Topic: foo_uie_quicksearch (Read 667534 times) previous topic - next topic
foo_uie_quicksearch
Reply #126
I think I have found out how to reproduce this. It seems as though the searchbox doesn't clear itself.
Type something in the searchbox, double click it to highlight it and try typing something over it.
foo_uie_quicksearch
Reply #127
I may sound stupid now, but... how do I dock it?
I assume it is possible since there are mentions of an "undock" feature (and I've seen screenshots showing it docked), but I couldn't dock it in any way I tried...
I'm using foobar2000 v0.9.2 beta 3 and foo_uie_quicksearch 2.0.
Thanks a lot!
foo_uie_quicksearch
Reply #128
Great plugin! I've been waiting for 0.9 ever since you made it available for 0.8.
A few things however
- Nowhere to change font in 0.9 version as suggested in the changelog
- pressing Reset to reset Tagz and then hitting Cancel resets them anyway
- if search string is wider than the the actual panel and you keep typing, the text doesn't shift to the left as it normally would with any other textbox. Try in any small textbox to get the idea.
- would be nice to see the text align in the middle of the panel. Right now it sticks to the top. Not sure whether it's a design flaw or just left to be done later.
I'm on XP SP2.
If those things were already mentioned, please don't yell.
foo_uie_quicksearch
Reply #129
Been eyeing this for awhile. Keep up the good work, Nemo and thanks for the port.
f to c to f to c
foo_uie_quicksearch
Reply #130
tried to reproduced it hear with 2.0 but still no bug. It must have to do with something else than the plugin:)
foo_uie_quicksearch
Reply #131
Hmm. What might it be then?
foo_uie_quicksearch
Reply #132
I have the same problem, also delete and backspace doesn't clear the characters.
foo_uie_quicksearch
Reply #133
OK, regarding the overwriting problem on typing a couple of characters, the text turns bold, almost as if the box has rewritten itself without clearing initially (though if I try to delete the characters before they turn bold they will still not delete so I'm assuming that the problem occurs after the second key press).
I've tried removing components to see if the problem was there, but no luck, perhaps it has to do with chipset, I'm using an Athlon FX-51 (essentially an AMD 64),  on my other computer, which is a non 64 bit processor (but still an Athlon), the problem does not occur on either 0.9.1 or 0.9.2, perhaps the 64 bit could be a contributing factor (though I'm pretty sure I'm clutching at straws)?  The Foobars are set up in exactly the same way.
foo_uie_quicksearch
Reply #134
I have AthlonXP with KT600 chipset, and the same...
foo_uie_quicksearch
Reply #135
I have an AMD 64 with no problem. But i must point out that i have a 32 bit winXP
foo_uie_quicksearch
Reply #136
Mine's a AMD Duron 1800 KT333 chipset (ancient), if that helps.
foo_uie_quicksearch
Reply #137
Version 2.1 will fix this issue. Please redownlaod from first post.
Note : Users of version 2.0 should manually remove the dll from their foobar components directory before installing any new version. [Valid dll's should be named foo_uie_quicksearch.dll , not foo_uie_quicksearch V.x.dll ... my bad.]
foo_uie_quicksearch
Reply #138
Thanks! This plugin is great!
foo_uie_quicksearch
Reply #139
Thanks a lot!
Good question!
foo_uie_quicksearch
Reply #140
Feature Request.
Could there be an option to auto focus the search result playlist after successful search.
foo_uie_quicksearch
Reply #141
Thanks a lot!
Okay, discovered myself: I was using an outdated version of Columns UI, I updated it and now it's fine
foo_uie_quicksearch
Reply #142
great plugin. keep up the good work
foo_uie_quicksearch
Reply #143
Hello all !
Great plugin indeed, nice work Nemo !
I'm having the same problem frankthechicken and others have reported concerning the non-clearing of the search box. I'm using foobar 0.91 with the latest Columns UI (0.1.3 beta 1v5). Windows XP SP2 Fr on a HP NC6120 Laptop (Intel 915GM)...
Hope this can help (?) and keep up the good work!!!
EDIT: Using Quicksearch 2.1 btw
foo_uie_quicksearch
Reply #144
Same problem here, non-clearing of the searchbox.
Using foobar 0.91, Columns UI 0.1.3 beta 1v5 and Quicksearch 2.1 (AMD palermo, windows xp sp2)
p.s) It clears when check 'Reset search string when successful' in Preferences.
but if not checked (by default), characters starts overlapping.
foo_uie_quicksearch
Reply #145
!!! Urgent !!!
please someone tell me how i can configure quick search to display in a playlist i create instead of making a new one with the search text i typed in. Pretty much i want it to go to a playlsit that says Search Results instead of "Search Results Jimi Hendirx Axis Bold As Love"
Thank you.
foo_uie_quicksearch
Reply #146
!!! Urgent !!!
Thank you.
go to Preferences - Search Results and History - Target Playlist
and fill it with 'Search Results'
and check off 'Append search string to playlist name'
foo_uie_quicksearch
Reply #147
[a href="http://img139.imageshack.us/my.php?image=fd8dz.jpg" target="_blank"]
foo_uie_quicksearch
Reply #149
Great Plugin so far, but here's a feature request: can you add an option for simply playing the first matching item instead of putting all matching items into a new playlist?
