Topic: foo_audioscrobbler 1.4.7 (Read 928091 times) previous topic - next topic
Reply #550
My cache is fileld with 28 tracks and I've get an error:
Audioscrobbler: Submitting 10 of 28 cached tracks...
Audioscrobbler: Submission failed: Plugin bug: Not all request variables are set - Invalid Source
every time I try to submit them.
The fields are their defaults:
[%artist%]
[%album%]
[%title%]
[%musicbrainz_trackid%]
I have same problem. It worked 3 hours ago, I went out and came back > didn`t work anymore.
edit: started to work. something wrong with their servers I guess, but still cant send stuff from cache in last.fm :S
edit2: Wait, it worked for a minute and then not. Foobar says still that as an error.
Reply #551
I have the exact same error, too. I'm not sure but it seems to appear after the synchronization of my ipod. It won't scrobble the cache, and I have to reinstall the plugin and clear the prefs to get it work again.
Thanks for any help.
Reply #552
I also had to do the same thing to solve the error. Now it works
Reply #553
Awesome work man ! Internet streams work perfet for me. I uses standard tags configuration.
Reply #554
I am getting the error of "Audioscrobbler: Previous submission still in progress". I have checked that Last.fm's servers are running. It also seems that it will randmly scrobble cache every few days. Does anyone know how to fix this?
EDIT:
I have managed to get it working it seems so far.
To get it to work you need to first move the compnent out of the components folder then run foobar. Foobar will as if you want to keep the settings for the plugin or if you want them removed. Click to confirm to remove the settings. Once foobar runs close it and put foo_audioscrobbler back into the components folder. Run foobar and do your settings and voila it should work now.
I believe that this happens becuase i'm guessing the old configuration for foo_audioscrobbler is not compatible with the new one and needs to be flushed.
Reply #555
Do you remember how many items were approx. stored in the cache?
I'm also interested in the number of items in the cache of all other scrobblers who are experiencing this issue. It has noting todo with incompatible configurations/caches (I have extra code in the plugin to preserve compatibility between versions) but it's too early to definitely tell what's causing the issue (though I have an idea).
Keep on scroobling!
Reply #556
I had 38 songs in cache.
Reply #557
Since my first post I have had to clear the cache twice, first time had around 600 songs the second time had around 150. When I first posted here in February about the problem I had over 1,200.
Reply #558
I had around 40 songs in cache.
Reply #559
I think it was around 60 tracks. But the problem occurs even with just one song played on the ipod, see the console below:
(I started foobar, the cache was empty and I just synchronized my ipod then clicked "submit", nothing else)
Startup time : 0:02.479901
Audioscrobbler: Handshake successful.
Podcatcher: Checking for new podcasts.
iPod manager: Apple iPod/iPhone connected. Device Instance Path: USB\VID_05AC&PID_1209\000A27001608E873
Audioscrobbler: Importing played tracks from iPod (Rémi)
Audioscrobbler: Finished importing 1 tracks.
Audioscrobbler: Submitting track...
After that the cache continues to fill with the error appearing everytime I click "submit".
EDIT: I can see the current playing track on my last.fm profile but then it won't scrobble (I don't know if it's usefull
Reply #561
about 127
Reply #562
There is bug when submitting an artist with hyphen inside his name. For example:
m-seven - Rebirth is submitted as m - seven - Rebirth, where m is artist name. Should be m-seven for artist.
EDIT:
Bug occurs when listening to online radio.
The separation to artist and title on hyphen is performed by the HTTP stream reader, not foo_audioscrobbler. The only way to fix this would be to append the artist and title fields together and separate them again differently. Or you can request that the HTTP reader's ShoutCast artist/title detection be changed. (They both come as a single field, the client has to separate them according to the hyphen.)
Reply #563
Thanks for pointing this out! I was really wondering what's going on and had no idea how foo_audioscrobbler might have caused this.
Reply #565
OK, I'll try to find my iPod and see whether I can reproduce it here.
Just to say that in my case it had nothing to do with the iPod. The scrobbling was only from foobar. And right now it's happening again. It keeps saying: previous submission still in progress.
Reply #566
Interesting, this simply means that the thread for submitting the tracks is still working on the previous submission and does not accept any new scrobbles at this point. Can you please post the complete console output (wrapped in CODEBOX tags) so that I see at which point it stopped working?
Reply #567
Watching: X:\Completos
Watching: C:\Documents and Settings\Pedro Maciel\My Documents\My Music\Sob Escuta\POSTO
Watching: Y:\Music\Completos
Facet initialized in : 0:00.657
Facet initialized in : 0:01.394
Facet initialized in : 0:00.911
Facet initialized in : 0:00.663
Facet initialized in : 0:00.887
Facet initialized in : 0:00.307
Facet initialized in : 0:03.204
Facet initialized in : 0:00.959
Facet initialized in : 0:01.163
Facet initialized in : 0:00.867
Facet initialized in : 0:01.033
Facet initialized in : 0:01.177
Facet initialized in : 0:00.928
Facet initialized in : 0:00.466
Facet initialized in : 0:01.331
Facet initialized in : 0:02.026
Facet initialized in : 0:01.532
Autoplaylists initialized in: 0:10.951748
"2008-A" : 0:01.483185
"2008-B" : 0:01.602182
"ALBUM" : 0:02.320549
"ASOT" : 0:00.739761
"COMPILATIONS" : 0:00.422292
"EM" : 0:00.199952
"ESCUTA" : 0:00.152943
"GDJB" : 0:00.348877
"IPOD CLASSIC" : 0:00.324544
"IPOD NANO" : 0:00.313417
"MOOD" : 0:00.386215
"MOOD IPOD" : 0:00.162305
"PLAY 2007" : 0:01.246679
"RATING+DANCE" : 0:00.500236
"RATING-DANCE" : 0:00.466387
"TATW" : 0:00.282016
Startup time : 1:47.517879
Opening track for playback: "Y:\Music\Completos\Compilação - Hed Kandi - Swing City\30 - 2 Da Bone.apl"
Reopening played file after update: "Y:\Music\Completos\Compilação - Hed Kandi - Swing City\30 - 2 Da Bone.apl"
Opening track for playback: "X:\Completos\Dj Marky - The Brazilian Job\15 - Kerb Krawler.mp3"
Reopening played file after update: "X:\Completos\Dj Marky - The Brazilian Job\15 - Kerb Krawler.mp3"
Opening track for playback: "X:\Completos\Dj Marky - Workin' The Mix\08 - The 9.mp3"
Reopening played file after update: "X:\Completos\Dj Marky - Workin' The Mix\08 - The 9.mp3"
Opening track for playback: "Y:\Music\Completos\Jeff Mills & Montpellier Philarmonic Orchestra - Blue Potential\07 - Keaton's Theme.mp3"
Reopening played file after update: "Y:\Music\Completos\Jeff Mills & Montpellier Philarmonic Orchestra - Blue Potential\07 - Keaton's Theme.mp3"
Opening track for playback: "Y:\Music\Completos\Compilação - Best Of Mix 2005\03 - Forever More.mp3"
Reopening played file after update: "Y:\Music\Completos\Compilação - Best Of Mix 2005\03 - Forever More.mp3"
Opening track for playback: "Y:\Music\Completos\Compilação - Hed Kandi - Swing City\12 - Anytime (Grant Nelson Remix).apl"
Reopening played file after update: "Y:\Music\Completos\Compilação - Hed Kandi - Swing City\12 - Anytime (Grant Nelson Remix).apl"
Opening track for playback: "Y:\Music\Completos\OST - It's All Gone\08 - Serendipity.apl"
Reopening played file after update: "Y:\Music\Completos\OST - It's All Gone\08 - Serendipity.apl"
Opening track for playback: "Y:\Music\Completos\OST - It's All Gone\03 - Flashdance (Paul Rincon Remix).apl"
Reopening played file after update: "Y:\Music\Completos\OST - It's All Gone\03 - Flashdance (Paul Rincon Remix).apl"
Opening track for playback: "X:\Completos\Dj Marky - Workin' The Mix\07 - Acid Blues.mp3"
Reopening played file after update: "X:\Completos\Dj Marky - Workin' The Mix\07 - Acid Blues.mp3"
Opening track for playback: "Y:\Music\Completos\Compilação - [FTH - OHM] Sexy Sessions - Vol. 1\25 - That Feeling [D-Formation make over vocal remix].mp3"
As you can see, I started foobar (no songs in the cache) and it keeps saying "previous...." since the beginning. I hope this could help
Reply #569
I just tested the fixed version and it's working wonders! Thanks!
When I tried to import tracks from doo_dop, the tracks were successfully imported, but not sent. 17 tracks were added to the cache.
iPod manager: Apple iPod/iPhone connected. Device Instance Path: USB\VID_05AC&PID_1263&MI_00\000A27001D287A70&AAPL0
  Audioscrobbler: Importing played tracks from Dingocat
  Audioscrobbler: Finished importing 17 tracks.
I assumed there would be an error if they couldn't be sent, but there were none.
Upon submitting the cache myself, things were okay, though.
Audioscrobbler: Submitting 10 of 17 cached tracks...
  Audioscrobbler: Submission succeeded.
  Audioscrobbler: Submitting 7 cached tracks...
EDIT: Formatting for clarity.
Reply #570
Great! Thanks for confirming the fix
And yes, foo_audioscrobbler imports tracks from foo_dop to the cache where they're are automatically submitted from the next time you listen music with foobar2000.
Reply #571
Aah, thanks for clarifying. =D
Reply #572
foobar2000 0.9.6.5 beta 2 or above is required to use foo_audioscrobbler 1.4.1.
Please update your foobar2000 installation.
Unfortunately it does not work with foobar 0.9.5.2. Could you Florian upload the old version of your plugin?
Reply #573
i'm still getting "Audioscrobbler: Submission failed: Plugin bug: Not all request variables are set - Invalid Source" with 1.4.1
are the tracks that were added to the cache in 1.4.0 gone for good? or should they be able to be sent with 1.4.1
Reply #574
It's the former unfortunately. You should be able to reset the cache via 'Preferences > Tools > Audioscrobbler > Reset Page'.
