Topic: foo_winamp_spam 0.9 beta (Read 374442 times) previous topic - next topic
Reply #100
Here goes Version 0.92
http://chron.visiondesigns.de/foobar2000/f..._spam_v0.92.zip
Changes
  • Implemented IPC_GETTIMEDISPLAYMODE (lParam 610) - always returns 0 (displaying elapsed time)
  • Implemented lParams 1237188, 1241704, 1242024, 1243292 - are not implemented in winamp, evillyrics spams them for unknown reasons - made them do nothing (stops console spam)
Made a hp for my components
Reply #102
Thanks to r1ch and Chronial for keeping up with this. Can't say i'm using it anymore (switched to foosion's COM Server and a COM client of my own) but kudos are definitely deserved here. Good job
Reply #103
Hey Chronial,
I use this plugin primarily for Gtalk's Now Playing mode. My console gets spammed with "Warning: foo_winamp_spam. lParam 120 not supported". Would you be able to fix that? Thanks.
Reply #104
How did you get it to work with Gtalk?
Gtalk neither shows my current track nor causes console spam. The now playing feature just does not work at all.
Reply #106
So we are at v0.93
http://chron.visiondesigns.de/foobar2000/f..._spam_v0.93.zip
Changes:
Implemented IPC_WRITEPLAYLIST (lParam 120) - If there is no winamp path set in registry, foobar sets it to its settings path during startup and deletes in on shutdown. Playlist is written into this path, so foobar will overwrite your winamp playlist, if this feature is activated and winamp installed.
Reply #108
Is there any chance implementing something like checking if user is seeking (in foobar, not through IPC_JUMPTOTIME)?
Reply #109
I'm sorry, but this component should emulate the winamp api, and I will not implement any other functionality than that.
Or did I get you wrong?
Reply #110
No, I didn't, but I just hope you can implement it, but if not, it doesn't matter. I'll try to do it on my own. Anyway thanks!
Reply #111
Hi, just found out that there is an updated Version. Evillyrics (build 142) still spams my console. I have the following version of the plugin:
foo_winamp_spam.dll (2006-12-09 23:36:08)
    Winamp API Emulator 0.93
The message is: WARNING : foo_winamp_spam: Unsupported WM_USER, lParam 1235828.
Reply #112
So we are at v0.93
Changes:
Hi! Thank you so much for taking over the development! Works like a charm
Reply #113
Thanks for the update ;D
-foobar2000 + Burrrn + EAC
-HD 80Gb using High QualityVBR MP3s
Reply #114
Evillyrics must generate these numbers at random ^^.
Will be fixed in the next release
Reply #116
Thanks for the update. Here is the error I still get:
WARNING : foo_winamp_spam: Unsupported WM_USER, lParam 1243188.
Reply #117
R1CH, I was wondering if it could be possible to also return dynamic info in the string. Things like %playback_time% and the playlist index\length.
I don't quite know if I understood this request correctly, but did you have a look at cwb_hooks?
Well, did a release for all the poor evillyrics haunted people out there
Get it here
Changes:
Fixed the Evillyrics spam - all lParam > 1200000 are ignored (they don't have any meaning after all)
Reply #118
Is it posible to use this plugin to control Winamp visualisations. That would be awesome.
last.fm/user/antropocentrio
Reply #119
Frankly, Even i don't remember why i asked that
Probably had to do with the plugin not returning info for winamp API calls that involve dynamic info, especially playlist position\length.
Reply #120
Once and for all:
The aim of this component is to imitate winamp's behavior towards other applications (like your mIRC plugin, google talk etc.). I am not going to add any feature to this component that is not present in winamp or is part of winamp's internal behavior (like winamp's communication with it's visualizations).
I hope this makes it clear.
(No, I'm not pissed or something alike - just wanted to make that clear )
Reply #121
It is possible add playlist-number of playing track?
When i use current version of plugin i see next:
I use PowerOff program and it have option - shutdown after "n" winamp tracks are played (not work!).
Also it have option - show track name in header of active window (work!)
Reply #122
Sry, I didn't quite understand your problem.
Can you give me the exact name or a download link of the program that is not working?
Reply #124
First off thank you for developing this compenent, I primarily use it for my playback info on google talk. There are however a couple issues I'd like to bring up and hopefully have resolved.
1) Is there any way to reduce the frequency which this program rewrites the winamp playlist? Under the current version it appears the playlist gets rewritten nearly every second which can cause a race condition resulting in sharing errors when other programs are trying to read the playlist. Maybe have it only update when the track changes and/or playback state changes?
2) Real winamp writes meta information as a comment on a line between the filename lines. While I generally dislike using comments as code, many 3rd party programs for winamp process this information. Specifically I am trying to get X-Winamp for XChat working.. it is able to report the currently playing track however unable to discover the filename based on the playlist for the fileserver options.
