Topic: WMA Codec update (Read 5700 times) previous topic - next topic
WMA Codec update
Hi
i use lame 3.90.3 to encode my cds
but i would like to give a try to the microsoft wma codec/encoder
where can i download ?
is it free or?
i need only the encoder
WMA Codec update
Hi
is it free or?
[{POST_SNAPBACK}][/a]
Maybe you'll change your mind after reading this:
[a href="http://www.rjamorim.com/test/multiformat128/results.html]results of Roberto's latest listening test[/url]
There's also "WMA Pro" which seems to sound better than "WMA Standard" at very low bitrates, but there's no hardware support for WMA Pro yet.
WMA is a set of closed-sourced codecs which can be (currently) used for free AFAIK.
Unfortunately I don't know where you can get the encoder.
(To be honest: I don't care much about WMA since either the quality is poor (standard) or there's no hardware support (pro))
HTH,
SebastianG
WMA Codec update
just give it a try, think twice if you want it for archival purpose
This is what I predict
If, If.......One day M$ bankrupt, WMA will also be gone together with it
WMA Codec update
Indeed, I gave WMA 9.1 STD a go a few weekends ago and finally discovered for myself why everyone bashes this format so much. The only level I wasn't able to easily ABX was the highest VBR level available in WMP10, as well as lossless of course. And I'm not even that good yet at ABXing either, so what does that tell you?
WMA Codec update
yes thanks!
but should i update Windows Media player?
i use w2k , but i have never updated my built in plauer
or?
WMA Codec update
yes thanks!
or?
To test Ripping CDs to Windows Media Audio 9 Codec, you will have to update to Windows Media Player 9.
[a href="http://www.microsoft.com/windows/windowsmedia/9series/player.aspx]http://www.microsoft.com/windows/windowsme...ies/player.aspx[/url]
...and also that applies for Individuals, Apple, Real and all that, right?
McoreD
WMA Codec update
McoreD
[a href="index.php?act=findpost&pid=249887"][{POST_SNAPBACK}][/a]
Well, AAC won't be gone.
WMA Codec update
[a href="index.php?act=findpost&pid=249572"][{POST_SNAPBACK}][/a]
EXACTLY
one more thing,
WMA is inferior to mp3 at higher bitrates (>128kbps)
hahahhahahahah, WMA STD or even PRO is loosing to AAC at lower bitrates!
I tried it myself, iTunes4.6/Nero aac at 80 or 96 is better than WMA STD
at 64 kbps, Vorbis, Nero HE-AAC, iTunes4.6  AAC sounds better than wma
a few years back, WMA is the best codec for bitrate 64kbps
but now NO MORE, Its not a winner at any bitrate.......so sad...........pittyful m$
