Topic: Unable to upload file (Read 3933 times) previous topic - next topic
Hello!
I just wanted to upload a sample to the Upload forum using Firefox, but everytime I submit the form, Firefox reports that the connection was reset while the page was loading. I also tried to use IE, but I received the Not Found message. Any idea what might be causing this? I have no problem uploading files to other IPB 2.1.5 forums.
Regards,
Sebastian
PS: The file is WavPack and has 4 MB.
The limit is exactly 4M.
Upped to 10M.
Still doesn't seem to work.
Did you change the limit in IPB only? Maybe upload_max_filesize in the PHP configuration is set to accept files with less than 4 MB, too.
There is no limit set in IPB and in the post above I did in fact adjust the PHP setting.
Edit: Try again, changed Apache config.
I just tried to upload an 1.7 MB WavPack file (pink noise) and I received the error after about 20 seconds.
Probably because I just restarted the webserver
OK, uploading. Will edit this post once the file was uploaded or I received an error. Will take sometime, though - my uplink is only 24 KB/s.
Worked. Thanks Garf!
