Topic: Foobar Gallery (Read 1809517 times) previous topic - next topic
Foobar Gallery
Reply #2475
How does the album art precisely work?
Do you have to have a .jpg of a cover in the folder along with the madsak or is it like freedb?
Also is it just another window you can turn on and off like the spectrum analyser.
[{POST_SNAPBACK}][/a]
yep you have to have a picture in the Dir of the Album.
But there is also a tool which fetches those from Websites: [a href="http://www.hydrogenaudio.org/forums/index.php?showtopic=29876]Link[/url]
Foobar Gallery
Reply #2476
Mazy could you share your foobar's config of the darktheme?
thx[{POST_SNAPBACK}][/a]
sure, get it [a href="http://mazy.johanka.cz/temp/mazy_settings_2_dark.rar]here[/url]. it's modified Lyx's Navigator.
i'm now experimenting with subscript numerals and hacks to visually separate trackinfo panel (using extended and customized box-drawing characters):
[/i]
[a href="index.php?act=findpost&pid=375988"][{POST_SNAPBACK}]
Would you be willing to share your .fcs please? Either one is fine
Foobar Gallery
Reply #2477
i got a question, in my infopanel (for version 8.3) there is a "? at ?" all the time, when showing last played, underneath there is the date which seems ok, but i want to erase this "? at?".... how can i do this?
here is my code:
$char(10)$char(10)$if(%_trackinfo_notrack%,No track,
------------------------------------------------------------------------------------------$char(10)
%artist%$char(10)
- %title% ->%_length%<-$char(10)
$if3(%album%,still unknown))$char(10)
Jahr: $if3(%date%,unbekannt)$char(10)
$char(1)CQualität:$char(10)
%__codec%      Bitrate: %__bitrate% Kbit/s$char(10)
$char(1)CStatistik:$char(10)
Dieses Lied wurde %play_counter% mal gespielt! $char(10)
Zum letzten mal: %play_date% at %last_played%$char(10)
Foobar Gallery
Reply #2478
Here is mine so far.  Working out the spacing bugs in the menu row, and the seekbar.  The album list in the top left is a filler until the album art plugin is ported
[a href="index.php?act=findpost&pid=375853"][{POST_SNAPBACK}][/a]
Thats really nice!  One question tho, how did u get the time playing percentage bar at the bottom?
[a href="index.php?act=findpost&pid=375899"][{POST_SNAPBACK}][/a]
Some of this is from a config I found over at Neowin, but here is the code;
$puts(progress_%,
$if(%_time_total_seconds%,
' '808080$pad_right($muldiv(%_time_elapsed_seconds%,100,%_time_total_seconds%),3)808080'%'' '
Bostitch vs. Swingline; Choose your stapler wisely.
Foobar Gallery
Reply #2479
whats the code to center some txt, like in the main bar window or in the track  info box
Foobar Gallery
Reply #2480
sure, get it [a href="http://mazy.johanka.cz/temp/spex04-mazy-mod.rar]here[/url] ... you would need font like calibri for it to work properly ...
richardtodd: $tab() works in most places (you have to use two for centering the middle part), $char(1)C for track info panel (it has to be first string on some line).
Foobar Gallery
Reply #2481
heres my sexy setup...
Go the 80s!
Foobar Gallery
Reply #2483
my current 0.9 setup. thanks a lot to mazy who helped me, figuring the playlist switch-style out :-)
@fegul: when i add the progressbar code you pasted to the status bar config nothing really happens.. :-(
Foobar Gallery
Reply #2484
Hi mazy,
I really like what you did with your track_info panel.
Would you mind sharing your settings?
ty!
Foobar Gallery
Reply #2485
My new 0.9 setup
Foobar Gallery
Reply #2487
Improved with new plugin releases:
Now all I need is uie_tabs so I can fit explorer tree in there like I used to (and projectM if it gets revived), and I'm happy as a lark!
Foobar Gallery
Reply #2488
Hi mazy,
 ty!
well it was just 'experiment' with that modified font ... you can get the font [a href=\"http://mazy.johanka.cz/temp/calibrib_test.rar]here[/url]. the tagz string is nothing special ...
trackinfo settings - font: Calibri MOD2 bold 14pt, vertical padding: 0px, horizontal padding: 5px, minimum height: 25px, line spacing: 0px, default text: white, default background (r g b):  119 213 249.
// t 255, b 119 213 249
//$puts(c_less,EEBF33)$puts(c_sep,EEC139)
//$puts(c_less,EEBF33)$puts(c_sep,f0f0f0)
$puts(c_less,FEEFBF)$puts(c_sep,f0f0f0)
// t 170, b 240
//$puts(c_less,CCCCCC)$puts(c_sep,CCCCCC)
//$puts(sep, $get(c_sep)• )
$puts(sep, $get(c_sep)┇ )
$ifgreater($len([%album%][%artist%]$if2(%title%,%_filename_ext%)),
100,
$char(1)C[%artist%$get(sep)]$if2(%title%,%_filename_ext%)
$char(1)C
$if(%album%,$get(c_less)%album%$get(sep),)
$if(%artist%,%artist%$get(sep),)[$if2(%title%,%_filename_ext%)]
Foobar Gallery
Reply #2489
I missed something - where's the v0.9 issue of track_info?
- edit - never mind, I just found it.
- edit2 - however, I still can't find instructions for getting panels on top of v0.9.  Can someone point me, please?
voted 'Most likely to veer your thread' three straight years!
Foobar Gallery
Reply #2490
Foobar Gallery
Reply #2491
[a href="index.php?act=findpost&pid=376310"][{POST_SNAPBACK}][/a]
Could you share me the formatting of your playlist view?
Inter Deum et Diabolum semper Musica est", Tanzwut
Foobar Gallery
Reply #2492
Here's mine...
Foobar Gallery
Reply #2493
Could you share those buttons for .9?
[a href="index.php?act=findpost&pid=376377"][{POST_SNAPBACK}][/a]
Foobar Gallery
Reply #2494
//offtopic
Some ppl already using albumart plugin with the new v0.9 of foobar. How?! I have read the albumart topic, no new version for foobar2000 0.9 is available yet. Am I missing something?
I don't speak English very well, please excuse me!
Foobar Gallery
Reply #2495
[a href="http://img93.imageshack.us/my.php?image=screen000007dr.jpg" target="_blank"]
PS: for Ivanov. Album art is arrived  still in alpha but working. Check the thread.
Foobar Gallery
Reply #2496
//offtopic
Here's a first experimental alpha version for 0.9. It works, but not completely. I think some menu items are broken, and maybe some other things, but it appears to be basically functioning.
[a href="http://stephan.kochen.nl/proj/foo_uie_albumart/foo_uie_albumart.dll]Download[/url]
I'm going to fix some known stuff tomorrow probably, and then I'll upload a new version and some source code.
If something breaks, do tell.
[a href="index.php?act=findpost&pid=376247"][{POST_SNAPBACK}][/a]
Foobar Gallery
Reply #2498
There is a way to take a screenshot of the active window only? Or I need to edit it everytime I take a SS?
[span style='font-size:8pt;line-height:100%']moderation: please refrain from inlining images larger than roughly 800x600 and 80KB. please use thumbnails and/or links for large pictures instead.[/span]
-foobar2000 + Burrrn + EAC
-HD 80Gb using High QualityVBR MP3s
Foobar Gallery
Reply #2499
[a href="index.php?act=findpost&pid=376481"][{POST_SNAPBACK}][/a]
ALT+Print Screen
