Topic: how to split playlist item into two lines? (Read 2711 times) previous topic - next topic
i don't know the tag for break-space (new line) because titleformating form doesn't accept ENTER key.
ie:
%title%
%artist%
i'm using columns ui and i'm looking for some simple solution.
result should look like playlist items on this picture (muine, gnome audio player):
http://muine-player.org/wiki/Image:Brandon...eScreenshot.png
thank you in advance
I don't think you can do that, can you? You'd think like $char(000D) or $char(13) or something like that would work, but foobar (or Columns UI, anyway) just strips it out.
It's not possible, because you're inherently limited to one line per track.
You could just increase the padding ...
love, IAN
droptothetop.com/
is there a plugin or any other solution?
[a href="index.php?act=findpost&pid=374600"][{POST_SNAPBACK}][/a]
Nope. Theoretically, I think someone could create a new playlist view for foo_ui_columns, but 1.) No one has and 2.) I'm not sure if that's even possible ATM.
