Topic: foo_playlist_tree (Read 713093 times) previous topic - next topic
foo_playlist_tree
Reply #1350
I set the double click action in playlist tree to "Playlist Tree/Play in Library Playlist" and it's functioning as it should.  One question:
Is it possible to configure playlist tree so that as soon as a song I have played by double clicking it in playlist tree finishes, the next track begins?  e.g., if I double click \mp3\artist\album\track 6, when track 6 finishes, track 7 begins?
or more succinctly, is it possible to make every folder in playlist_tree act like a playlist?
foo_playlist_tree
Reply #1351
Its not currently possible.
There used to be a link to my website here.
foo_playlist_tree
Reply #1352
Everybody of us who uses PT and the Browser has made a decision how to organize the interplay of these two components: you can browse nodes by singleclick or by doubleclick, also you can set that browser playlist is automatically activated or not. You even can combine these 4 possibilities with different ways how the library playlist is handled.
But there would be a behavior that is the most interesting and (for me at least) the most useful.  It requires a special command for doubleclick in PLT: "[local] activate browser playlist".  This command just makes sense if you use singleclick for browsing and has unchecked the automatical activation of the browser playlist.
What would be the advantage?  You don't have to decide if you like the automatic activation of browser playlist: a singleclick just fills the browser and a simple doubleclick opens also the browser playlist - very easy to use!
In that context i also would like to wish the feature of the socalled preview version: Add/Send to selected folder. Then you easily can browse a node by doubleclick, singleclick a special folder that should be filled with tracks and send them from playlistview by hotkey, context menu or buttons. (Nice side effect: the easy sending from folder to folder inside pt panel by context menu)
Have a nice day, all you!
foo_playlist_tree
Reply #1353
I added "Activate Browser playlist menu option" as a feature request in the browser list.  It would really belong as part of browser, not playlist tree.
foo_playlist_tree
Reply #1354
PLT 2.2 beta 2
Let me a quick check:
is the #tag# function for getting multi values broken?
Edit:  just found in your forum %<tag>%.
foo_playlist_tree
Reply #1355
Is there a way to change to defualt icons set?
Is there a way to customize the "open folder" icon and "open query" icon?
Thanks,
Amit.
foo_playlist_tree
Reply #1356
I have a drop query set to read the contents of a folder that is not included in the "Music folders" list in the Media Library.  Because these songs' metadata is not stored in the database, when I refresh the query, the metadata is not read, and all the songs end up lumped together in the query root.  Is there anyway for Playlist Tree to read the metadata when it refreshes to properly create the subfolders?  It seems possible, since files that are not in the media library can still be inserted into playlists and have their metadata read and even saved between foobar sessions.
foo_playlist_tree
Reply #1357
An little annoyment that happens often enough is that a node is selected and library playlist is activated when you right click a node or expand it by clicking the +button. This only happens if nothing is selected in the panel - once a selection is done that behavior doesn't occur. The easiest way to reproduce this is to click the +button of a node directly after fresh start of foobar.
foo_playlist_tree
Reply #1358
Are you using the latest version?  I thought that the last couple version support this.
foo_playlist_tree
Reply #1360
This is the way the treeview control works by default and it would be a hassle to work around it.
foo_playlist_tree
Reply #1361
I like this Plugin very much, but there ist one thing i miss since the last version for 0.8.3.
There i could do a query according to %systemdate% (comparing to %last_played% e.g.). But now it seems this feature went away?
Is there a way to access this variable?
rainer
foo_playlist_tree
Reply #1362
Does @and only work with @node queries?  I tried doing
@drop<c:\directory1> @and @drop<c:\directory2>
and it only takes files from directory 1.
foo_playlist_tree
Reply #1363
i'm having this issue with playlist...when i drag & drop some folder to playlist tree it loads also playlist and result is having duplicate tracks. is there some setting in playlist tree to not read playlists in folders.
foo_playlist_tree
Reply #1364
I had a little bit time to test the newest beta and many of the new features works well. But the new sorage technique confused me a little bit - there are two problems:
1. If you create some panels in one layout everything is fine. But if you add a panel in an other ColumnsUi layout this panel is not really a new one but an old one from first layout. The only solution i see: I have to create all panels in first layout, then to choose by context menu in second layout the panel i like and at last i have to remove that panel in first layout.
2. just the switching from one layout to an other causes that my panels are swapped: they display other stored pts.files (Note: i just tested inside tabbed panels)
I thought it could be a bug because that doesn't happen in album list and it even doesn't happen in PT too after a redrawing tree by context menu. But i hope you can understand the annoying factor. Sorry!
foo_playlist_tree
Reply #1365
cwbowron, are you able to reproduce these problems, or am I doing something wrong?
foo_playlist_tree
Reply #1366
It should work, but I cannot test it right now.
do you mean @and or do you really mean @or?  @or would be if you want the contents of BOTH directories.  @and would be if you want the files that are in both.
foo_playlist_tree
Reply #1367
I should have been using @or, but that still doesn't work.
foo_playlist_tree
Reply #1368
Very small suggestion:
Similar to behaviour of Windows Explorer, the currently selected folder may be displayed with the expanded icon. I'm using a Windows XP icon set and it would slightly increase the feeling of authenticity?.
How do I enable this?
EDIT: Never mind.
foo_playlist_tree
Reply #1369
Bug
Don't know if this has been reported. When I enable 'Hide Lines' in the preferences the top nodes +/- disappear.
foo_playlist_tree
Reply #1370
Bug
That's a limitation of the treeview control.
foo_playlist_tree
Reply #1371
I changed the tabbed panel to a normal splitter and the second point still occur: all the panels change their places. Do i something wrong or is this a bug?
foo_playlist_tree
Reply #1372
It's a known issue.
foo_playlist_tree
Reply #1374
Bug
Why would you even have this option if it doesn't work properly?  I can't expand the top nodes if the +/- is gone. Awesome plugin other than that btw.
