Topic: Foobar playlist format (.fpl) description? (Read 15980 times) previous topic - next topic
I've been hunting for awhile for a description of the .fpl playlist format.  I've got a 'classical music jukebox' program that shuffles classical playlists (in bland old m3u format)  while keeping different parts of works grouped together; I'd like to use the additional info in .fpl playlists (especially the duration, if it's saved!) for more features.
I found this Perl script when I searched the board
http://tate.undef.jp/read-fpl.txt
but a test playlist I saved doesn't seem to fit in with what this expects, at leas as I understand it from my very-rusty Perl knowledge!
Unless I'm mistaken, there ought to be a 4 byte identifier, followed by 4 byte count of rows, followed by the first row with a 4-byte file type number and 4 bytes for the length of the subsequent string.  What i observe is a 20-byte block before the first string, instead of 16, none of which seem to relate to the size of the string.  Also, the initial identifier is 0xE1 A0 9C 91 instead of 0x 82 68 D0 E3.
Any links to some document with a quick description would be helpful :-)
-Zac
i know that the new developer of 'mpeg audio catalogue' has made delphi components for reading and writing fpl playlists ...
Delphi?  Good gravy, lol.  You mean this?
http://www.dv.co.yu/mpgscript/mpgtools.htm
Hmm, this stuff doesn't look like it's been updated since 1999, so I don't think.fpl support's included with this version.. Is there a newer link?
-Zac
no, this one: http://mac.sourceforge.net/
Ah, thanks for the link.  I looked it over, and it appears to pretty much be wrong, too.  The format must have changed with the most recent release.  Here is what I have ascertained thus far for the format:
A) First 16 bytes always the same (E1 A0 9C 91 F8 3C 77 42 85 2C 3B CC 14 01 D3 F2)
B) A 4-byte value indicating the length of the following string (bigendian)
C) An extremely long string, containing filenames beginning with file://, and followed by field names and field name values seperated by 00.  Sometimes the values follow the names, sometimes they don't, sometimes there are values and no names.  Sometimes, blocks of values follow blocks of names.  I don't understand this.
D) After the string is a 4-byte value indicating how many items are in the playlist.
E) Next is what seems to be a long list of data, with each info block starting with the sequence 00 01 00 00.
Beyond this I'm at a loss.  I can't find any reference to the #samples or the total time in seconds or miliseconds, so I'm not sure what to do.  I'll note that each block of info is very sparse, with lots of 0 bytes, suggesting almost everything there is a small-valued integer.  Dunno what those integers mean, however.
-Zac
(who now has a headache...)
As far as I can remember, duration info is not stored. It's been a while though since I wrote that component. It should be fairly easy though to update it to support 0.9.
Looks like it will involve a bit of substantial updating; the playlist file now stores replaygain and duration info.  I have figured out a big part of the formatting I think:
After the list of filenames and tags etc. you have a big block of numbers.  The first byte is the count of items in the playlist.  For each file there is then a sequence of 53 bytes consisting of the following sequence:
A) 4 byte integer, unknown meaning.  Seems to be a single-digit integer value, often 1 or 3
B) 4 byte integer, unknown meaning.  Varies depending on location in playlist.
C) 4 bytes, always 0?
D) 4 byte integer specifying the file size
E) 4 bytes, always 0?
F) 8 bytes, unknown meaning
G) 8 byte floating point value representing duration in seconds
H) 4 bytes, probably floating point album replaygain value (7AC4 = -1.00 if none)
I) 4 byte floating point representing track replaygain value (7AC4 = -1.00 if none)
J) 4 bytes, probably representing an album peak value (80BF = 1.00 if none)
K) 4 byte floating point track peak value (80BF = 1.00 if none)
L) 1-byte integer representing the number of 4-byte integers following
After L comes a varaible number of integer values whose meaning is unknown to me.  All the numbers are very low.
I hope this is useful to someone besides me, and that they don't change it again on the next release :-P
-Zac
(feeling a bit like an archaeologist)
Attempting to resurrect this thread. =)
So, is there any chance of getting an official description of the format?
I'm trying to write a Python-based HTTP streaming server that could use the FooBar2000 database as its library source. So far, I've, thanks to Zacw's efforts, managed to read the "data section" and the item count correctly, but after that, I've no idea what's going on.
Double-post and all, but a couple hours of hacking has brought me to a state where I can now read all the items from the file... but the "integer table" is still a mystery for me. I'm _guessing_ it's some sort of a pointer table (key, value, key, value) to the global string table (henceforth "data table") on the top of the file, but the offsets don't quite make sense. See for yourself: this is the dump from my program so far.
It can read the header, the data table and split/enumerate its entries (since they all seemed to be \0-delimited):
Data length: 617
Data entr.s: 50
  0 : file://H:\whatever\M-FLO\m-flo astromantic\06 m-flo - way u move (dragon ash).mp3
  1 : album
  2 : artist
  3 : comment
  4 : date
  5 : genre
  6 : title
  7 : tracknumber
  8 : astromantic
  9 : m-flo
  10 : --==More Volume Please==--
  11 : 2004
  12 : Hip-Hop
  13 : way u move (dragon ash)
  14 : 6
  15 : enc_delay
  16 : 576
  17 : enc_padding
  18 : 1440
  19 : mp3_accurate_length
  20 : yes
  21 : bitrate
  22 : 192
  23 : codec
  24 : MP3
  25 : encoding
  26 : lossy
  27 : channels
  28 : 2
  29 : samplerate
  30 : 44100
  31 : mp3_stereo_mode
  32 : stereo
  33 : tool
  34 : LAME3.92
  35 : codec_profile
  36 : CBR
  37 : tagtype
  38 : id3v2|id3v1
  39 : file://E:\Music\mp3\Minotaur Shock\Chiff-Chaffs & Willow Warblers\04 Minotaur Shock - Moray Arrival.mp3
  40 : Chiff-Chaffs & Willow Warblers
  41 : Minotaur Shock
  42 : 2001
  43 : Electronic
  44 : Moray Arrival
  45 : 04
  46 : 2004
  47 : 204
  48 : extrainfo
  49 : VBR
Then it begins enumerating the items, which it does properly (at least the file sizes and durations both seem to be correct):
<__main__.FPLFile instance at 0x00A455A8>
  albumpeak -1.0
  dtn   49
  duration 490.56
  rgalbum   -1000.0
  rgtrack   -1000.0
  size 11776995
  trackpeak -1.0
  unk1 1
  unk2 0
  unk3 0
  unk4 0
  unk5 128107706786250000
252 bytes read, offset 37d
8:10
But then comes the "item table" (the low integer values Zacw mentions). I think this is a key-value mapping of some sort, indexing the data table. This would make sense, since a playlist is bound to contain many instances of the same string. Then again, this limits the amount of unique strings to.. a bit over 4 billion. 2^32.
The first four entries seem bogus, perhaps 4 (edit: or 5) more unknowns added since Zacw's studies (which reminds me: The item table item count is not one byte, but four.) If four, this would set entry #5, or "82" in our example, as the first real data entry. It would then make sense that this is the pointer for the actual file path, and the rest are key-value pairs. However, like my script says, the data table does not have entry #82, so there's some other magic going on. Also, both files quote 82 as itemdata #5. (The first three entries do change though.)
00007 tracknumber
00012 Hip-Hop
00022 192
00000 file://H:\whatever\M-FLO\m-flo astromantic\06 m-flo - way u move (dragon ash).mp3
00082 <not found>
00001 album
00088 <not found>
00002 artist
00095 <not found>
00003 comment
00103 <not found>
00004 date
00108 <not found>
00005 genre
00114 <not found>
00006 title
00120 <not found>
00007 tracknumber
00132 <not found>
00144 <not found>
00150 <not found>
00177 <not found>
00182 <not found>
00190 <not found>
00214 <not found>
00216 <not found>
00226 <not found>
00230 <not found>
00242 <not found>
00247 <not found>
00267 <not found>
00271 <not found>
00279 <not found>
00283 <not found>
00289 <not found>
00293 <not found>
00302 <not found>
00308 <not found>
00317 <not found>
00319 <not found>
00330 <not found>
00336 <not found>
00352 <not found>
00359 <not found>
00364 <not found>
00373 <not found>
00387 <not found>
00391 <not found>
00399 <not found>
And, as you can see, there's a lot of entries in the item table.
The correct data for this file is:
Artist Name : m-flo
Track Title : way u move (dragon ash)
Album Title : astromantic
Date : 2004
Genre : Hip-Hop
Track Number : 6
Comment : --==More Volume Please==--
Here's the next file, for comparison and fun.
<__main__.FPLFile instance at 0x00A45670>
  albumpeak -1.0
  dtn   44
  duration 308.813333333
  rgalbum   -1000.0
  rgtrack   -1000.0
  size 7876736
  trackpeak -1.0
  unk1 1
  unk2 411
  unk3 0
  unk4 0
  unk5 127327008231875000
232 bytes read, offset 465
5:8
00006 title
00011 2004
00019 mp3_accurate_length
00082 <not found>
00001 album
00088 <not found>
00002 artist
00103 <not found>
00003 comment
00108 <not found>
00004 date
00114 <not found>
00005 genre
00120 <not found>
00006 title
00515 <not found>
00546 <not found>
00561 <not found>
00566 <not found>
00577 <not found>
00591 <not found>
00216 <not found>
00226 <not found>
00230 <not found>
00594 <not found>
00247 <not found>
00267 <not found>
00271 <not found>
00599 <not found>
00283 <not found>
00289 <not found>
00293 <not found>
00302 <not found>
00308 <not found>
00317 <not found>
00319 <not found>
00330 <not found>
00603 <not found>
00613 <not found>
00336 <not found>
00352 <not found>
00391 <not found>
00399 <not found>
The correct data here is
Artist Name : Minotaur Shock
Track Title : Moray Arrival
Album Title : Chiff-Chaffs & Willow Warblers
Date : 2001
Genre : Electronic
Track Number : 04
I hope someone can make some sense of this data. I'll try and continue hacking tonight and tomorrow and so on.
Would, of course, be nice if someone (=the developer of FB2k) would come up with some official documentation on the file format. I found the m3u and m3u8 (what's that anyway?) exports lacking - only the filename? ._.
is this still relevant to anyone? I reverse engineered the .fpl format and also the foobar.dat.
Everything can be read and processed with my java code here:
https://github.com/tfriedel/foobar2000-export
At the moment the default is to convert .fpl to .m3u files, but you could read all the other metadata and do something with it. Have fun!
cygn
As I just googled this topic - this is relevant e.g. for me  )
Hope that your foobar2000-export tool can help to rearrange/edit some of my old fpls properly, according to path/filename changes of involved media files.
Built-in foobar2k 'fpl-m3u' conversion is not the way in my case because of data loss: e.g. all the fpl entries which are, in their turn, related to selected entries from cue files - in m3u just will be replaced by corresponding number of lines simply representing cue sheet filenames.
As I see your tool allows direct fpl edition.
But there are source code archives only available by the given link.
So can you give any clue how to use your tool for 'general windows user'?
Thank you
cygn
Thank you
Hi beb,
first I want to say, this is not intended as tool for 'general windows users', but for programmers who want to make their own software and need to handle foobar files.
But if you are fit on the command line, you can use it to convert fpl to mp3. I compiled the whole thing for you here:
http://dstats.net/fwd/yopqm
unzip it, then run cmd.exe, change to the directory containing the .jar file and run java -jar foobarConverter.jar playlist.fpl output.m3u
This will convert one foobar playlist to an m3u playlist.
My code doesn't support editing or writing fpl's. Not all bits of fpl files are understood and needed to export them. It might be not that hard to implement writing fpl files, but I don't need it now, so I'm not working on it.
I can however answer questions if somebody wants to do it, if it's not apparent from my java source code.
So unfortunately for your use case, I think it's not much help. But have you tried opening the playlist in foobar2000 and using the "revive dead items" from the edit menu? It's supposed to fix moved files.
...first I want to say, this is not intended as tool for 'general windows users', but for programmers who want to make their own software and need to handle foobar files...
Hi cygn,
Thank you for reply. The situation has been clarified enough.
I've been disappointed a bit by now, still hoping for better times to edit fpl will come )
Thanks anyway and best regards!
Forgive my bad english.
if I understand correctly this is already doing everything they want
klick
Built-in foobar2k 'fpl-m3u' conversion is not the way in my case […] can you give any clue how to use your tool for 'general windows user'?
I’ have doubts that either foobar2000-export or AmoK Playlist Copy (which also comes in English) is appropriate for your case. What about foo_playlist_revive?
For anyone directly wondering, the .fpl is intentionally not defined so that Peter can make compatibility-breaking optimizations to the format as necessary as the speed of format is essential to the speed of the program.
For users wishing to use their playlists across different software, saving the playlists as .m3u(8) is really your best (and really only) option. Of course, that has its own limitations (e.g. cuesheet compatibility, speed).
For developers of components, know that you can make full, proper use of the .fpl format through the documented APIs.
For developers of other software looking to reverse-engineering such things, understand that a) such things are not generally well regarded for the above reasons, and that b) you know exactly what are doing, that things may break as deemed necessary for fb2k and that in the end you maybe hassling yourself and users more than helping them. [edit]That may sound more threatening than I intended--I'm a lowly forum mod and in certainly no position to be threatening anyone--but I would consider my words an appropriate guideline.
elevatorladylevitateme
