Topic: Channel Mixer (foo_channel_mixer) (Read 537335 times) previous topic - next topic
Reply #450
I'm not sure what DH is but from what i understand it's a VST modelling algorithm built into the firmware of some devices.
It is also available in some software DVD players such as PowerDVD. And there is DH wrapper component.
Reply #451
TB IsoneSurround.
In internet you can find jb isone pro surround v1.0.1, which works without limitations.
Thanks!!
JB Isone Pro Surround is brilliant. I even managed to calibrate it for my UE5 earphones!
CMSS3D is limited to headphones only. As for DH and TB IsoneSurround -- just tested them; they're overall tolerable, but i certainly wouldn't use them for music since they enforce reverberation and it always makes a mess out of music :)
Reply #452
Hi Skipyrich,
I'm a request for you could you please create a VST version of your Channel Mixer foobar2000?
I think it's a very good plugin for stereo upmix; There's nothing on the web like yours. It would be possible feed with your VST a dolby digital headphone wrapped dll (six channel input and two channel output).
With a VST HOST in this way we could give dolby digital to everykind of audio card to whole system with ASIO DRIVERS.
Best Regards
Tony
P.S.
Thank you in advance for your answer.
Reply #453
Hi, I hope someone can answer this for me..
I set 'convert mono to stereo' for a mono flac file I had, then forgot I had the DSP set.
All the files since then have been stereo.. I've probably processed 100 tunes.. will all these be converted one (Left?) channel of the files into dual mono now?
I always delete my flacs after I extract them to wav files, so that would suck
Does the plugin check if the file is stereo before attempting the mono to stereo DSP?
I am fearful I might have ruined a bunch of wavs
edit: a quick look in winamp at some wav's I created seem to be proper stereo files.. confirmation would be nice though
Reply #454
Hi!
First of all, big thanks for this powerfull plugin!
But (sorry) I have a problem, I can't save settings. I want to increase center volume, after a restart all settings are reseted even if I save them in "default" profile. I also tried to create a new profile but they are reseted after a restart.
Here is the report :
Core (2012-11-25 10:24:36 UTC)    foobar2000 core 1.1.18
foo_albumlist.dll (2012-11-25 10:23:28 UTC)    Album List 4.5
foo_audioscrobbler.dll (2010-06-04 07:27:04 UTC)    Audioscrobbler 1.4.7
foo_cdda.dll (2012-11-25 10:23:06 UTC)    CD Audio Decoder 3.0
foo_channel_mixer.dll (2011-06-01 17:18:00 UTC)    Channel Mixer 0.9.6.7
foo_converter.dll (2012-11-25 10:23:02 UTC)    Converter 1.5
foo_dsp_std.dll (2012-11-25 10:23:20 UTC)    Standard DSP Array 1.0
foo_dsp_vstwrap.dll (2009-05-11 16:08:58 UTC)    George Yohng's VST Wrapper 1.2
foo_fileops.dll (2012-11-25 10:21:52 UTC)    File Operations 2.2
foo_freedb2.dll (2012-11-25 10:23:32 UTC)    Online Tagger 0.7
foo_input_monkey.dll (2011-02-24 10:13:54 UTC)    Monkey's Audio Decoder 2.1.5
foo_input_std.dll (2012-11-25 10:23:00 UTC)    Standard Input Array 1.0
foo_playcount.dll (2012-06-11 18:09:57 UTC)    Playback Statistics 3.0.2
foo_rgscan.dll (2012-11-25 10:22:36 UTC)    ReplayGain Scanner 2.1.2
foo_ui_std.dll (2012-11-25 10:22:46 UTC)    Default User Interface 0.9.5
foo_unpack.dll (2012-11-25 10:23:00 UTC)    ZIP/GZIP/RAR Reader 1.6
I only use this DSP :
Equalizer
Channel mixer
I'm under Seven 64bits.
Any idea?
Reply #455
I tried to delete foo_channel_mixer.dll.cfg in my profile folder. Then restart, increse center volum => fb2k write a new foo_channel_mixer.dll.cfg. Then restart => channel mixer settings reseted.
Reply #456
Hi!
I've a strange problem with foo_channel_mixer and foobar(last and older version also). I've 5.1 setup and upmix from stereo to 6 channels. When I'm change track subwoofer sound disappear and only solutions is restart foobar. Everything work with keyboard UP-DOWN selections and ENTER as a start playback key but not with mouse double click. With first play after start the program, I've a subwoofer sound everytime and only changing manually with mouse have this issue. I've try a clean instalation of windows and foobar, onboard Realtek and USB Maya U5 soundcard, different chanell mixer, foobar settings also  WASAPI ASIO KS DirectSound  but not luck.
My setup is Acer 5930g laptop, Maya U5 DAC with analog 5.1 speakers, Windows 7 x64.
Any ideas, someone have a similar problem?
Reply #457
Hello sir. thank you very much for this plugin
right now I'm mixing up my stereo music to 6 channels for my headphones.
Everything sounds great.
But i have to wait long time for changes for example on the speaker configuration
to be applied.
Is that normal?
It normally takes ~7 seconds to change the settings.
My system:
- Gigabyte h77 d3h
- xeon e3 1230 v2
Reply #458
This time depends on output buffer size.  File->Preferences->Playback->Output->Buffer length
Reply #460
Hi!
Hey konradoo77, have you fixed the problem with disappearing subwoofer after skipping or changing track in tracklist? I have the same Problem and no idea to fix it.
I found that I can reactivate the subwoofer signal without restarting foobar when I start a new track with differnt KHz. So when subwoofer signal is lost I could start a track with 96 Khz or so and then after 44.1 Khz is working again. But that is very complicated and not useful.
Did you find any other solution?
Greetings from Berlin
Reply #461
Hey klingklang, nice catch! With directsound output it's also work for me, but I use KS and must have resampler with it and sadly it's still buggy.
Reply #462
Thank you. What is "KS"? The message from hydrogenaudio was in my spamfolder. Please excuse the late response.
Reply #463
Kernel Streaming ?
Reply #465
I have some 8-channel FLACs that only have stereo content (i.e. all channels are silent except FL and FR), so I tried to use this component in a Converter job to produce 2-channel FLACs. The output files are still 8-channel, though, no matter what settings I choose. I tell it to output 2 channels, and only FL and FR are selected. Doesn't matter what I choose in the Downmix tab. Am I doing something wrong?
Meanwhile, the stock 'Downmix channels to stereo' DSP does what I want; the resulting files report as stereo, not 8ch, and they are smaller (by 2 or 3%), as expected.
Reply #466
This component doesn't handle 8 channels.
Functionality:
    * - (up|down)mix (to|from) 1-6 channels
    * - redirect bass to subwoofer channel (6-channels output mode only)
    * - delay rear channels by 1-40 ms (4 or 6-channels output mode only)
    * - surround sound effect (2->4 or 2->6 mode only)
    * - changing virtual width of a stereoimage
    * - etc...
Reply #467
Ah, so I did miss something.
Re: Channel Mixer (foo_channel_mixer)
Reply #468
If open the settings via fb.Run Main Menu Command ( "View / DSP / DSP # 1 config");
or any other # 1,2,3 .... - foobar2000 has crashed
Perhaps there is a solution to this ?
Reply #469
I'm afraid not, I think this happened since foobar2000 added that menu. Workaround: don't use it.
To my surprise menu -> Playback -> Channel Mixer  seems to work now.
Reply #470
The "View\DSP\DSP #* Config" menu items are a feature of foo_dsp_effect, and are broken. If you'd submitted your crash report, you would have seen which component it was caused by. Either remove that component, or do not attempt to use that feature until mudlord manages to fix it.
Reply #471
That feature was broken from the start. It should be burned in hell.
The intent is to completely redo that component, starting from that menu only exposing DSPs that foo_dsp_effect creates (since the component does many things I do not like). I'd advise not to use the component at all, since there is no ETA on the rewrite. It depends on several things such as:
* Real-life work/volunteering things. And things related to said vocational stuff.
* Other projects (such as DRM and executable compression. The DRM stuff was a major priority and still is).
* Other things, such as time spent on other things like computer gaming and family.
* Completely arbitrary stuff such as the phase of the moon and the timing of the vernal equinox (yes, I can be mentally unstable, which drastically affects my usefulness as a human being).
* Motivation. Computer games and just being not bothered fits into that too.
Reply #472
@mudlord Don't be mad, just be happy people still like your software and use it regularly. They'll still be happy to wait for future updates or rewrites or whatever.
Reply #473
I have the latest Foobar 1.3.13, and I am using Channel_mixer only to widen or reduce the stereo scene, there are two ways to get to channel_mixer, from the drop menu file "preferences DSP manager" and from the menu playback "channel mixer" , the modifications made in channel_mixer from menu playback are never taken in account,, it stays stuck with setting from preferences.
thanks for your attention.
POL
Reply #474
This was such a cool thing but since I've updated foobar doesn't work anymore, I used your component to be able to use all my 5.1 speakers and sub woofer even with non 6 channel songs (stereo songs), so sad that it doesn't work anymore and to hear that the developer has life problems.
