Topic: foo_cwb_hooks (Read 304774 times) previous topic - next topic
foo_cwb_hooks
Reply #175
Excellent upgrade. Thanks a lot cwbowron
foo_cwb_hooks
Reply #176
Chris,
Thanks for a very useful plugin. I have one question though. I've just upgraded from v1.0.13 to v1.0.14, and while the %cwb_activelist_count% variable does now update when the contents of the playlist changes, it shows zero doesn't have a value when no track is playing. Is this deliberate? I'd like to be able to see the total number of tracks in the active playlist even when I'm not playing one.
Thanks,
Chris
foo_cwb_hooks
Reply #177
Could you consider adding this?
Basically I'd like REGEXP support in $str_replace (you'd probably call it $cwb_str_replace then) or a function to to exclude all non-readable characters but linebreaks, tabs and spaces.
Displaying tags which are automatically downloaded is often a mess and if for example using %lyrics% tag in trackinfo_panel_mod I'd like it as clean as possible without validating every filetag.
foo_cwb_hooks
Reply #178
Thanks for the update. Is %cwb_index% (for selected, eventually not playing track) possible?
foo_cwb_hooks
Reply #179
could be easily implemntable via PCRE http://www.pcre.org/.
But is for sure way to big to be part of cwb_hooks
maybe someone wants to do foo_pcre?
foo_cwb_hooks
Reply #180
am i doing something wrong?
$cwb_fileexists($replace(%_path%,%_filename_ext%,)folder.jpg)
displays unknown function
i just want to check for album art
foo_cwb_hooks
Reply #181
your string $cwb_fileexists($replace(%_path%,%_filename_ext%,)folder.jpg)
work here ( display 1 if file exist else nothing)
Music is my first love.
foo_cwb_hooks
Reply #182
try this: $cwb_fileexists($replace(%path%,%filename_ext%,folder.jpg))
foo_cwb_hooks
Reply #183
could you add a "$cwb_readfile()" ?
that would be very great for artist bio or album descriptions.
foo_cwb_hooks
Reply #184
sorry didnt have latest version.
Is there a way to get foo_run to execute cover downloader automatically if an album art doesnt exist?
foo_cwb_hooks
Reply #185
In columnsUI there is the statusbar option to:
"Show selected tracks total length, accurate to X decimal places"
What about a %cwb_playinglist_length% and a %cwb_activelist_length% that do similar things for the entire playlist?
elevatorladylevitateme
foo_cwb_hooks
Reply #186
Excellent plugin. Really a must. Thx a lot.
Would it be possible to also have
%cwb_activelist_size% - size in bytes of the active list
for convenience, it could be useful to add also the pending %cwb_playinglist_size%
useful when exporting lists to external devices such as mp3 players.
foo_cwb_hooks
Reply #187
Could you add a way to get information for the currently playing track (even if it is not selected)? This would allow us, for example, to highlight all of the tracks of a currently playing album. Maybe like %cwb_playing_album% or
%cwb_playing_custom%.
foo_cwb_hooks
Reply #188
would it be possible to implement %foobar_path%  or even a %drive_installed% i want to be able to retrieve the drive letter
foo_cwb_hooks
Reply #189
I added some features that are a bit outside the scope of the title formatting hooks, but i dont want to create a whole new component for it so its going to be a part of CWB hooks.
= Release 1.1.0beta =
* added timestamp action for tagging (example usage, add a ADDED timestamp when you add new files)
* added new file tagger tool - allows you to run any context menu item on files added to library.  useful with above scripting action for adding timestamp to new files (Preferences/Tools/New Files Tagger)
There used to be a link to my website here.
foo_cwb_hooks
Reply #190
this is great (especially that you can simply select any context menu item for it)! i guess i could use this together with custom info, right?
foo_cwb_hooks
Reply #191
thanks for the update!
a bit off topic, but....
Using the New File tagger to add "Added" to files added to the db the format (on my foo) is YYYYMMDD. But, on single digit days (like today) I get 2006124 instead of 20061204.
Is there a way to fix this?
foo_cwb_hooks
Reply #192
if it isn't too much of a pain in the ass, would it also be possible to have another $systemdate() function that works with Win32 filetime?
foo_cwb_hooks
Reply #193
Thanks for the update!
I try again: %list_index% is not accessible though panels. Can you please make this accessible?
%cwb_list_index% - Index of currently selected track
foo_cwb_hooks
Reply #194
Er. That's not happening to me. I have the the New File Tagger thing set to do:
Tagging/Scripts/set added date
and then the actions that script is set to do are:
Time Stamp: ADDED
Format "ADDED" using "$left(%added%,10)"
I've used this probably on a half-dozen albums since i updated, and they all show up perfectly the way they should. '2006-12-03', '2006-12-04', that kind of thing.
Are you doing something different?
edit:
Maybe it depends on your regional settings? Try going into Control Panel > Regional and Language Options, and then make sure the 'Short date' is set to show MM and dd instead of M and d.
foo_cwb_hooks
Reply #195
Time Stamp: ADDED
edit:
http://www.halfbakedschemes.com/added.jpg
using Custom Info
EDIT: I added your script and it works as advertised YYYY-MM-DD, but is there a way to change the script to drop the "-" i.e. YYYYMMDD?
foo_cwb_hooks
Reply #198
Yeah, add an extra step to that masstagger script:
Format "ADDED" using "$replace(%added%,'-',)"
foo_cwb_hooks
Reply #199
I notice that the wiki page says not to request any new features along the lines of %cwb_next_*%, but since %cwb_next_title%, etc. are in existence, is it possible to have any kind of "previous" function? Or there is already a way to do it that I'm not aware of?
