000h - 71A8F000h
hnetcfg                          loaded at 662B0000h - 66308000h
wshtcpip                        loaded at 71A90000h - 71A98000h
System.Drawing.ni                loaded at 7ADE0000h - 7AF7C000h
System.Windows.Forms.ni          loaded at 7AFD0000h - 7BC6C000h
dciman32                        loaded at 73BC0000h - 73BC6000h
wdmaud                          loaded at 72D20000h - 72D29000h
msacm32                          loaded at 72D10000h - 72D18000h
MSACM32                          loaded at 77BE0000h - 77BF5000h
midimap                          loaded at 77BD0000h - 77BD7000h
KsUser                          loaded at 73EE0000h - 73EE4000h
mslbui                          loaded at 605D0000h - 605D9000h
PopUpIcons                      loaded at 0B250000h - 0B256000h
awaysystemex                    loaded at 3AB00000h - 3AB25000h
xpsp2res                        loaded at 0B800000h - 0BAC5000h
DBGHELP                          loaded at 59A60000h - 59B01000h
Stack dump analysis:
Address: 09F20E7Ch, location: "iTunesMobileDevice", loaded at 09F10000h - 0A024000h
Symbol: "AFCSendData" (+000000ECh)
Address: 71AB4D1Fh, location: "WS2_32", loaded at 71AB0000h - 71AC7000h
Symbol: "WSARecv" (+0000006Ah)
Address: 71AD2EA3h, location: "WSOCK32", loaded at 71AD0000h - 71AD9000h
Symbol: "recv" (+00000033h)
Address: 016B47DFh, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 016B499Ch, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 016B49A9h, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 016B8901h, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 016B2CA0h, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 016E1434h, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 7C9032A8h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlConvertUlongToLargeInteger" (+0000006Ah)
Address: 7C9032E3h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlConvertUlongToLargeInteger" (+000000A5h)
Address: 7C90327Ah, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlConvertUlongToLargeInteger" (+0000003Ch)
Address: 016B2C73h, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 7C92ACADh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlUnwind" (+00000108h)
Address: 7C90D04Ch, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "ZwContinue" (+0000000Ch)
Address: 7C92ACD6h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlUnwind" (+00000131h)
Address: 016D8900h, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 016B740Bh, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 71A544B0h, location: "mswsock", loaded at 71A50000h - 71A8F000h
Address: 71A544A8h, location: "mswsock", loaded at 71A50000h - 71A8F000h
Address: 71AB4D16h, location: "WS2_32", loaded at 71AB0000h - 71AC7000h
Symbol: "WSARecv" (+00000061h)
Address: 71AB2E1Fh, location: "WS2_32", loaded at 71AB0000h - 71AC7000h
Symbol: "WSASetEvent" (+0000018Eh)
Address: 71A52BE9h, location: "mswsock", loaded at 71A50000h - 71A8F000h
Address: 71A52C78h, location: "mswsock", loaded at 71A50000h - 71A8F000h
Address: 71A52C66h, location: "mswsock", loaded at 71A50000h - 71A8F000h
Address: 016D37E8h, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 7C90D26Ch, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "ZwDeviceIoControlFile" (+0000000Ch)
Address: 71A5440Bh, location: "mswsock", loaded at 71A50000h - 71A8F000h
Address: 0168196Eh, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 7C910098h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+0000018Bh)
Address: 7C910021h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+00000114h)
Address: 7C91003Dh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 7C8097F6h, location: "kernel32", loaded at 7C800000h - 7C8F6000h
Symbol: "InterlockedIncrement" (+00000000h)
Address: 7C910961h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "wcsncpy" (+00000402h)
Address: 7C910040h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 0049FDC8h, location: "foobar2000", loaded at 00400000h - 00527000h
Address: 7C90E900h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "strchr" (+00000113h)
Address: 0049FDA9h, location: "foobar2000", loaded at 00400000h - 00527000h
Address: 7C80980Ah, location: "kernel32", loaded at 7C800000h - 7C8F6000h
Symbol: "InterlockedDecrement" (+00000000h)
Address: 004B62AEh, location: "foobar2000", loaded at 00400000h - 00527000h
Address: 004A22A0h, location: "foobar2000", loaded at 00400000h - 00527000h
Address: 004376C7h, location: "foobar2000", loaded at 00400000h - 00527000h
Address: 00437C93h, location: "foobar2000", loaded at 00400000h - 00527000h
Address: 004382FCh, location: "foobar2000", loaded at 00400000h - 00527000h
Address: 004B48A8h, location: "foobar2000", loaded at 00400000h - 00527000h
Address: 00437A79h, location: "foobar2000", loaded at 00400000h - 00527000h
Address: 00437A8Fh, location: "foobar2000", loaded at 00400000h - 00527000h
Address: 016AF483h, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 016AF4A2h, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 004F5EE0h, location: "foobar2000", loaded at 00400000h - 00527000h
Address: 016B3FB0h, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 0167373Dh, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 004F5EC8h, location: "foobar2000", loaded at 00400000h - 00527000h
Address: 0164430Eh, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 01657307h, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 016CF234h, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 016B7EF2h, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 016B7ED8h, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 016B2C63h, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 016C8B5Ah, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 016E13F8h, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 4EC936CFh, location: "gdiplus", loaded at 4EC50000h - 4EDF6000h
Symbol: "GdipGetPathGradientFocusScales" (+00000972h)
Address: 4EC93834h, location: "gdiplus", loaded at 4EC50000h - 4EDF6000h
Symbol: "GdipGetPathGradientFocusScales" (+00000AD7h)
Address: 016B2C14h, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 0191003Dh, location: "foo_dts", loaded at 01910000h - 019E0000h
Address: 016C740Eh, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 01659761h, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 0168A8FEh, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 016C9BA8h, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 0168A932h, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 016B8A07h, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 016B2F87h, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 016E35DCh, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 016B8105h, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 016B848Ch, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 016B87E3h, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 015FF024h, location: "foo_discogs", loaded at 01590000h - 01624000h
Address: 016B89CFh, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 7C9032BCh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlConvertUlongToLargeInteger" (+0000007Eh)
Address: 016CA5ABh, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 7C92A9EFh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "towlower" (+000001C9h)
Address: 7C90E46Ah, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "KiUserExceptionDispatcher" (+0000000Eh)
Address: 7C812AEBh, location: "kernel32", loaded at 7C800000h - 7C8F6000h
Symbol: "RaiseException" (+00000052h)
Address: 01643D90h, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 7E41885Ah, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetDC" (+00000193h)
Address: 004C8D95h, location: "foobar2000", loaded at 00400000h - 00527000h
Address: 004CB625h, location: "foobar2000", loaded at 00400000h - 00527000h
Address: 7C9101C0h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 7C9101BBh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+00000117h)
Address: 016AF6DEh, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 016B2BACh, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 01699884h, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 016D0A50h, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 016CE1E4h, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 0164432Fh, location: "foo_dop", loaded at 01640000h - 016FC000h
Address: 01654CC7h, location: "foo_dop", loaded at 01640000h - 016FC000h
Version info:
foobar2000 v0.9.5.3 beta 2
UNICODE
Windows 5.1
Additional info:
SoundTouch DSP 0.1 (SSE)  (foo_dsp_soundtouch)
mslive 0.4.5 (Intel SSE)  (foo_input_mslive)
PopUp Plus 20080423  (foo_popupplus)
Album List 4.2.2  (foo_albumlist)
Misc. Addons 0.1.1 (SSE)  (foo_misc_addons)
ListeningTo 0.1.1  (foo_listeningto)
Track Positioner 1.0  (foo_trackpos)
Lyrics Art Panel 0.057  (foo_uie_lyrics_art)
freedb Tagger 0.6  (foo_freedb2)
Gapless Crossfader 0.3.3.5 (SSE)  (foo_dsp_crossfader)
Reverse Playback 0.1.4 (SSE)  (foo_input_reverse)
Default User Interface 0.9.5  (foo_ui_std)
Masstagger Addons 0.3.4 (SSE)  (foo_masstag_addons)
foo_func 0.1.7  (foo_func)
Masstagger 1.6  (foo_masstag)
True Phase 1.0  (foo_truephase_hq)
Acro WMA decoder 0.1.7.2 (SSE)  (foo_input_wma)
Discogs Tagger 1.13  (foo_discogs)
iPod manager 0.6.0  (foo_dop)
Main window snapping 0.1  (foo_snap)
ZIP/GZIP reader 1.0  (foo_unpack)
APPCOMMAND multimedia key support 0.1  (foo_appcommand)
Tagger Panel Window 1.0.6 [Jan  2 2008 - 15:50:49]  (foo_cwb_hooks)
Facets 2008-02-25  (foo_facets)
Standard DSP Array 1.0  (foo_dsp_std)
Pretty Popup 1.2.3  (foo_prettypop)
Navigator 0.6  (foo_navigator)
Minimize On Close 0.2  (foo_minimize_on_close)
Playlist Bind 3.2  (foo_playlist_bind)
CD Audio Decoder 2.1.2  (foo_cdda)
Autoplaylist Manager 1.0  (foo_autoplaylist)
cwbowron's title format hooks 1.2.6 [Jan  2 2008 - 15:50:05]  (foo_cwb_hooks)
Album Art Browser 0.0.5 [Jul 13 2007 - 10:15:45]  (foo_cwbowron)
ReplayGain Scanner 2.0.6  (foo_rgscan)
VLevel 20060324.0  (foo_dsp_vlevel)
File Operations 2.1  (foo_fileops)
Winamp API Emulator 0.90  (foo_winamp_spam)
DTS decoder 0.1.3 (Intel SSE)  (foo_dts)
Miranda ListeningTo foobar2000 Plugin 1.0  (foo_mlt)
Run services 0.3.3  (foo_run)
Continuator 0.5.0  (foo_dsp_continuator)
Playback Queue Viewer 0.2  (foo_pqview)
Database Search 1.4  (foo_dbsearch)
TLB Remote Control 2.1  (foo_tlbRC)
Extended Variables 0.3  (foo_exvar)
Skip silence 0.1 (SSE)  (foo_dsp_skip_silence)
CD Art Display Interface 2.0 beta 134  (foo_cdartdisplay)
Converter 1.1.1  (foo_converter)
Highlight playing 0.1.0  (foo_highlightplaying)
Lyrics Grabber 0.2.0 Beta  (foo_lyricsgrabber)
Preview 1.2  (foo_preview)
foo_etc 0.10beta  (foo_etc)
Randomized Playlist Entry 1.2.3  (foo_random)
ABX Comparator 1.3.3  (foo_abx)
Quick Tagger 1.0.1  (foo_quicktag)
foobar2000 core 0.9.5.3 beta 2  (Core)
Masstagger Replace 0.0.1  (foo_masstag_replace)
Playlist Tools 0.6.2 beta 6  (foo_utils)
Winamp IPC emulator 0.1.0  (foo_winamp_ipc)
RAR reader 1.1  (foo_unpack)
Menu Addons 0.4 (SSE)  (foo_menu_addons)
Reply #1294
Ok, heres a file that contains 4 copies of the itunesDB and 3 copies of the artwork folder.
http://www.sendspace.com/file/fz6py9
-iTunesDB_clean was generated with no music on the ipod and after I deleted the existing copy so that itunes would make a fresh one.
-The dop_only files were made after transferring 3 tracks to the ipod with the clean database using foo_dop. With this database only, foo_dop detects duplicate tracks and syncs correctly. Also, artwork is transparent.
-For dop_then_itunes , itunes was opened with the foo_dop transferred files in the database. With this database, the duplicates aren't detected by foo_dop and the artwork is fixed.
-itunes_only was made by once again cleaning out the database and generating a clean one. Then, the same three files as before were transferred using itunes. Obviously, foo_dop does not detect duplicates for the sync here and artwork is fine.
I noticed that the artwork files for dop_then_itunes are twice the size of the dop_only and itunes_only ones. My guess is that itunes does not detect the presence of artwork added by foo_dop and adds its own copy, causing duplicate art in the database. This also explains how itunes is fixing the transparent art problem...it just sends a correct copy while ignoring the other one. Keep in mind that the 3 tracks are from one album so only one album cover should be present. I think that mediamonkey is doing the same thing, btw. I hope this is of some help.
Reply #1295
Yes, that is indeed the problem, thanks.
Ah thanks. Seems there's a few issues using "Stop", so don't use it at the moment, I'll fix it for next version.
Thanks, I'll take a look.
Reply #1296
Thanks for another great update!
Recover Orphaned Tracks seems to have found a lot for me. It processed 20 tracks or so, but I'm not sure what.
Is there a way of checking what got added? They didn't seem to go in to my "added last 1 week" smart playlist.
Reply #1297
alphaex32: I got a good lead on the transparency problem from your files, please check version 0.6.1. "Stop" should work OK now (hopefully..). I haven't tackled the sync problem yet though.
I made some other general changes whilst reorganising some code, so try and give all the commands a good thrashing to make sure nothing broke as a result.
I wanted to add a nice report to show what, but I didn't get a chance yet. Note that there will be a dialog showing loads of filenames on the iPod, that doesn't mean anything, it is just scanning it there. If it did add anything, if you go into "Manage contents" they will be at the end of the main list of tracks. They should really be on the smart playlist as well if you left date added as "date added to iPod".
Reply #1298
Whoops, looks like that broke album art. Im getting this error for all the tracks I send:
Failed to add album art for track: Gdiplus error (function: Gdiplus::Bitmap::c'tor, code: 2)
Reply #1299
Ooops, it was broken on iPod touch / iPhone. It should be sorted in 0.6.1.1.
