Topic: Speex Armv4 Lib (Read 5440 times) previous topic - next topic
Speex Armv4 Lib
I noticed speex.org has a specialized release for ARM. Does anyone know if this release has the fixed point port enabled ?
If not, could I be given any guidance on how to compile the source with fixed point enabled for use on a Pocket PC (ARM) ?
Speex Armv4 Lib
Although I didn't build those, I would assume fixed-point is enabled. If not, you'll notice right away that it's about 100x slower than real-time (or worse).
Speex Armv4 Lib
can anyone tell me how to test / use the ARM release? should I run it on an ARM device? if so, how? thank you, thank you, thank you!
Speex Armv4 Lib
[{POST_SNAPBACK}][/a]
If you want listen speex files on PocketPC or PALM use TCPMP:
PALM - [a href="http://picard.exceed.hu/tcpmp/test/tcpmp.palmos.0.66e.zip]http://picard.exceed.hu/tcpmp/test/tcpmp.palmos.0.66e.zip[/url]
PocketPC - http://picard.exceed.hu/tcpmp/test/tcpmp.setup.0.66e.exe + http://picard.exceed.hu/tcpmp/test/speex.setup.0.66e.exe
Speex Armv4 Lib
[a href="index.php?act=findpost&pid=333716"][{POST_SNAPBACK}][/a]
May be it will be usefull...
There is an applicatiaon for Pocket PC - Resco Audio Recorder - it is a chenge for native dictaphone. And it supports real time Speex encoding. But RAE is not free.
Ogg Vorbis for music and speech [q-2.0 - q6.0]
FLAC for recordings to be edited
Speex for speech
