Topic: foo_vis_projectM (Read 167417 times) previous topic - next topic
foo_vis_projectM
thanks for the double-click
foo_vis_projectM
I'm obviously missing something here. I have the projectM as a panel above my playlist, but in the preferences, i cannot find anywhere to change the minimum height. Width I can adjust by dragging but cannot do anything with height. i see from other posts that this can obviously be done.
I'm sure I'll look stupid, but can someone put me out of my misery?
Tourmalet
foo_vis_projectM
Tourmalet
[{POST_SNAPBACK}][/a]
i use [a href="http://www.hydrogenaudio.org/forums/index.php?showtopic=28869]Panel stack[/url] . In the panel stack config , you can set a minimum height
foo_vis_projectM
Hamallainen
That's got it sorted! Many, many thanks for your quick help.
Tourmalet
foo_vis_projectM
Good job bleh! Thanks!
foo_vis_projectM
Minor new release (0.97.4).  New stuff:
- Config dialogs are now tabbed because they were getting too full for my tastes.
- Mouse cursor mostly hides quietly in fullscreen mode.  It pops back up for a bit right after the switch to fullscreen and I'm not sure how to resolve this, but it works okay after that.
- Animated song title now available on spacebar press and song change.
- Preset length is configurable, but it's hard to get a greater level of control than short or long since projectM tweaks the preset time as it sees fit to try to keep things synced with the beat.
foo_vis_projectM
I'm using the new panel version, and it's working great! I'm so siked to have a native vis for foobar, and it's running ultra-smoothly.
great work!
foo_vis_projectM
Reply #32
well for not being done im in love thanx man got me a new screen saver and way to pass protect when this is on or can it be added?
foo_vis_projectM
Thanks for your great work ! Finally a visualization panel
foo_vis_projectM
Reply #34
Only problem I've found with the panel version is it seems to be a bit blocky.  Probably because of the way it's stretched.  Not major, and maybe not even fixable.
Also, although already mentioned I think, Unicode support would be awesome.
Selectable fonts would be a big plus too.  Keep up the good work, this is awesome.
foo_vis_projectM
Reply #35
Blah, I reorganized the way I had the source organized on my hard drive before releasing 0.97.3 and I reverted to the original projectM source, which would crash any time characters above 127 were used (e.g. Çüâ).  Someone sent me an e-mail last night and alerted me that the issue has reappeared.  A re-fixed version is now available (0.97.4.1).  It doesn't appear to display any of the characters that made it crash, though :|.  As per the LGPL, if anyone wants a copy of the modified projectM source, they can PM me.
I'll start working on replacing projectM's current font-rendering library with a nicer (and probably slower) one later today.  I don't know how long it'll take, but when it's done, I won't have to worry about a silly crash like this one again.
Regarding password protection, it isn't something I'm interested in implementing because (1) I have no idea how to get a system login prompt to come up and (2) if I did start working on this, I'd probably keep locking myself out of my computer and having to restart until I'd fixed all of the bugs.  Maybe after I've addressed some of the more noticeable issues (fonts, panel keys, etc.) I'll look into this.
foo_vis_projectM
Reply #36
I am having alot of trouble with this component (panel version). It seems that it crashes almost everytime I open it up. The only way I am able to avoid crashes is to remove all of the presets. Are most presets simply incompatible with projectM?
foo_vis_projectM
Reply #37
Song titles do not fade out as on previous versions. I'm using v0.97.4.
foo_vis_projectM
Reply #38
I've tried all the presets in the ''presets_projectM'' folder that came in ''projectM-0.97.tar.gz'' from [a href="http://xmms-projectm.sourceforge.net/]http://xmms-projectm.sourceforge.net/[/url] - None have caused a crash. (though some drive my cpu use to 100%) I haven't tried any others.
foo_vis_projectM
Reply #39
[a href="index.php?act=findpost&pid=305746"][{POST_SNAPBACK}][/a]
As Cosmo said, the presets shouldn't be causing a problem.  Could you tell me which version you're using and either PM me your crash log (failure.txt) or post it here within [code] tags?
[a href="index.php?act=findpost&pid=305830"][{POST_SNAPBACK}][/a]
Are you using dynamic song info?  If you are, disable the animation on song change.  If that makes it go away, I can put out a bugfix version that doesn't pop up the title on dynamic info updates if the song change animation is important to you.
foo_vis_projectM
Reply #40
Great plugin!
Only one question, is there a setting somewhere to set the minimum height for the panel? The horizontal length is fine but the vis appears really thin when added to my panel stack. The problem is solved if i add it to a my set of tabbed panels.
"If you cannot read this, please ask the flight attendant for assistance."
- United Airlines Flight Safety Brochure
foo_vis_projectM
Reply #41
[a href="index.php?act=findpost&pid=305865"][{POST_SNAPBACK}][/a]
I do not have dynamic info enabled. However, when I did enable it and selected "Display animated title on song change" within projectM, it crashed. I'll post the crash log shortly.
While I'm at it, I just want to thank you for efforts. This is a great component!
foo_vis_projectM
Reply #42
Great plugin!
[a href="index.php?act=findpost&pid=305871"][{POST_SNAPBACK}][/a]
see post #28
edit:
sorry , i had not read your post completly
foo_vis_projectM
Reply #43
This is the crash log. I think it might have something to do with Windowblinds. I'll disable it and try to reproduce the crash.
edit[removed crash log. Windowblinds was causing crash!]
foo_vis_projectM
Reply #44
It is possible add support for cyrillic fonts in this nice plugin?
foo_vis_projectM
Reply #45
I seem to lose my mouse acceleration whenever foobar is in focus and the panel version of this plugin is in my components folder.
I tried deleting it from my components, that fixed it.
Using a Logitech Marblemouse and win XP sp2
great plugin
foo_vis_projectM
Reply #46
Everytime I try to play a song called "Génesis" by Vox Dei, foobar crashes. (Only with this song, maybe the problem is the "é" in its title)
This is the crashlog:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 00D653C2h
Access violation, operation: read, address: 6F522087h
Call path:
WinMain=>app_mainloop
Code bytes (00D653C2h):
00D65382h:  40 84 C9 75 F9 2B C3 48 3B F8 7D 5F 8A 44 2F 01
00D65392h:  3C 20 75 0D 8B 15 E8 30 D7 00 6A 00 6A 00 52 EB
00D653A2h:  44 0F BE C8 8D 0C 8D 64 00 00 00 83 3C 31 00 74
00D653B2h:  3A A1 28 1B D8 00 8B 04 85 20 17 D8 00 8B 0C 08
00D653C2h:  D9 41 10 8B 14 10 D9 E0 6A 00 D8 42 14 6A 00 51
00D653D2h:  D8 05 E8 30 D7 00 D9 1C 24 EB 0A A1 F0 30 D7 00
00D653E2h:  6A 00 6A 00 50 FF 15 AC 01 D7 00 8B C5 47 8D 50
00D653F2h:  01 8A 08 40 84 C9 75 F9 2B C2 3B F8 0F 8C 3C FF
Stack (0012F6A4h):
0012F684h:  0012F95C 0012F934 00000000 F0622DD8
0012F694h:  F0622A2C 804DB8F3 F0622AEC 804E2490
0012F6A4h:  5F122EF0 5F122F14 09A67008 0012F6F0
0012F6B4h:  00D6562F 0AC30E68 00D65440 00D57D11
0012F6C4h:  0AC30E68 09A67008 00D5C6FC 09A67008
0012F6D4h:  09A67008 000802CE 5E010C57 00000000
0012F6E4h:  5E010C57 FFFFFF11 FFFFFE33 0012F72C
0012F6F4h:  00D53A6C 09A67008 0012F768 00D539E0
0012F704h:  77D18734 000802CE 0000000F 00000000
0012F714h:  00000000 00D539E0 DCBAABCD 00000000
0012F724h:  0012F768 00D539E0 0012F794 77D18816
0012F734h:  00D539E0 000802CE 0000000F 00000000
0012F744h:  00000000 0000000F 00D539E0 00000000
0012F754h:  00000014 00000001 00000000 00000000
0012F764h:  00000010 00000000 0000004E 00000000
0012F774h:  00000000 00000000 0012F748 0012F2C8
0012F784h:  0012F8A8 77D40467 77D18830 00000000
0012F794h:  0012F7C4 77D1C63F 00000000 00D539E0
0012F7A4h:  000802CE 0000000F 00000000 00000000
0012F7B4h:  00000000 00000000 00000082 001BFE48
Registers:
EAX: 0AC0F7C0, EBX: 0AC30E69, ECX: 6F522077, EDX: 00000180
ESI: 0AC0F7C0, EDI: 0000000A, EBP: 0AC30E68, ESP: 0012F6A4
Crash location: "foo_uie_vis_projectm", loaded at 00D50000h - 00D8C000h
Loaded modules:
foobar2000                      loaded at 00400000h - 00452000h
ntdll                            loaded at 7C910000h - 7C9C6000h
kernel32                        loaded at 7C800000h - 7C901000h
USER32                          loaded at 77D10000h - 77DA0000h
GDI32                            loaded at 77EF0000h - 77F36000h
ole32                            loaded at 774B0000h - 775ED000h
ADVAPI32                        loaded at 77DA0000h - 77E4C000h
RPCRT4                          loaded at 77E50000h - 77EE1000h
msvcrt                          loaded at 77BE0000h - 77C38000h
COMCTL32                        loaded at 773A0000h - 774A2000h
SHLWAPI                          loaded at 77F40000h - 77FB6000h
utf8api                          loaded at 10000000h - 1000D000h
comdlg32                        loaded at 76360000h - 763AA000h
SHELL32                          loaded at 7C9D0000h - 7D1EE000h
foo_albumlist                    loaded at 003E0000h - 003EB000h
foo_audioscrobbler              loaded at 00940000h - 00960000h
LIBCURL                          loaded at 00960000h - 00979000h
WS2_32                          loaded at 71A30000h - 71A47000h
WS2HELP                          loaded at 71A20000h - 71A28000h
WINMM                            loaded at 76B00000h - 76B2E000h
SYNCOR11                        loaded at 6BD00000h - 6BD0D000h
foo_cdda                        loaded at 00A00000h - 00A0E000h
foo_clienc                      loaded at 00A10000h - 00A1B000h
foo_console                      loaded at 00A20000h - 00A27000h
foo_diskwriter                  loaded at 00A30000h - 00A42000h
foo_dsp_delta                    loaded at 00A50000h - 00A57000h
foo_dsp_extra                    loaded at 00A60000h - 00A75000h
foo_follow_cursor_reset          loaded at 00A80000h - 00A86000h
foo_id3v2                        loaded at 00A90000h - 00AC0000h
MSVCP60                          loaded at 76030000h - 76095000h
foo_infobox                      loaded at 00AC0000h - 00AD3000h
foo_input_std                    loaded at 00AE0000h - 00B7E000h
MSACM32                          loaded at 77BB0000h - 77BC5000h
foo_masstag                      loaded at 00B80000h - 00B94000h
foo_mod                          loaded at 00BA0000h - 00BA9000h
BASS                            loaded at 00BB0000h - 00C0A000h
foo_openwith                    loaded at 00C10000h - 00C19000h
MSVCR71                          loaded at 7C340000h - 7C396000h
foo_output_std                  loaded at 00C30000h - 00C39000h
foo_out_dsound_ex2              loaded at 00C40000h - 00C49000h
DSOUND                          loaded at 73E90000h - 73EEC000h
VERSION                          loaded at 77BD0000h - 77BD8000h
foo_playlistfind                loaded at 00C60000h - 00C6B000h
foo_playlistgen_ex              loaded at 00C70000h - 00C7F000h
foo_read_http                    loaded at 00C80000h - 00C89000h
foo_rgscan                      loaded at 00C90000h - 00C9D000h
foo_toaster                      loaded at 00CA0000h - 00CC1000h
gdiplus                          loaded at 4EBA0000h - 4ED43000h
foo_uie_albumart                loaded at 00CE0000h - 00CEC000h
foo_uie_albumlist                loaded at 00CF0000h - 00D01000h
foo_uie_lyrics                  loaded at 00D10000h - 00D3A000h
WININET                          loaded at 77180000h - 77227000h
CRYPT32                          loaded at 77A50000h - 77AE5000h
MSASN1                          loaded at 77AF0000h - 77B02000h
OLEAUT32                        loaded at 770F0000h - 7717C000h
foo_uie_tabs                    loaded at 00D40000h - 00D4A000h
foo_uie_vis_projectm            loaded at 00D50000h - 00D8C000h
OPENGL32                        loaded at 5F120000h - 5F1EC000h
GLU32                            loaded at 5FEA0000h - 5FEC1000h
DDRAW                            loaded at 736E0000h - 73729000h
DCIMAN32                        loaded at 73B40000h - 73B46000h
foo_uie_volume                  loaded at 00D90000h - 00D9B000h
foo_ui_columns                  loaded at 00DA0000h - 00DD7000h
foo_ui_std                      loaded at 08DE0000h - 08DF7000h
foo_vis_manager                  loaded at 00DE0000h - 00DE8000h
foo_winamp_spam                  loaded at 08E00000h - 08E07000h
foo_wma                          loaded at 08E10000h - 08E2A000h
WMVCore                          loaded at 08E30000h - 09074000h
WMASF                            loaded at 09080000h - 090BB000h
uxtheme                          loaded at 5B150000h - 5B188000h
ialmgicd                        loaded at 09510000h - 09743000h
ialmgdev                        loaded at 097E0000h - 0985B000h
WINTRUST                        loaded at 76BF0000h - 76C1E000h
IMAGEHLP                        loaded at 76C50000h - 76C78000h
wdmaud                          loaded at 72CA0000h - 72CA9000h
msacm32                          loaded at 72C90000h - 72C98000h
midimap                          loaded at 77BA0000h - 77BA7000h
mswsock                          loaded at 719D0000h - 71A10000h
DNSAPI                          loaded at 76EE0000h - 76F07000h
iphlpapi                        loaded at 76D20000h - 76D39000h
winrnr                          loaded at 76F70000h - 76F78000h
WLDAP32                          loaded at 76F20000h - 76F4D000h
hnetcfg                          loaded at 66740000h - 66799000h
wshtcpip                        loaded at 71A10000h - 71A18000h
rasadhlp                        loaded at 76F80000h - 76F86000h
KsUser                          loaded at 73E60000h - 73E64000h
Secur32                          loaded at 77FC0000h - 77FD1000h
urlmon                          loaded at 77230000h - 772CE000h
wsock32                          loaded at 71A50000h - 71A5A000h
RASAPI32                        loaded at 76EA0000h - 76EDC000h
rasman                          loaded at 76E50000h - 76E62000h
NETAPI32                        loaded at 597F0000h - 59844000h
TAPI32                          loaded at 76E70000h - 76E9F000h
rtutils                          loaded at 76E40000h - 76E4E000h
USERENV                          loaded at 76630000h - 766E4000h
DBGHELP                          loaded at 5D4B0000h - 5D551000h
Stack dump analysis:
Address: 5F122EF0h, location: "OPENGL32", loaded at 5F120000h - 5F1EC000h
Symbol: "glLoadIdentity" (+00000000h)
Address: 5F122F14h, location: "OPENGL32", loaded at 5F120000h - 5F1EC000h
Symbol: "glMatrixMode" (+00000000h)
Address: 00D6562Fh, location: "foo_uie_vis_projectm", loaded at 00D50000h - 00D8C000h
Address: 00D65440h, location: "foo_uie_vis_projectm", loaded at 00D50000h - 00D8C000h
Address: 00D57D11h, location: "foo_uie_vis_projectm", loaded at 00D50000h - 00D8C000h
Address: 00D5C6FCh, location: "foo_uie_vis_projectm", loaded at 00D50000h - 00D8C000h
Address: 00D53A6Ch, location: "foo_uie_vis_projectm", loaded at 00D50000h - 00D8C000h
Address: 00D539E0h, location: "foo_uie_vis_projectm", loaded at 00D50000h - 00D8C000h
Address: 77D18734h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetDC" (+0000006Dh)
Address: 77D18816h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetDC" (+0000014Fh)
Address: 77D40467h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DeregisterShellHookWindow" (+000001CFh)
Address: 77D18830h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetDC" (+00000169h)
Address: 77D1C63Fh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "IsWindowUnicode" (+000000A1h)
Address: 77D1C665h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "CallWindowProcW" (+0000001Bh)
Address: 5F14699Bh, location: "OPENGL32", loaded at 5F120000h - 5F1EC000h
Symbol: "wglSwapBuffers" (+000002F7h)
Address: 5F146780h, location: "OPENGL32", loaded at 5F120000h - 5F1EC000h
Symbol: "wglSwapBuffers" (+000000DCh)
Address: 77D1B4C0h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+00000184h)
Address: 00D73608h, location: "foo_uie_vis_projectm", loaded at 00D50000h - 00D8C000h
Address: 77D1B4D0h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+00000194h)
Address: 77D1B50Ch, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+000001D0h)
Address: 7C91EAE3h, location: "ntdll", loaded at 7C910000h - 7C9C6000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 77D1B473h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+00000137h)
Address: 77D1BF78h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "RedrawWindow" (+0000000Ch)
Address: 00D53372h, location: "foo_uie_vis_projectm", loaded at 00D50000h - 00D8C000h
Address: 00DE522Ch, location: "foo_vis_manager", loaded at 00DE0000h - 00DE8000h
Address: 00DE1879h, location: "foo_vis_manager", loaded at 00DE0000h - 00DE8000h
Address: 773D540Ah, location: "COMCTL32", loaded at 773A0000h - 774A2000h
Symbol: "Ordinal384" (+000195E0h)
Address: 77EF6E49h, location: "GDI32", loaded at 77EF0000h - 77F36000h
Symbol: "BitBlt" (+00000089h)
Address: 77EF6E31h, location: "GDI32", loaded at 77EF0000h - 77F36000h
Symbol: "BitBlt" (+00000071h)
Address: 00CC0020h, location: "foo_toaster", loaded at 00CA0000h - 00CC1000h
Address: 77EF6C64h, location: "GDI32", loaded at 77EF0000h - 77F36000h
Symbol: "DeleteObject" (+00000229h)
Address: 77EF6D51h, location: "GDI32", loaded at 77EF0000h - 77F36000h
Symbol: "DeleteDC" (+000000ABh)
Address: 77EF59A0h, location: "GDI32", loaded at 77EF0000h - 77F36000h
Symbol: "SelectObject" (+00000000h)
Address: 7C9205C8h, location: "ntdll", loaded at 7C910000h - 7C9C6000h
Symbol: "RtlFreeHeap" (+0000018Bh)
Address: 7C920551h, location: "ntdll", loaded at 7C910000h - 7C9C6000h
Symbol: "RtlFreeHeap" (+00000114h)
Address: 7C92056Dh, location: "ntdll", loaded at 7C910000h - 7C9C6000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 773D6065h, location: "COMCTL32", loaded at 773A0000h - 774A2000h
Symbol: "Ordinal384" (+0001A23Bh)
Address: 773D6489h, location: "COMCTL32", loaded at 773A0000h - 774A2000h
Symbol: "Ordinal384" (+0001A65Fh)
Address: 7C922270h, location: "ntdll", loaded at 7C910000h - 7C9C6000h
Symbol: "RtlInitializeCriticalSection" (+00000743h)
Address: 7C921596h, location: "ntdll", loaded at 7C910000h - 7C9C6000h
Symbol: "wcsncpy" (+00000B07h)
Address: 7C9206EBh, location: "ntdll", loaded at 7C910000h - 7C9C6000h
Symbol: "RtlAllocateHeap" (+00000117h)
Version info:
foobar2000 v0.8.3
UNICODE
By the way, thanks a lot for this excellent component. I really love it.
foo_vis_projectM
Reply #47
[a href="index.php?act=findpost&pid=306024"][{POST_SNAPBACK}][/a]
I'm currently looking into replacing projectM's current font rendering library with one that uses FreeType2.  When I get that done, you should be able to use Unicode-supporting TrueType fonts.
great plugin
[a href="index.php?act=findpost&pid=306106"][{POST_SNAPBACK}][/a]
Hmm, that's really weird.  Is this happening even with the panel closed?
Everytime I try to play a song called "Génesis" by Vox Dei, foobar crashes. (Only with this song, maybe the problem is the "é" in its title)[a href="index.php?act=findpost&pid=306132"][{POST_SNAPBACK}][/a]
Which version are you using?  There was a bug similar to this in earlier versions, but I thought I fixed it in 0.97.4.1
foo_vis_projectM
Reply #48
[a href="index.php?act=findpost&pid=306147"][{POST_SNAPBACK}][/a]
Oops, sorry. I didn't see the new version, I was using 0.97.4. It works great now, thanks.
foo_vis_projectM
Reply #49
This is great work. Will test it exhaustively.
Did I say this was great work?
