Topic: mppenc 1.15t (Read 20353 times) previous topic - next topic
mppenc 1.15t
mppenc 1.15t is out. It handles teh_sample properly now. The problem was a result
of aggressive compiler settings in previous versions.
The new versions for both Windows and Linux are now compiled by ak using GCC. It
allows for easier maintenance and ensures that we release compatible binaries
that produce the exact same encoded files.
The new encoder should produce files with a bitrate similar to 1.15s, but in many
cases slightly lower or higher (1-2 kbps at --standard). We've thoroughly tested it
on a Pentium 3, Pentium 4, Athlon, Athlon XP, Athlon 64, G5 (Mac). Speed is mostly
the same as before but on some computers it is slightly lower. Frank Klemm
advises to be very careful when compiling with certain flags and we've
followed this advice.
Future plans:
We're currently testing yet another problematic sample which could be indicative
of a problem with SV7 (SV8 can easily handle it). We're in direct contact with
Frank and it's possible that the next version of the code will include minor
changes to psy.c. It's time to tweak the encoder and slowly finalize SV7
before we tackle the more demanding challenge of a new stream version.
mppenc 1.15t for Windows
mppenc 1.15t for Linux
Musepack Tools for Mac OS X (compiled by kuniklo)
Musepack Forum Discussion
And if Warhol's a genius, what am I? A speck of lint on the ***** of an alien
mppenc 1.15t
Nice to see that mpc is alive and problems are taken care of.
mppenc 1.15t
I see that the MusePack page says 1.15t "has less problems with highly tonal music compared to 1.14."  How safe is it to use 1.15t as a replacement for 1.14?
"Have you ever been with a woman? It's like death. You moan, you scream and then you start to beg for mercy, for salvation"
mppenc 1.15t
As safe as letting your mother drive you to work.
There's nothing alphaish in 1.15 anymore. Frank himself said that 1.14 is uninteresting. 1.15t is the natural progression of Klemm's attempts to fix samples such as amnesia, Ventolin, Get Real Paid... In SV8, he managed to improve handling of those. 1.15f was a half-assed attempt, since part of his code that handled those could not be ported back to SV7 (technical limitations of SV7). Our goal is to reach 1.16 and make it as good as possible when it comes to quality. It's a long way, but choosing 1.14 only means going backwards as far as transient-handling is concerned.
As always, trust your ears, not my words.
mppenc 1.15t
Great news, thanks for the announcement seed
mppenc 1.15t
Very nice, thanks.
mppenc 1.15t
Very Good News, Many thanks Seed
mppenc 1.15t
Will SV8 become a transform coder or not? I remembered Frank have intended to a transform coder in SV8 somewhere.
mppenc 1.15t
It is nice to see that MPC is alive and a team is bringing its development ahead
mppenc 1.15t
Seed, when should we await final 1.15 beta?
stimulating the audio nerve directly
mppenc 1.15t
[a href="index.php?act=findpost&pid=269218"][{POST_SNAPBACK}][/a]
when it's finished
Thanks to the mpc development team !
mppenc 1.15t
There will be no final 1.15 beta.
The final beta will be 1.16.
AFAIK the Musepack versioning works like this:
Even numbers -> Beta (eg. 1.14)
Uneven numbers -> Alpha
Edit: Actually Seed explained the development roadmap in his second post.
mppenc 1.15t
Hmm, what about stable then? Seems a bit tricky. ;-)
mppenc 1.15t
[a href="index.php?act=findpost&pid=269632"][{POST_SNAPBACK}][/a]
Those are the even numbers that are divisible by an even number of uneven numbers.  For dithering reasons.
"All I ask is that composers wash out their ears before they sit down to compose." - Morton Feldman
mppenc 1.15t
I couldn’t resist and did few tests yesterday.
1/ creaking.wav
mpc had serious problems with this sample (I’ve often described this artefact as “boiling oil” sounding).
1.14 = the artefact is obvious, and easy to ABX (8/8)
1.15t = the boiling sound is seriously reduced. But additional noise is still audible. Clearly less annoying though. (7/8)
1.14 vs 1.15t = 11 out of 16, pval = 0.105
I was disappointed by this score, because difference seemed to be obvious. I therefore launched a second test: 14 out of 16, pval = 0.002 [/|\ with ABC/HR 1.1b2 you have to shuffle again the samples in order to perform a new test]
TOTAL = 25/32 which should be a significant result (pval = 0.001 according to KikeG’s binomial table)
2/ orion II.wav
another micro-attacks sample
1.14 = there’s additional noise (7/8)
1.15t = noisy too (appeared first as noisier than 1.14) = 8/8
1.14 vs 1.15t =  10 out of 16, pval = 0.227 [pure guess, I didn’t insist]
3/ mahler (chorus)
I’ve used this very tonal sample for my previous ~175 kbps listening test, and it appeared to be the most disappointing one for mpc 1.14.
1.14 = “ugly voices” (7/8)
1.15t = uglier” (8/8)
I’ve performed a second test to confirm this failure:
12 out of 16, pval = 0.038
This last result is now significant, but the total score isn’t; therefore, last test:
15 out of 16, pval < 0.001
=> TOTAL = 37/48 (pval = 0.000)
I think it could be safe to say that (for my ears) 1.15t lowered the quality of this tonal sample.
4/ Hymnus peregrinorum - Dum pater familias.wav
Another vocal sample, mix of tonal and guttural voices (deep bass). I focused my attention on 2.3 – 4.0 range (raucous voice).
1.14 = sounds distorted (7/8, easy)
1.15t = also disorted, maybe slightly more (7/8)
1.14 vs 1.15t = 12 out of 16, pval = 0.038
It confirmed the (subtle) regression of 1.15t encoding. I must nevertheless add that I was really surprised to obtain a positive score
5/ I went to bed ;-)
log files (uninteresting: no additional comments)
I could upload samples later.
mppenc 1.15t
guruboolez what profile were these tests performed on? I believe the most significant 1.15a improvements were on the insane profile
mppenc 1.15t
Sorry, I forgot to precise it.
--standard --xlevel for 1.14 & --standard for 1.15t
mppenc 1.15t
Could you provide the samples somewhere ? Posting results without any way to check ourselves is a bit useless imo.
If the samples are too long, it would be great if you could also say where exactly the artifact is.
It's a 'Jump to Conclusions Mat'. You see, you have this mat, with different CONCLUSIONS written on it that you could JUMP TO.
mppenc 1.15t
ftp://ftp2.foobar2000.net/foobar/
Some are already available. I'll upload the other tomorrow.
mppenc 1.15t
Once again, here's how it works:
Alpha = 2 decimal places, odd (e.g. 1.11, 1.13a, 1.15t, etc.)
Beta = 2 decimal places, even (e.g. 1.12, 1.14, etc.)
Release = 1 decimal place (e.g. 1.0, 1.1, etc.)
So, the next logical beta is 1.16, and the next logical release is 1.2.
Regards,
Madrigal
mppenc 1.15t
[a href="index.php?act=findpost&pid=269691"][{POST_SNAPBACK}][/a]
Some samples are very large, like 30s. So could you also define the exact part where you heard the artifacts ?
mppenc 1.15t
I was sampling throughout the weekend and didn't find any problems.  I do my tests with --insane.  I confirmed 15t handling teh_sample.  It also seems transaparnet on Bloch_Formule, Walkyries_short, and amnesia.  It also tested transparently on Kraftwerk's Tour de France, Eels' My Beloved Monster, and Jolivet Suite en Concert pour flute et percussion - Hardiment.
But, then, I lack the classical range of guruboolez.
I confirmed a problem with the Mahler Chorus, but not in "ugly voices".
14/17 (0.6%) for the first 11 seconds.  In this section, what consistently tipped me off was a collapse (or some odd channel variation) of the stereo image toward the end (from about the 8.5 second mark during the TOOOOOOOOOOO).
At the 18-19 second mark, I thought I identified loss in sharpness in the female voice, but at 16/25 (11.5%), it apparently isn't huge (that and I actually preferred the less sharp MPC voice).  The male voice in the 20-22 second range seems to have more tonal variation in the original, but I scored 16/25 again.
Since 15s GCC was my preferred version before t (TOOOOO a t, an alpha MPC...  ), I tested Mahler on it.  13/17 (2.5%).  The problem seemed to have shifted to a little earlier in the section and I felt like I needed to listen more closely to identify which was which.  I didn't test the other parts.  I did listen to the whole sample to see if 15s GCC created any different problems.  Nothing stood out.  At 823 KB vs. 878 KB for t, I may stick with 15s GCC.  I do want to give the rest of guru's samples a try, however, and will report back later today or tomorrow.
foobar2000 v0.8.3 facilitated the testing.
mppenc 1.15t
Tested using --insane:  transparent
Tried focusing on the section guruboolez indicated along with just before it up to 1.8, the start, and the last 4 seconds.  Nothing better than 60%.
mppenc 1.15t
samples:
ftp://ftp2.foobar2000.net/foobar/creaking.exe
ftp://ftp2.foobar2000.net/foobar/Pierres_Reflechies.exe
ftp://ftp2.foobar2000.net/foobar/Orion_II.exe
and the old ones:
ftp://ftp2.foobar2000.net/foobar/Hymnus_peregrinorum.zip
ftp://ftp2.foobar2000.net/foobar/03_mahler.exe.wv
*.exe are wavpack self-extractible files (Win32). Add .wv extension if you want.
Lefungus> for 03_mahler.exe.wv sample, the problem is audible at least on the beginning (first seconds); I've ABXed it on the middle (the loudest part of the sample, near 00:14 - 00:18.
