Topic: iPod manager (Read 2279715 times) previous topic - next topic
[seemingly abandonware] iPod manager
Reply #1025
It doesn't show up anywhere on the iPod? Strange. I'll try something in next build.
BTW: do you actually need the directory lister in preferences? I can split it off into another component if so, but it will be removed from foo_dop.
Reply #1026
I'm not sure what's going on here:
I selected a playlist containing ~14 000+ songs, and went to iPod -> send to iPod. Somehow, it seems to think i have over 4 billion songs lol.
Using v 0.5.6.29 TEST with a 160 Gb iPod Classic.
"Lifting Shadows Off a Dream"
Reply #1027
I ssh-ed into the ipod and the video file did get transferred (its in one of the iTunes_Control/Music/ folders) its just not showing up in video section on the ipod. I checked the music section too, just in case, but its not there either.
Reply #1028
Please try this version. I basically reverted a couple changes from memory that are probably the culprit.
Okay, I finally got the chance to try it out.
The left side of the album art that used to be cropped off is now showing, but the right side remains the same.
Reply #1029
[a href="http://img292.imageshack.us/my.php?image=foodopuo8.png" target="_blank"] Should be fixed in 0.5.6.30.
I made a change in 0.5.6.30; just a stab in the dark so may not have any effect, try it and let me know.
OK, it should be back to how it was in 0.5.6.30.
Reply #1030
Nope, nada. However I noticed something wierd. The video actually shows up on the iPod in itunes, but not on the device itself. It seems that itunes is reading the database differently than the ipod or is reading the files directly. Btw, I tried resetting the ipod to see if that would make it show up, but no luck.
edit: Btw, I noticed that transferring songs still seems to take a while. It seemed like it was faster, but now it appears to be sort of random. Sometimes the art transferring step just takes an unusually long time.
Reply #1031
There was a small error in .30 try .31.
If it still doesn't work, I need a backup of your iTunesDB with the last two things sent to it two videos (one by foo_dop one by something that works).
Also, is the 'numbers under A' thing OK now?
Reply #1032
BINGO! Videos and # sorting are both working now. Im not sure which tag I need to use to distinguish TV Shows from Movies, though.
Reply #1034
Oh, alright. You should probably add that video support info to the field mapping wiki. Now that transferring everything seems to be working, ive been testing out some other stuff. I found that the lyrics support isnt quite working correctly. I use the UNSYNCED LYRICS tag, and they show up, however at the beginning of the text is some code which shows other metadata like artist, title, and date. Also some of the lyrics at the end get cut off. While im on the subject, lyrics field mapping would be nice too. The more database fields you let us map, the better, in my opinion.
Also, album art is still transferring really slowly. This is espcially noticeable when I transfer a whole album, and the art is sent for one file at a time. It seems like it should only be doing that once for a single album, anyway. This gets me worried that maybe the art is taking up a lot more disk space then it needs to because it gets sent for each song individually.
Reply #1035
The iPod reads lyrics directly from the tag. So, shouldn't really be much to do with me, foo_dop is not supplying it with any lyrics. You can try the compatibility mode of id3v2 tagging in foobar2000 if you are still having problems.
No, it should be shared between tracks in the same album according to their metadata (note: this is currently not working for various artist albums).
Reply #1036
Oh, yeah the album I just transferred was a compilation which explains the art. I understand its probably a challenge trying to find the perfect test to differentiate separate compilation albums if they have the same name. Maybe you could have a titleformatting box where we could enter our own code that would return a unique album identifier. For example, since I keep all my albums in separate folders, I could just use %path%
id3v2 compatibility mode fixed the lyrics problem, btw, so thanks for the tip.
Reply #1037
It worked a charm thanks.
I notice on the new version, under the 'iPod Manager' preferences that there is a new database option - numbers last sorting.
You then state (you missed a word by the way) that "(disabling may issues on recent iPod models)".
So unchecking this box will stuff up the iPod? The older versions (when there was no option to chose from) used to have it sort by numbers first or not?
Also, how does the "Ignore leading 'The' when sorting on iPod" work? Does it use the PERFORMERSORTORDER (TSOP ID3v2) tag to store or get it's information from?
Cheers.
Reply #1038
Yes. It doesn't stuff up your iPod but disabling it will cause some oddities with the "scroll by big letters" thing on Classics/Nano 3Gs. So if you don't mind that you can disable it just like previous versions.
No, it just doesn't use any leading "the" in most fields when sorting. So, The Simpsons goes under S.
Reply #1039
I'm curious: is there any chance of integrating Foobar's own "Convert to..." dialog within this plugin (like the "Send to Device" plugin does). That might be an interesting was of solving several issues at one (support for embedded CUE sheets, for example).
Just a thought.
Reply #1040
Sorry to be annoying. I understand what it does, I just don't understand where it holds the decision it has made. Is it stored in the db? Or done on-the-fly?
I like this feature (the removing of the "The") but only on artists and albums, I don't like it applied to songs.
Hence why I have used the TSOA (album), TSOT(title), TSOP(performer) ID3v2 fields to store the way I want it sorted. I use MP3TAG to get rid of the "The" at the start of the artist and album names, but keep the title the same.
Is there any chance of these fields being implemented into your plugin for custom sorting?
I like how you can turn the 'numbers last' sorting off, that's a good feature!
' post='414002' date='Jul 21 2006, 16:13']PS :  I have a few albums called "greatest hits" (by different artists) -- I'm not sure if this is possible, but can you tell the database not to display them all as being in same album "greatest hits" when loading the "albums" view?  Otherwise, I guess I'll have to change my tags...
Also, was this ever answered or developed?
Anyway, thanks for the good progress on this, I'm really enjoying using this now.
Reply #1041
I guess "stored in the db" is the more accurate description.
As far as I can tell, foobar2000 does not support these fields, so I can't use them.
Sort fields like this are supported by the iPod though, at the moment they are calculated automatically based on that preference you mentioned.
So, I can add support for sort fields but they would be different fields to those you mentioned. The question is what to name these fields - either id3v2 like "xxx SORT ORDER" or just "SORT xxx" or ...
Well, definitely some people would be annoyed otherwise..
There was some issues with the iPod relating to this, I'll check what the state of things is on my Classic.
Just a thought.
It's not possible. Chapters are supported for transcoding anyway.
Reply #1042
For sorting with foo_dop, I use "albumartistsortorder" & "artistsortorder". They are Txxx frames, but fb2k reads & writes both tags. I use ID3v2.3 tags for mp3 and mp4 tags on my m4a files.
Surf's Up!
"Columnated Ruins Domino"
Reply #1043
Spaces are good though
I'll probably just use "<fieldname> SORT ORDER" (seems like most likely candidate for the ID3v2 mappings if they ever get added). Probably some remappings too.
Reply #1044
Yes, spaces are good and so are remappings.  I've pretty much given up the idea of using iTunes tagging. fb2k & iTunes tagging co-existing together is a real bear. Now, if only fb2k would recognize m4b files, I'd do away with iTunes entirely. One can only dream, I suppose.
Surf's Up!
Reply #1045
0.5.6.33 released:
  * Now reads play counts from iPod touch/iPhones. So should be able to scrobble those if one desires. Needs testing - check console for errors (file not found is OK unless there are unprocessed play counts).
  * I added the overdue video tagger, accessible from "iPod/Video Properties". It's meant to be used before you send files to your iPod; if you are using it on files on your iPod you will need to additionally use the "iPod/Update metadata in iPod library" command.
  * Sparse artwork handling uses album artist now.
I checked on my Classic with iTunes and it seemed to do it no matter what - sorry.
Reply #1046
i'm too lazy to search this thread to see if this question/request has been asked  , but:
is there a possibility to add a queuing feature to foo_dop when you're in the process of adding files?
right now you get the 'ipod is busy' notification, and if i am going through my music library adding albums one by one, i have to wait until foo_dop is done adding songs until i do it all over again. and again. and again.
Reply #1047
The newest build is causing foobar to crash while its reading the ipod database. Heres the log:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 014D74F4h
Access violation, operation: read, address: 00000CD8h
Call path not available.
Code bytes (014D74F4h):
014D74B4h:  59 5F 5E 83 C4 14 C2 04 00 CC CC CC 6A FF 68 28
014D74C4h:  79 51 01 64 A1 00 00 00 00 50 83 EC 08 56 57 A1
014D74D4h:  A0 80 53 01 33 C4 50 8D 44 24 14 64 A3 00 00 00
014D74E4h:  00 8B F1 8B 46 10 8B 48 04 8B 54 24 24 8D 04 91
014D74F4h:  8B 10 8D 4C 24 0C 51 8B 4E 04 E8 3D EB FE FF C7
014D7504h:  44 24 1C 00 00 00 00 8B 56 0C 52 50 8B 46 08 FF
014D7514h:  D0 C7 44 24 24 FF FF FF FF 8B 74 24 14 83 C4 08
014D7524h:  8B F8 C7 44 24 10 00 00 00 00 C7 44 24 0C 00 00
Stack (0BABF8D0h):
0BABF8B0h:  00000000 00000000 00000000 00000000
0BABF8C0h:  00000000 00000000 00000000 00000000
0BABF8D0h:  90B99967 00000000 00000336 0BABFEAC
0BABF8E0h:  0BF17018 0BABFEE8 01517928 FFFFFFFF
0BABF8F0h:  014FEF52 00000336 0BF17018 0BABFEC8
0BABF900h:  0BABFEF4 01565FA4 014D72A1 0BABF918
0BABF910h:  0BABF914 015146A0 015242FC 01565FA4
0BABF920h:  014D9B10 0BF17018 0BABFEC8 014D2B52
0BABF930h:  0000066D 0BABFF0C 90B99F47 01565EDC
0BABF940h:  01565E68 01565E68 00000000 00000001
0BABF950h:  00000000 00000000 00000000 00000000
0BABF960h:  00000000 00000000 00000000 00000000
0BABF970h:  00000000 00000000 00000000 00000000
0BABF980h:  00000000 00000000 00000000 00000000
0BABF990h:  00000000 00000000 00000000 00000000
0BABF9A0h:  00000000 00000000 00000000 00000000
0BABF9B0h:  00000000 63650000 00000000 746E0000
0BABF9C0h:  00000000 00000000 00000000 00000000
0BABF9D0h:  00000000 00000000 00000002 001501D8
0BABF9E0h:  00000000 00000000 00010000 00000000
Registers:
EAX: 00000CD8, EBX: 0000066D, ECX: 00000000, EDX: 00000336
ESI: 0BABF918, EDI: 00000000, EBP: 0BABF918, ESP: 0BABF8D0
Crash location: "foo_dop", loaded at 014A0000h - 0154B000h
Loaded modules:
foobar2000                      loaded at 00400000h - 00523000h
ntdll                            loaded at 7C900000h - 7C9B0000h
kernel32                        loaded at 7C800000h - 7C8F5000h
COMCTL32                        loaded at 773D0000h - 774D3000h
msvcrt                          loaded at 77C10000h - 77C68000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F02000h
Secur32                          loaded at 77FE0000h - 77FF1000h
GDI32                            loaded at 77F10000h - 77F57000h
USER32                          loaded at 7E410000h - 7E4A0000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7D1D7000h
ole32                            loaded at 774E0000h - 7761D000h
shared                          loaded at 10000000h - 1002A000h
COMDLG32                        loaded at 763B0000h - 763F9000h
IMM32                            loaded at 76390000h - 763AD000h
AirfoilInject                    loaded at 00380000h - 003A8000h
winmm                            loaded at 76B40000h - 76B6D000h
dsound                          loaded at 73F10000h - 73F6C000h
VERSION                          loaded at 77C00000h - 77C08000h
MSCTF                            loaded at 74720000h - 7476B000h
msctfime                        loaded at 755C0000h - 755EE000h
foo_abx                          loaded at 00F20000h - 00F53000h
foo_albumlist                    loaded at 00F80000h - 00FE7000h
foo_appcommand                  loaded at 01010000h - 01026000h
foo_audioscrobbler              loaded at 01050000h - 01080000h
WS2_32                          loaded at 71AB0000h - 71AC7000h
WS2HELP                          loaded at 71AA0000h - 71AA8000h
foo_autoplaylist                loaded at 010A0000h - 010D0000h
foo_cdda                        loaded at 010F0000h - 01125000h
foo_converter                    loaded at 01150000h - 011B9000h
foo_cwbowron                    loaded at 011E0000h - 01208000h
gdiplus                          loaded at 4EC50000h - 4EDF3000h
foo_cwb_hooks                    loaded at 01240000h - 0128C000h
foo_dbsearch                    loaded at 012B0000h - 01320000h
OLEAUT32                        loaded at 77120000h - 771AB000h
foo_dirwatch                    loaded at 01340000h - 0136E000h
foo_discogs                      loaded at 01390000h - 01424000h
foo_dockable_panels              loaded at 01440000h - 01473000h
foo_dop                          loaded at 014A0000h - 0154B000h
SETUPAPI                        loaded at 77920000h - 77A13000h
UxTheme                          loaded at 5AD70000h - 5ADA8000h
foo_dsp_continuator              loaded at 01570000h - 01586000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
MSVCR80                          loaded at 78130000h - 781CB000h
foo_dsp_crossfader              loaded at 015B0000h - 015E0000h
foo_dsp_skip_silence            loaded at 01600000h - 01623000h
foo_dsp_soundtouch              loaded at 01650000h - 01673000h
libmmd                          loaded at 01690000h - 01941000h
foo_dsp_std                      loaded at 01960000h - 019A8000h
foo_dsp_vlevel                  loaded at 019D0000h - 019F4000h
foo_dsp_vst~                    loaded at 01A20000h - 01A42000h
foo_dsp_winamp                  loaded at 01A70000h - 01A93000h
foo_dts                          loaded at 01AC0000h - 01B16000h
foo_etc                          loaded at 01B30000h - 01B67000h
id3lib                          loaded at 01B70000h - 01BFE000h
CLBCATQ                          loaded at 76FD0000h - 7704F000h
COMRes                          loaded at 77050000h - 77115000h
vbscript                        loaded at 73300000h - 73365000h
SXS                              loaded at 75E90000h - 75F40000h
foo_exvar                        loaded at 01C50000h - 01C7E000h
foo_facets                      loaded at 01DA0000h - 01E20000h
MSIMG32                          loaded at 76380000h - 76385000h
foo_fileops                      loaded at 01E40000h - 01E86000h
foo_freedb2                      loaded at 01EB0000h - 01EF1000h
foo_func                        loaded at 01F20000h - 01F5E000h
foo_highlightplaying            loaded at 01F70000h - 01F91000h
foo_input_mslive                loaded at 01FC0000h - 02007000h
WMVCore                          loaded at 15110000h - 1536A000h
WMASF                            loaded at 11C70000h - 11CAA000h
foo_input_reverse                loaded at 02030000h - 0205E000h
foo_input_std                    loaded at 02070000h - 02198000h
foo_input_wma                    loaded at 021C0000h - 021EE000h
foo_listeningto                  loaded at 02210000h - 02220000h
foo_masstag                      loaded at 02230000h - 0227F000h
foo_masstag_addons              loaded at 022A0000h - 022C1000h
foo_masstag_replace              loaded at 022F0000h - 02321000h
foo_menu_addons                  loaded at 02350000h - 023AD000h
foo_minimize_on_close            loaded at 023C0000h - 023D6000h
foo_misc_addons                  loaded at 02400000h - 0243C000h
foo_mlt                          loaded at 02450000h - 0245A000h
foo_navigator                    loaded at 02470000h - 024A1000h
foo_playcount                    loaded at 024D0000h - 024F5000h
foo_playlist_bind                loaded at 02520000h - 02545000h
foo_pqview                      loaded at 02560000h - 0258D000h
foo_prettypop                    loaded at 025B0000h - 025FD000h
mscoree                          loaded at 79000000h - 79046000h
msvcm80                          loaded at 7C4C0000h - 7C53D000h
mscorwks                        loaded at 79E70000h - 7A40A000h
mscorlib.ni                      loaded at 790C0000h - 79BE8000h
mscorjit                        loaded at 79060000h - 790B6000h
rsaenh                          loaded at 0FFD0000h - 0FFF8000h
foo_preview                      loaded at 04A90000h - 04AB1000h
foo_quicktag                    loaded at 04B50000h - 04B8E000h
foo_removefromqueue              loaded at 04BB0000h - 04BBA000h
foo_rgscan                      loaded at 04BD0000h - 04C2A000h
foo_run                          loaded at 04C50000h - 04C7E000h
foo_runcmd                      loaded at 04CA0000h - 04CCF000h
foo_scrobblecharts              loaded at 04CF0000h - 04D23000h
WININET                          loaded at 42C10000h - 42CDF000h
Normaliz                        loaded at 04D40000h - 04D49000h
iertutil                        loaded at 42990000h - 429D5000h
foo_snap                        loaded at 04F70000h - 04F86000h
foo_tlbRC                        loaded at 04FB0000h - 04FD0000h
foo_trackpos                    loaded at 04FF0000h - 0500F000h
foo_truephase_hq                loaded at 05030000h - 0504E000h
foo_uie_albumart                loaded at 05070000h - 050AD000h
foo_uie_bookmarks                loaded at 050D0000h - 05123000h
foo_uie_explorer                loaded at 05140000h - 0517C000h
foo_uie_lyrics                  loaded at 051A0000h - 051FF000h
foo_uie_lyrics_art              loaded at 05220000h - 052CB000h
foo_uie_lyrics_panel            loaded at 052E0000h - 05344000h
foo_uie_panel_splitter          loaded at 05370000h - 053B2000h
foo_uie_quicksearch              loaded at 053E0000h - 05426000h
foo_uie_typefind                loaded at 05450000h - 05480000h
foo_uie_vis_channel_spectrum    loaded at 054A0000h - 054D9000h
foo_uie_vis_projectm            loaded at 05500000h - 0554A000h
OPENGL32                        loaded at 5ED00000h - 5EDCC000h
GLU32                            loaded at 68B20000h - 68B40000h
DDRAW                            loaded at 73760000h - 737A9000h
DCIMAN32                        loaded at 73BC0000h - 73BC6000h
foo_ui_columns                  loaded at 05CE0000h - 05DF9000h
foo_ui_std                      loaded at 05E20000h - 05EE1000h
foo_unpack                      loaded at 05F10000h - 05F3D000h
foo_utils                        loaded at 05F60000h - 05FA4000h
foo_vis_screensaver              loaded at 05FD0000h - 05FFB000h
foo_vis_shpeck                  loaded at 06020000h - 06049000h
foo_winamp_ipc                  loaded at 06060000h - 06082000h
foo_winamp_spam                  loaded at 060B0000h - 060CF000h
System.ni                        loaded at 7A440000h - 7AC3E000h
System.Drawing.ni                loaded at 7ADE0000h - 7AF7C000h
System.Windows.Forms.ni          loaded at 7AFD0000h - 7BCA2000h
PopUpIcons                      loaded at 066C0000h - 066C6000h
WINTRUST                        loaded at 76C30000h - 76C5E000h
CRYPT32                          loaded at 77A80000h - 77B14000h
MSASN1                          loaded at 77B20000h - 77B32000h
IMAGEHLP                        loaded at 76C90000h - 76CB8000h
CoreFoundation                  loaded at 18000000h - 18110000h
WSOCK32                          loaded at 71AD0000h - 71AD9000h
YSFileShim                      loaded at 0AA50000h - 0AA5A000h
icuuc36                          loaded at 0AA60000h - 0AB28000h
icudt36                          loaded at 0AB30000h - 0B237000h
icuin36                          loaded at 0B240000h - 0B2CD000h
pthreadGC2                      loaded at 0B2D0000h - 0B2DF000h
libobjc.i386.A                  loaded at 22200000h - 2229D000h
mslbui                          loaded at 605D0000h - 605D9000h
iTunesMobileDevice              loaded at 0B430000h - 0B544000h
QuickTime                        loaded at 66800000h - 6777F000h
mswsock                          loaded at 71A50000h - 71A8F000h
hnetcfg                          loaded at 662B0000h - 66308000h
wshtcpip                        loaded at 71A90000h - 71A98000h
DBGHELP                          loaded at 59A60000h - 59B01000h
Stack dump analysis:
Address: 01517928h, location: "foo_dop", loaded at 014A0000h - 0154B000h
Address: 014FEF52h, location: "foo_dop", loaded at 014A0000h - 0154B000h
Address: 014D72A1h, location: "foo_dop", loaded at 014A0000h - 0154B000h
Address: 015146A0h, location: "foo_dop", loaded at 014A0000h - 0154B000h
Address: 015242FCh, location: "foo_dop", loaded at 014A0000h - 0154B000h
Address: 014D9B10h, location: "foo_dop", loaded at 014A0000h - 0154B000h
Address: 014D2B52h, location: "foo_dop", loaded at 014A0000h - 0154B000h
Address: 01526F68h, location: "foo_dop", loaded at 014A0000h - 0154B000h
Address: 7C910600h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000002Ch)
Address: 7C90EE00h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+000000FFh)
Address: 7C910500h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+000000C3h)
Address: 7C910700h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000012Ch)
Address: 7C918E00h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlUnicodeStringToInteger" (+0000019Fh)
Address: 7C918DFAh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlUnicodeStringToInteger" (+00000199h)
Address: 7C90D625h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "ZwContinue" (+0000000Ch)
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+00000117h)
Address: 7C9106F0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+00000117h)
Address: 015046EEh, location: "foo_dop", loaded at 014A0000h - 0154B000h
Address: 014DAF9Dh, location: "foo_dop", loaded at 014A0000h - 0154B000h
Address: 014A3AEEh, location: "foo_dop", loaded at 014A0000h - 0154B000h
Address: 014A3C1Fh, location: "foo_dop", loaded at 014A0000h - 0154B000h
Address: 014B2D8Eh, location: "foo_dop", loaded at 014A0000h - 0154B000h
Address: 01522160h, location: "foo_dop", loaded at 014A0000h - 0154B000h
Address: 0152442Ch, location: "foo_dop", loaded at 014A0000h - 0154B000h
Address: 0151CF36h, location: "foo_dop", loaded at 014A0000h - 0154B000h
Address: 014DBF13h, location: "foo_dop", loaded at 014A0000h - 0154B000h
Address: 014CFD1Bh, location: "foo_dop", loaded at 014A0000h - 0154B000h
Address: 7E41A303h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "ClientThreadSetup" (+000002F9h)
Address: 0151CF60h, location: "foo_dop", loaded at 014A0000h - 0154B000h
Address: 014C74ABh, location: "foo_dop", loaded at 014A0000h - 0154B000h
Address: 014C64DAh, location: "foo_dop", loaded at 014A0000h - 0154B000h
Address: 7C80B683h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "GetModuleFileNameA" (+000001B4h)
Address: 7C839AA8h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C80B690h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "GetModuleFileNameA" (+000001C1h)
Address: 014C64D0h, location: "foo_dop", loaded at 014A0000h - 0154B000h
Address: 06080056h, location: "foo_winamp_ipc", loaded at 06060000h - 06082000h
Address: 7C800000h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Version info:
foobar2000 v0.9.5.1
UNICODE
Windows 5.1[
Reply #1048
Ah, should be fixed now thanks.
Reply #1049
Musicmusic,
Sorry if this has been asked before, but does this support the 80 GB and/or 160 GB iPod classics? I didn't see this model in the list of supported iPods, and was just wondering if this will work when I get a 80/160 in a few weeks.
Thanks .
Song List: keikoniumboards.ke.funpic.org/files/songlist.html
