Topic: How to "create" a unique GUID? (Read 4355 times) previous topic - next topic
While making my own plugin, I have used code from musicmusic's modded foo_search_ex.
Among other things, I "borrowed" this:
// {7E409D65-CBE2-41f8-B366-200BFEEEBC40}
const GUID navigator_extension::extension_guid =
{ 0x7e409d65, 0xcbe2, 0x41f8, { 0xb3, 0x66, 0x20, 0xb, 0xfe, 0xee, 0xbc, 0x40 } };
only changing "search_extension" to "navigator_extension".
If I understand this correctly, this is a unique ID, and I guess it isn't such a good idea to copy it from another plugin if you happen to use both plugins, so I should probably have my own GUID. But, where/how to get it?
upNorth:
I use a utility from VisualStudio called "guidgen.exe". I believe it's located in the Common > Tools folder of the VisualStudio install. As far as I can remember, there are no dependencies.
[a href="index.php?act=findpost&pid=251978"][{POST_SNAPBACK}][/a]
Thanks, stevekim
The solution was just as simple as I expected it to be...
