Topic: The Definitive Custom Buttons Thread (Read 765819 times) previous topic - next topic
Reply #101
Because of request!
New ratingbuttons for this buttonbar in size 32x32 and 20x20
Size 128x128 and ratingscripts also included.
((((( Strictly4me )))))
I can't figure this one out, how do I add those scripts to the masstager, and how do I connect the buttons to it?
- Twaize
Reply #102
[/quote]
- Twaize
[/quote]
Took me ages to work out - mainly cause i could'nt get masstagger to load once i pasted in the .dll - till i found this
"If you don't have the masstagging groups, it's because you did not install it, reinstall foobar 2000 on your previous installation (you won't loose anything)" - http://eolindel.free.fr/foobar0.9/masstagger.php [installed it seperately and deleted it - did the trick somehow].
Anyway...
highlight a song(s) and use the right click menu - go to Tagging > Manage Scripts = then u'll get an interface like below:
From here choose the 'Load from File' option under Scripts & Load 1 of Strictly4Me's scripts (as shown) - then Save - in the example this is called 4star - this will allow the script to be shown in the right click context menu.
This means that when you go to customizing your toolbar (right click toolbar) you can link it to the tagging command (e.g. tagging/scripts/4star)...
Hope this helps & thanks Strictly4Me - I've been looking for a way to do this without using track info mod script.
P.S.
Incase anyone needs to add %rating% to coloums UI playlist view as well (preferences) - here's my simple script:
$if(%rating%,
$select(%rating%,
Reply #103
sorry for asking this, but where do I get foo_uie_buttons that supports png's? i got the latest columns plugin, but can't get png's to work, and i can't find any info in this thread, even though i think i should
Reply #104
You do not need foo_uie_buttons. Columns UI by default uses buttons that utilize PNG for the images. You do, however, need to install libpng13.dll and zlib1.dll in your foobar main directory for the images to appear. You can download the latest version of Columns UI here. The link for libpng and zlib is available on that same page if you click on "Requirements >"
Reply #105
[quote name='Garfield4' date='Jan 17 2007, 22:19' post='465069']
[/quote]
- Twaize
[/quote]
Anyway...
From here choose the 'Load from File' option under Scripts & Load 1 of Strictly4Me's scripts (as shown) - then Save to File - in the example this is called 4star - this will allow the script to be shown in the right click context menu.
P.S.
$if(%rating%,
$select(%rating%,
[/quote]
The script now works, when I rightclick on a song and select it under tagging>scripts
But I can't get the button to connect, even when I choose it, when customising my buttons.
Reply #106
[/quote]
[/quote]
Glad you got it going so far
Once your in the customize button window - you need to select 'Now Playing item' in the Item Group - otherwise the button will just act as a blank.
Hope this fixes things
Reply #107
[quote name='Garfield4' date='Jan 18 2007, 12:53' post='465274']
[/quote]
[/quote]
[/quote]
It's working, thank you so much
Reply #108
How do you use the buttons when they are in 7z
Reply #110
cool thank you very much
Reply #111
I'd like to request a re-upload of the WMP-style buttons, preferably with extra buttons if at all possible
Reply #112
How do I open an .fcb file?
I found it
Reply #114
When I change the buttons I dont see eny. Why is it like this?
Reply #115
Just wanted to share these buttons with you, inspired/stolen (  ) from iTunes:
Only a prev/next button though.
DOWNLOAD HERE
Les mots d'amour...
Reply #117
my buttons (mostly I use the ones for switching between track/album gain)
Reply #118
Here's some buttons intended to fit into the Aero theme of Windows Vista.
Reply #119
My buttons
Download:
[attachment=3198:attachment]
Reply #120
Amazing work!
Favourite artist:CD-R
Favourite album:700MB
Reply #121
tango !
[attachment=3231:attachment]
[attachment=3232:attachment]
[attachment=3233:attachment]
[attachment=3234:attachment]
Reply #122
WMP11 Style Buttons
I fixed these buttons up today, for those who are interested. They were posted before but the download link is now broken.
The changes i made include changing the Mute button to a Random Button, I also made a pause button that can be displayed instead of the play button depending on the playback state, useful for a 'play or pause' button.
[attachment=3258:attachment]
[attachment=3256:attachment]
heres the Code for the buttons
// Stop
$button($sub($div(%_width%,2),90),0,0,0,36,36,/images/playback/stop.png,/images/playback/stop_h.png,stop,)
// Previous
$button($sub($div(%_width%,2),54),0,0,0,36,36,/images/playback/prev.png,/images/playback/prev_h.png,previous,)
// Play/Pause
$button($sub($div(%_width%,2),18),0,0,0,36,36,
$if(%isplaying%,$if(%ispaused%,/images/playback/play.png,/images/playback/pause.png),/images/playback/play.png),
$if(%isplaying%,$if(%ispaused%,/images/playback/play_h.png,/images/playback/pause_h.png),/images/playback/play_h.png),play or pause,)
// Next
$button($add($div(%_width%,2),18),0,0,0,36,36,/images/playback/next.png,/images/playback/next_h.png,next,)
// Random
$button($add($div(%_width%,2),54),0,0,0,36,36,/images/playback/random.png,/images/playback/random_h.png,random,)
Reply #123
how to import fcb file
Reply #124
^ right mouse button on the Buttons > Customize > hit Tools > Load from file > find the .fcd you need.
