Topic: wmcmd syntax (Read 3828 times) previous topic - next topic
wmcmd syntax
I can't find the syntax I need to use to decode wma files to wav using the wmcmd.vbs command line script.
Any help would be greatly appreciated!
mrgou
wmcmd syntax
I don't think it's possible.
Maybe using -a_codec PCM -input meh.wma -output meh.wav, but I didn't test.
[a href="index.php?act=findpost&pid=347605"][{POST_SNAPBACK}][/a]
No, that's not working. I believe the container is still wma, although it's uncompressed.
If that's not possible with wmcmd, is there any command line decoder from WMA to WAV?
wmcmd syntax
try mplayer instead.
mplayer can even decode WMA lossless and WMA pro.
@echo off
cd "%userprofile%\desktop"
"C:\path to\mplayer.exe" -v -ao pcm:file="%~n1.wav" %1
pause
save the code above to a batch file,
after mplayer finish decoding, a wav file will appear on your desktop.
