Topic: foo_audioscrobbler 1.4.7 (Read 930097 times) previous topic - next topic
Reply #175
anyone else's not submitting?
Handshaking: Client up to date.
Handshake successful.
Submission failed: bad authorization.
Reply #176
Works for me.
Reply #177
hmm It's working on this PC of mine, but not the other. Strange.
Reply #178
To everyone who is experiencing the following messages:
[20:23:45] Handshaking: Client up to date.
[20:23:45] Handshake successful.
[20:23:46] Submission failed: bad authorization.
Yes, this is caused by a bug in the current version (v1.3.5) of foo_audioscrobbler in which it does not re-handshake properly. Currently, the only workaround is to close and re-open foobar2000, causing foo_audioscrobbler to do its initial handshake on program launch (which IS done properly).
For those of you who have never experienced this problem, it's very easy to recreate. Simply do the following:
  • Scrobble a track in foobar2000.
  • Leave foobar2000 open and scrobble a track in some other client (for example, the last.fm client).
  • Exit that client and now switch back to foobar2000 and try scrobbling a track. You will receive the error messages above. This is because a re-handshake is needed to re-establish the foo_audioscrobbler<-->last.fm connection that got disrupted by the other_client<-->last.fm handshake from step 2. It is this re-handshake process that foo_audioscrobbler does not do correctly.
I've sent a PM to the author of the plugin so hopefully he will fix this annoying bug soon.
Reply #179
I think my problem was because I was listening on my main computer, then switched to my laptop, streaming music over my network from my main computer.
Reply #180
It is this re-handshake process that foo_audioscrobbler does not do correctly. I've sent a PM to the author of the plugin so hopefully he will fix this annoying bug soon.
Thanks Jugdish for your helpful comments.
I've just released foo_audioscrobbler 1.3.6 which fixes the bug occured when re-handshaking to the submission server.
You can get it via the first post of this topic.
Kind regards,
Florian
Reply #181
Thanks Florian, works great! Those of us who scrobble from more than one client greatly appreciate this update
Reply #182
Works perfect now. Thanks!
Reply #183
Feature request:
Can you make that now playing track info is send to skype's mood, similar to official last.fm player?
Reply #185
Cool. Thanks
Reply #186
hmm wont submit. just keeps caching tracks all of a sudden?
Reply #187
Doesnt work for me even with new version.
Reply #189
Could you guys be a little more specific? Like open the console (View > Console) and see what error messages it's giving.
Reply #190
same as the others. that's why i didn't bother. is there a more verbose log anywhere?
Startup time : 0:00.385400
Submit interval set to 1 seconds.
Submitting 10 of 56 cached tracks to Audioscrobbler...
Submission failed: bad authorization (retrying in 60 seconds).
Reply #191
frnak: That looks like you've got your password entered incorrectly. It is possible to get a "Handshake successful" even with the wrong password because your password doesn't get sent until after the handshake when you start submitting tracks. So the fact that you are able to handshake but not submit makes me think that your password is the problem. Double- and triple-check that you've got it entered correctly.
Reply #192
Not submitting. Cache contains 12 tracks.
Re entered my password and it does the same thing.
Reply #193
it worked itself out, apparently - serverside? thanks for the fast plugin update florian.
edit: it's back? weird.
Submitting 10 of 27 cached tracks to Audioscrobbler...
edit: and its fixed! server-side, sorry about that. required a password reset, for anyone else still having issues. http://www.last.fm/forum/34905/_/278293
Reply #194
Hello, i'm experiencing problems today with the new foo_audioscrobbler 1.3.6
Everything seems ok, but my scrobblings don't appear on my Last.fm page...
I set the correct username and passw, i let foobar.exe pass through the firewall, but i got "Your cache contains 0 tracks" in foobar Preferences, even though the Console says so:
"Startup time : 0:00.612913
Submitting track to Audioscrobbler...
Submission succeeded.
Submission succeeded."
What can i do?
edit: i'm investigating and i now think that is a server-related problem, not a plugin issue
Reply #195
Hmmm... I think that the plugin should send the Album Artist tag to server, not the Artist (or Artist, when the first one is blank). Why? For example: Gling-Gló album by Björk. On last.fm it figures only by Björk, but it has been trully record by Björk & Trió Guðmundar Ingólfssonar.
So - I have it tagged by that way: Artist: Björk, Trió Guðmundar Ingólfssonar; Album Artist: Björk. And IMO it should be scrobbled the way I mentioned, because Last.fm hasn't got the second artist in any album! Next example could be The Lord of the Rings: The Complete Recordings, where on Last.fm it's figures only by Howard Shore, but few track was recorder also by other people (Artist: Howard Shore, Miranda Otto; Album Artist: Howard Shore).
What do you thing about it?
Sorry for my bad english, hope it can be understood.
Reply #196
Please do this - I have the same problem and all I can do is watch last.fm get bad data all day.
Reply #197
I think the best solution would be to add 2 input fields to the foo_audioscrobbler prefs, one for "Artist" and one for "Track", allowing the user to enter TAGZ functions to specify exactly what they want the plugin to send as the artist and track title. This way you could specify either %album artist% or %artist% depending on which you prefer. Plus, you could have it not submit songs that match a certain criteria, by using a TAGZ script that conditionally replaces the artist+track name with an empty string.
Reply #198
That would be sort of the dream solution, but it's been suggested so many times I assume there's some Good Reason why it's not already in.
Reply #199
Feature request:
I think this is already possible using the AMIP component.
AMIP does support sending "now playing" track info to Skype, but it has some serious problem when dealing with unicode characters
