Topic: Firefox And Ha (Read 17335 times) previous topic - next topic
Firefox And Ha
I've switched to Firefox and I'm experiencing a weird problem and HA. I see the forum in a weird display, it's all in a whte background and no quote colours are available. It's kind of a lo-fi version (but it isn't, already checked).
Someone has experienced somethign like that? It's really hard to read, I have to open it in IE
Firefox And Ha
Here Firefox works without any problems
Firefox And Ha
"Problem is at your end, Firefox works fine here"
Firefox And Ha
Damn, so the problem is on my side (I 'hoped' this was a general issue so someone has a solution)... I really don't know what could be the problem, it only happens in this forum, others are displayed correctly.
Firefox And Ha
firefox perfect with HA here too, i can only suggest you try a fresh install with latest non beta to a new directory, if error is the same, i'd ask for help at the firefox forums.
Firefox And Ha
Try the obiligatory cache, cookie, temporary files emptying first before reinstalling.
Firefox And Ha
perfect here also
Firefox And Ha
From the way you described this, I believe that I had this exact same problem. I got rid of it though. What I needed to do was as follows: (only try this if nothing else works):
1) Backup all bookmarks and Firefox settings. Cause in this process, you'll otherwise lose them.
2) Uninstall Firefox.
3) Delete the directory for Firefox in Program Files.
4) In your "Documents and Settings\[Winodws User Name]\Application Data\" folder, look for a Mozilla folder, and in that Mozilla folder, look for one named "Firefox".
If you can't find this directory, search for a directory named Application Data or Firefox, and you can figure out the rest from there. Once you find this Firefox directory, delete it.
5) Reinstall Firefox.
Back when I had this issue (and this was one of several sites that had issues), simply reinstalling did not alleviate the issue.
And I do love Firefox.
Firefox And Ha
jkwarras, could you check to see if you can see the quote block in this post?
http://bbs.kldp.org/viewtopic.php?p=233411#233411
If you can't see "Alphanumeric letters work here too. 1, 2, 3." then you have the same problem as someone in Korea.
edit: test code for blure from bbs.kldp.org
Alphanumeric letters, 1, 2, and 3.
Firefox And Ha
no problems here - xp pro sp2 + firefox 1.0
Firefox And Ha
[a href="index.php?act=findpost&pid=274701"][{POST_SNAPBACK}][/a]
Really weird, at work with exactly same installation as at home I can see HA correctly (under windows 2000 pro). So, I can see the quote block in the forum kjoonlee.
It seems I'll have to uninstall/reinstall Firefox at home. Thanks for the replies
Firefox And Ha
I reckon this is one of the sites where Firefox is the most popular browser..
Firefox And Ha
[a href="index.php?act=findpost&pid=274618"][{POST_SNAPBACK}][/a]
My Firefox displays HA like you described when I check something like 'always use my colors' in the General options tab. Did you check that?
Best audio player for the power user: foobar2000
Firefox And Ha
@RedFox: I can't reproduce that. It looks lo-fi, but I can still see inside quote blocks.
[a href="index.php?act=findpost&pid=274777"][{POST_SNAPBACK}][/a]
Quote blocks yes, but no quote colors
NB: avatar images are displayed, the setting only affects colors, so it's indeed different from the lo-fi version.
Firefox And Ha
firefox 0.8 (win32) here, too lazy to update. all fine a-ok.
Firefox And Ha
this is a system-message: 'jkwarras' updated, now joining the league *thumb up*
good decision, isn't it..
Firefox And Ha
I was hoping you could check if you could see the quote block at home, but oh well.
[a href="index.php?act=findpost&pid=274768"][{POST_SNAPBACK}][/a]
I've just checked, and at home I can see the quote block correctly. But HA still doesn't look right
Firefox And Ha
[a href="index.php?act=findpost&pid=274772"][{POST_SNAPBACK}][/a]
No, I didn't have that enabled
Firefox And Ha
[a href="index.php?act=findpost&pid=274771"][{POST_SNAPBACK}][/a]
25% Firefox/Mozilla users
Firefox And Ha
[a href="index.php?act=findpost&pid=274809"][{POST_SNAPBACK}][/a]
Poll ?
Firefox without problems here. I love this browser !
I know that I know nothing. But how can I then know that ?
Firefox And Ha
Poll ?
No poll needed. What I quoted is the actual number.
Firefox And Ha
Poll ?
[a href="index.php?act=findpost&pid=274816"][{POST_SNAPBACK}][/a]
How do you know ? Are there any statistics ?
Firefox And Ha
I'ts possible for us normal user see Hydrogenaudio stats?
I'm a webmaster, an I am courious...
