Topic: "Reading a Binary Header" for dummies (Read 3827 times) previous topic - next topic
I've had enough programming experience to be able to find a hex value in a file, but I'm absolutely virginal when it comes to finding the 11 set bits in a file that signify a header.  Bit level programming is Greek to me.
I'm trying to plug away at some source code others have written, but as yet it just isn't clicking with me.
Help!
This is real programming  Just have to get practiced with the operators,
shifts >>, >>>, <<
and & or |, xor ^
A reference book comes in handy, plenty of googleables 'logical operators shift programming...etc'
To find 11 bits on? first find a full byte then see whats around it.
gl'
no conscience > no custom
[a href="index.php?act=findpost&pid=337270"][{POST_SNAPBACK}][/a]
Does the first bit really have to be aligned on the beginning of a byte? Then I doubt he would have had to ask...
Edit: previous lookup table solution i suggested was faulty and removed now.
you can look either side *
pseudocode:
loop pos{
if array[pos]=0xff
{ if (array[pos-1] has bit 3=0 and bits2,1,0=1 )
  {return pos*8-3;}
  if (array[pos-1] has bit 2=0 and bits 2,1=1 AND array[pos+1] has bit 8=1)
{return pos*8-2}
  if etc..
  }//end fullbytefound
}//end search
To find 11 consecutive set bits anywhere in a byte stream, I'd make a table of of possible byte combinations....
possible, whatever works does to get on with
[span style='font-size:8pt;line-height:100%']Edit: *warning - Eric has pointed out the possibiity of sync word falling between two bytes showing this approach is incomplete[/span]
If you are talking about the MPEG Audio header, it is 12 bits set to "1". And the start is on a byte boundary.
So you only have to search for hex FFF
But only 11 for mpeg 2.5 streams
...the start is on a byte boundary.
[a href="index.php?act=findpost&pid=337321"][{POST_SNAPBACK}][/a]
Can someone confirm/refute this?  Does every header sync always start on a byte boundary?
yes, it always starts at a byte boundary
Good - that simplifies things considerably.  Thanks to everyone.
