Topic: Nero Releases FREE Reference Quality MPEG-4 Audio Encoder (Read 476519 times) previous topic - next topic
Reply #425
New Version (1.0.0.2) is out, get it from:
http://www.nero.com/nerodigital/eng/down-ndaudio.php
I'm just encoded file with new neroaacenc... neroaacenc.exe -q 0.425 -lc -if xxx.wav -of xxx.m4a
CoolEdit recognized xxx.m4a as a AAC-HE and it's sounded like a average AAC-HE...
I'm think it is a side effect of "Backwards compatible signalling of SBR and PS Audio Object Types
(also when LC is used for encoding) for improved 3GPP Compatibility"
... but why it's affect the playback quality of winamp/cooledit?
...and I've just discovered that the new version produces .m4a that my Shuffle won't play, whereas previous version with the same settings did. This evening I'll try experimenting with the command line switches and tagging to see if it makes a difference. Can anyone else with a Shuffle verify this? I tried various -q and used the recommended command line settings for foobart2000.
Reply #426
will check it ASAP, but first try running mp4creator -optimize *. m4a (get it at rarewares.org). the shuffle won't read files which have the tag data at the end.
Which version of foobar did you use to produce your files? foobar2000 0.9 does tagging when converting but it attaches them to the end
Marcin
Reply #427
Marcin
I'll try it this evening. I'm using 0.9.1, which is what worked with the previous version of the nero encoder. (I should just mention that iTunes displays and plays the files fine.) I'll also try encoding without foobar, to see if it is causing the problem.
I'm keen to get this working, because the Nero encoder sounds excellent to my ears.
Reply #428
I've never seen such a brilliant progress display before
Anyway, I like the codec, the results have surprising quality and, imporatnt to me: Searching is extremely fast.
Reply #429
Old FAAD2 just reads that info incorrectly, nothing to worry about, the file is LC
Reply #430
Marcin
Marcin, you're brilliant!  mp4creator -optimize did the trick. I'll go that route.  Out of interest, I noticed that with the "unoptimized" files, that the Shuffle would finally play each one after a pause of several minutes. Not sure why the shuffle needs to read the tags, since it has no where to display the info.
Reply #431
My Settings in EAC for encoding and tagging with nero are:
user- defined encoder, file ending .m4a
Program used:
C:\Windows\system32\cmd.exe
additional commands:
/c C:\path\to\neroaacenc.exe -q 0.425 -if %s -of %d && C:\pat\to\Neroaactag.exe %d -meta:artist="%a" -meta:album="%g" -meta:track="%n" -meta:title="%t" -meta:genre="%m" -meta:year="%y"
You might want to change the paths according to your personal preference
thx, i'll give it a shot
this isn't working for me, i get a message saying that the external compressor returned an error.  any ideas on why this might be?
Reply #432
Are you typing yuor paths correctly?, if your paths to the encoder and tagger have spaces (like having C:\Exact Audio Copy\neroaacenc.exe), you need to put the whole path in quotes.
Reply #433
there we go, that was the issue.  thanks so much
Reply #434
Not just info, faad decoded & new neroaacdec decoded raw pcms differs by values... That values can't be described as a round errors... and this difference audible for me (at least @ -q 0.5), MP4 created by neroaacenc v1.0 and decoded by old&new neroaacdec and faad tied within acceptable round errors... I don't understand why bring this.. "signalling" thing for AAC-LC... iTunes properly encoded & decoded AAC-LC, mono as a mono, stereo as stereo without any "signalling". Why not use more compatible way for this like a Apple did?
Reply #435
help... I'm trying to convert WMA -> WAV -> AAC by piping ffmpeg -> nero's CLI encoder...
I tried with nerodigital 1.0.0.2, and here's my result.:
C:\ffmpeg>ffmpeg -i INPUT.wma -acodec pcm_s16le -f wav - | neroaacenc_sse2 -q 0.
28 -ignorelength -if - -of output.mp4
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
  configuration:  --enable-theora --enable-mp3lame --enable-libogg --enable-vorb
is --enable-faad --enable-faac --enable-xvid --enable-x264 --enable-mingw32 --en
able-a52 --enable-dts --enable-pp --enable-gpl --enable-memalign-hack --enable-a
mr_nb --enable-amr_wb
  libavutil version: 49.0.0
  libavcodec version: 51.1.0
  libavformat version: 50.0.0
  built on Jan 29 2006 03:34:22, gcc: 4.0.2
Input #0, asf, from 'INPUT.wma':
*  Nero Digital Audio Reference MPEG-4 & 3GPP Audio Encoder *
*  Copyright (C) 2006 Nero AG                               *
  Duration: 00:41:10.4, start: 0.608000, bitrate: 20 kb/s
  Stream #0.0: Audio: wmav2, 22050 Hz, mono, 20 kb/s
Output #0, wav, to 'pipe:':
  Stream #0.0: Audio: pcm_s16le, 22050 Hz, mono, 352 kb/s
Stream mapping:
  Stream #0.0 -> #0.0
*  All Rights Reserved Worldwide                            *
*  Package build date: May  1 2006                          *
*  See -help for a complete list of available parameters.   *
[color=red]ERROR: could not parse WAV file[/color]
size=  106376kB time=2470.0 bitrate= 352.8kbits/s
video:0kB audio:106376kB global headers:0kB muxing overhead 0.000040%
Problem with piping?  'cause I tried:
> ffmpeg -i input.wma -f wav temp
> neroaacenc_sse2 -q 0.28 -ignorelength -if temp -of output.mp4
and it works... Nero's problem or XP's piping problem?
Thank you.
Reply #436
Sweet! This was worth the wait. I've got it working except how do I set the iTunes compilation filed to true or false? I tried -meta-user:compilation="true" or ="false" but that did not work. Any ideas? Thanks!
Reply #437
-meta-user:itunescompilation=1
Reply #439
It does not, the big ipod also does not read tags, everything is stored in db files, but The shuffle knows which track it is playing - you can sync it with last.fm via amarok (i do it that way). If you are using iTunes there is also a problem with streaming back-tagged m4a files. When you are on windows use tag&rename to tag your files it's the only one working for me. On linux no solution (exept tagging and optimizing)
btw. does anyone know a method to optimize so it does not change its creation time (mp4creator does it through a temp file) i need it because amarok rea-dds optimized files to your collection.
Reply #440
Thanks! And 0 for if it is not one?
If it's no compilation then the field should not be used at all or removed, but maybe setting it to zero has the same effect.
Mp3tag v2.36 now also puts the atoms at the beginning and it also has the optimize feature.
It should also keep the creation time.
Reply #441
The chapters support is just wonderfull.
but as someone mentioned. it would be nice to be able to rip into on .wav and then refer to the cue sheet for th chapter info.
wouldn't that also be more precise regarding where to put the chapters points ?
How does chapter support work in winamp ?
Sven Bent - Denmark
Reply #443
Is it possible to write into .3gp with this encoder?
Reply #445
is there a way to make it use more cpu pwoer to improve quality.
psytell encoder once had such a switch  believe it was -production
beacuse wit the speed it as nowm i would gladly pay up to 50% more encoding time for a "5-10% more quality"
Also SMP support ?
Sven Bent - Denmark
Reply #446
Don't even mention that antique. ;-)
It's not easy to trade CPU power for better encoding. The only thing off the top of my head is using better, slower quantizer and having a variety of them, like LAME.
Anything else is just tuning and won't use more CPU.
ruxvilti'a
Reply #447
Also SMP support ?
Use a higher setting, and ABX.
Reply #448
why is PNS non activated still?
Reply #449
Given a file encoded with the Nero encoder, is it possible to find out which version of the encoder was used to encode it ?
