Topic: foo_audioscrobbler 1.4.7 (Read 928044 times) previous topic - next topic
Reply #600
Feature Request: Multiscrobbling, for example libre.fm and last.fm
Reply #601
I think that s not a real problem as you can have listen to the track from myspace for example. You can also download the tracks from there and so scrobble them. Nothing illegal i think?
A new complete album is usually not available to listen to, just one or two tracks. I also assume that you are not allowed to rip the tracks from the website.
People shouldn't have the tracks and listen to them in the first place but we all know that mistakes can happen. Not that I have anything I'm not allowed to have of course ;-)
Reply #602
Quite right. Anyway i dont think that story is a big deal. The only real problem appearing to me is can we really trust LastFM?
Reply #603
Personally I don't believe last.fm have done or would do something like that, it would just completely annihilate their reputation, it's illegal, and they stand to lose far more than they could possibly gain. I have heard some bad things about TechCrunch, like deleting any posts that argue against last.fm leaking this data. The best they can do is say they have 'a source that has proved to be very reliable in the past', WTF does that mean? They have presented no evidence for this, it's just a (very damaging) rumour.
I feel sorry for last.fm, they're pretty vulnerable to this kind of thing, there's nothing they can do except deny it...
Reply #604
"Audioscrobbler: Previous submission still in progress"
this happened after i submitted the scrobbler.log of my DAP with qtscrobbler. after restarting foobar and hitting the submit button under preferences i get
Audioscrobbler: Handshake successful.
Audioscrobbler: Submitting 10 of 31 cached tracks...
Audioscrobbler: Connection error
only way to get rid of this is deleting foo_audioscrobbler and its settings/cache and starting with the fresh component.
since i haven't been using qtscrobbler for a year or so i'm wondering now, if this is an foo_audioscrobbler related issue. but i see, that some similar occurrences have been reported here...
just curious
Reply #605
I'm also getting the same problems, it will scrobble my tracks for awhile then I get the message from the console: "Previous Submission Still in progress"
Any attempt to submit my cache fails with the above message continuing; only after I restart foobar I'm able to submit my cache.
The past version never had this problem, and the submission server seems to be working fine. (but I could be wrong, they do say that it's not totally accurate)
Here is a list of components I have installed if it helps any!
Core (2009-05-21 11:00:50)
    foobar2000 core 0.9.6.7
foo_albumlist.dll (2009-05-21 10:59:10)
    Album List 4.3.1
foo_audioscrobbler.dll (2009-05-07 15:05:28)
    Audioscrobbler 1.4.1
foo_cdda.dll (2009-05-21 10:58:54)
    CD Audio Decoder 2.1.4
foo_converter.dll (2009-05-21 10:58:58)
    Converter 1.2.1
foo_convolve.dll (2006-08-04 21:57:26)
    Convolver 0.3
foo_discogs.dll (2009-04-23 23:02:10)
    Discogs Tagger 1.19
foo_dsp_crossfeed.dll (2006-03-21 16:32:54)
    Crossfeed 0.92
foo_dsp_std.dll (2009-05-21 10:59:10)
    Standard DSP Array 1.0
foo_exvar.dll (2008-06-14 00:42:54)
    Extended Variables 0.3.1
foo_fileops.dll (2009-05-21 10:57:42)
    File Operations 2.1.2
foo_freedb2.dll (2009-05-21 10:58:00)
    freedb Tagger 0.6.1
foo_input_std.dll (2009-05-21 10:58:46)
    Standard Input Array 1.0
foo_lastfm_radio.dll (2009-02-25 23:05:24)
    Last.fm Radio 0.5.6b
foo_mouse_gesture.dll (2008-11-03 15:50:22)
    mouse gesture host 0.4.1
foo_musicbrainz.dll (2009-05-01 12:00:48)
    MusicBrainz Tagger 0.2
foo_out_ks.dll (2006-08-04 21:54:58)
    Kernel Streaming Output 1.2.2
foo_playcount.dll (2009-04-29 20:09:32)
    Playback Statistics 2.1.9
foo_playlist_manager.dll (2007-01-22 13:05:12)
    Playlist Manager 1.0.2
foo_rgscan.dll (2009-05-21 10:58:30)
    ReplayGain Scanner 2.0.8
foo_run.dll (2009-02-11 23:44:52)
    Run services 0.3.5
foo_runcmd.dll (2007-08-16 21:08:42)
    Run Command 1.0 beta 3
foo_ui_columns.dll (2009-02-22 01:42:02)
    Columns UI 0.3.6.7
foo_ui_std.dll (2009-05-21 10:59:16)
    Default User Interface 0.9.5
foo_uie_biography.dll (2009-05-20 21:23:58)
    Biography View 0.2.8.0
foo_uie_console.dll (2008-08-06 06:43:31)
    Console panel 0.3
foo_uie_elplaylist.dll (2009-04-26 14:04:38)
    ELPlaylist 0.6.5.2(beta)
foo_uie_graphical_browser.dll (2008-04-19 21:37:52)
    Graphical Browser rev015
foo_uie_library_tree.dll (2009-04-19 18:16:58)
    Library Tree 0.3.1
foo_uie_lyrics.dll (2008-12-12 11:39:20)
    Lyric Show Panel 0.3.3.9 [Dec 12 2008 - 17:39:01]
foo_uie_panel_splitter.dll (2009-05-09 03:50:52)
    Panel Stack Splitter 0.3.7.4(alpha)
foo_uie_playlists_dropdown.dll (2008-12-08 03:43:24)
    Playlists Dropdown 0.7 beta 1
foo_uie_quicksearch.dll (2007-05-18 14:31:10)
    Quick Search Toolbar 2.8l
foo_uie_textbox.dll (2009-03-26 23:49:28)
    Textbox 0.0.7
foo_uie_trackinfo_mod.dll (2007-01-05 15:36:20)
    Track info panel mod 0.8.0 beta [Jan  5 2007 - 13:36:12]
foo_uie_vis_channel_spectrum.dll (2008-05-18 04:02:12)
    Channel Spectrum panel 0.17.2
foo_uie_wsh_panel_mod.dll (2009-05-05 14:43:38)
    WSH Panel Mod 1.1.7
Reply #606
It'd be really great to have a main menu item that toggled scrobbling and also a track menu item such as "play without scrobbling"  great component!
I double scrobbling on/off button, and menu item, maybe if file has tag field 'no scrobbling' set to '1' then scrobbling could be skipped, same as with foo_skip and SKIP=1 tag
I would like to see something like that too... I really don't like all my audiobooks to be scrobbled. Some field where you can set your custom criteria, so for example if %genre% is "Audiobook" it could skip.
fb2k on OSX: flac q8 > rockboxed Sansa e280v1: Vorbis q5.0
Reply #607
I would like to have a Love/Ban option like the Last.fm client has. Marking songs you love makes it easier to make playlists out of them in Last.fm.
Reply #608
It'd be really great to have a main menu item that toggled scrobbling and also a track menu item such as "play without scrobbling" :D great component!
I'm glad so many people are also after this functionality.  I think last.fm would be a much more useful service if it only scrobbled tracks that contained certain tags, such as %rating% GREATER 2 or NOT %rating% MISSING or  NOT %genre% audiobook or combinations of such.
Reply #609
That's true, plugin will not re-handshake anytime, only after foo restart :/
Reply #610
Yeah, that's what I experienced too after I updated. If I scrobble from my mp3player with qtscrobbler when foobar is running, I get this "previous submission still in progress" which happened before... fix please!
Reply #611
Audioscrobbler: Submitting 10 of 691 cached tracks...
Audioscrobbler: Submission failed: Plugin bug: Not all request variables are set - Invalid Source
Any ideas what I'm doing wrong?
Reply #612
Are these tracks scrobbled from iPod? The same thing happened to me. In my case reverting to an old version didn't work (cache emptied). So here's what not to do.
Reply #613
It's a bug which has been resolved with v1.4.1. Please see this post on how to reset the cache.
Reply #614
doesnt anybody have a mirror of 1.3?
Reply #615
As I already mentioned in the foo_dop thread, last.fm now allows to scrobble multiple plays with one time stamp, which is an improvement in case of scrobbling the songs of an ipod.
Source: http://www.last.fm/help/faq?category=iPod+Scrobbling
On an iPod there is only the last time stamp stored whilst the counter is going up.
According to musicmusic, the developer of foo_dop, it is a change that must be made in foo_audioscrobbler.
Would be a great improvment.
Reply #616
is it possible to let audioscrobbler scrobble multiple plays from my ipod?
itunes can do it so i hope foobar too
Reply #617
Version 1.4.1 was working fine for me until a few days ago... Now it seems stuck at "Audioscrobbler: Previous submission still in progress", even though the handshake and the currently playing tracks work fine. Also QTScrobbler appears to submit tracks without a problem... Any ideas about how to solve this?
Reply #618
The problem appears, if you scrobble from another source (last.fm website, qtscrobbler) when foobar is already running. seems like that foo_audioscrobbler does only do a handshake on startup. problem appeared with 1.4.1, would like to see this fixed too...
Reply #619
I'm not sure it's that, to be honest. I backed up my foobar2000 config file, removed the audioscrobbler settings (losing some 150+ songs in the cache...), reinstalled the plugin,  tried to scrobble anew and it worked. I wonder if the problem has anything to do with the particular tracks that it was trying to scrobble, since it originally got stuck in the middle of a submission (submitted ~30 tracks before getting stuck). Atypical characters in the tag or something, perhaps?
Reply #620
Well, there might be some other ways were it occurs. I just described the way it always happens to me, easily reproducable (for me that is). Did you try a restart of foobar and submitting again before reinstalling?
Reply #621
Oh, yeah, most definitely. Those 150 scrobbles were accumulated over the course of a few days, with several restarts in the middle, since I originally attibuted it to some server-side problem.
Reply #622
I installed the foobar2000 0.9.6.8 portable version on my USB drive, and then installed the foo_audioscrobbler-1.4.1 on the drive also, using my home computer running Windows Vista.
(My office computer doesn't allow .exe files to be run from anywhere but the C: drive, so I copied the USB drive to a folder on C:  It is running Windows XP)
Foobar runs and plays fine.  Audioscrobbler appears to be working fine, but tracks are piling up in the cache and not being submitted.  Hitting the submit button does nothing.
My console gives me the following:
Startup time : 0:00.106843
Opening track for playback: "G:\MP3's\Artists\Blackalicious\Blackalicious - 2005 - The Craft\Blackalicious - 14 - The Craft.mp3"
Audioscrobbler: Request denied (400)
Audioscrobbler: Submitting track...
Opening track for playback: "G:\MP3's\Artists\Ambulance Ltd\Ambulance Ltd - 2004 - Ambulance Ltd\Ambulance Ltd - 01 Yoga Means Union.mp3"
Audioscrobbler: Submitting 2 cached tracks...
Any thoughts on why it isn't working?
I've tried deleting the config file, and reinstalling both elements, but I keep getting the same error.
It works fine from my USB drive at home.
Reply #623
Do you have to use a proxy at work? If so it's probably not letting the submit requests to last.fm through...
np: 4'33"
Reply #624
Foobar 0.9.6.8 + foo_audioscrobbler 1.4.1 = nonstop "Still awaiting handshake"    Net problem? Not, beacause with 1.3.16 - no problems,  fast Handshake successful. Why?
