Topic: Columns UI (Read 4608420 times) previous topic - next topic
0 Members and 10 Guests are viewing this topic.
Columns UI
Reply #5625
well that really is odd. i have images in my group header and they appear fine even when adding files from explorer. but i've just checked the documentation and there is a variable so you can try it...
%el_foobar2000_path%
Columns UI
Reply #5626
Hey, thanks a lot for your assistance. Everything works fine now. By the way, may I know where can I find the docs for Panel Stack Splitter and ELPlaylist?
Thanks. =D
Columns UI
Reply #5628
Can't add new "Playback / DSP Settings / Preferences" command to toolbar button.
It is possible in DUI
Columns UI
Reply #5629
question about album list panel.
since my last reinstall and ui rebuild, its started doing this:
http://i46.tinypic.com/2ij3mvq.png
http://i49.tinypic.com/x1wwec.png
http://i50.tinypic.com/3599xtw.png
http://i50.tinypic.com/33b34go.png
look at them in order, it should be pretty clear whats going on.
previously when something was long enough to go "outside" the confines of the panel, it would just do so, and i could mouse over it to see a yellow tooltip of what the whole thing was.
NOW when something is too long, the whole thing auto scrolls along, which you can see becomes a bit of a problem with super long named stuff or when i'm 3-4 sub-items down, because i have to slowly close each one up before i can see the "left" side of my panel again.
Is there any way to stop the panel auto scrolling along to the right hand side of the currently selected item? because i'd really rather it just stayed stuck at the left and things that were obscured just remained obscured. i know what 99% of my stuff is just by the first 1-2 letters anyway so its not a big problem for me if stuff gets obscured by the edges, but the auto scrolling to compensate, is a big problem.
i dont know why its started doing this, my layout was entirely the same, so i've gone back and tried previous versions of the panel too (0.3.3 and 0.3.4) and neither of these "fix" or remove this functionality.
Columns UI
Reply #5630
nevermind
i found a really old version (0.2.2) and its stopped doing it now.
sweet
Columns UI
Reply #5631
Im kinda new to foobar and this component. I saw some layout and made mine like some of those. But I encountered some problems.
1) I don't get my edges to completely disappear even choosing"none".
2) Im also trying to understand the global style. However, some format isn't listed in the titleformat page, like %_themed%, %_is_group%, %offset_colour, etc
Columns UI
Reply #5632
Hi there,
Artwork like artist picture or back/disc cover are not shown in NG Playlist but in artwork view.
Greets,
Frank
Help me! The beetles have trapped me between the walls...!
Columns UI
Reply #5633
Did you already a right-click on a column's header and ticked "Artwork"?
Columns UI
Reply #5634
Hehe... yes, I'm not a foobar-noob!
FEATURE REQUEST:
Actually art work is shown in my artwork column but only the normal album cover. If there is no album cover, e.g. for classic music, I want to have the composer instead an album cover. It is well cycled in the artview panel automatically. And that is the behaviour I want to have in the artwork column. You see?
And that is the point: I want to use the predifined source labels under Preferences > Display > Columns UI > Artwort.
I don't want to add my artist/composer art resource folder under "Front Cover". And I don't wanna write another script, because the functionality is there (see artwork panel) so I think it could be easily implemented to the artwork column.
Nice day,
Frank
Columns UI
Reply #5635
Feature request - ability to toggle show/hide artwork column without going to preferences / having columns headers shown (solution: i.e. as an item in view menu, therefore possible to bind to a hotkey too)
Columns UI
Reply #5636
See Robertina 2 posts before...
Columns UI
Reply #5637
That is not the way lwiczek is asking for:
Columns UI
Reply #5638
Exactly - I want an shortcut/menu item for: right mouse button on column header -> artwork. For the moment is the only option to toggle it without going to preferences... and it's the only thing why I keep those headers on (not using it for sorting - autoplaylist mostly, nor for changing column width - prefer automatic as well)
Columns UI
Reply #5639
i really searched and tried quite a bit but couldn't get it running to my likings.. so heres my question:
i have GENRE and STYLE tagged to my files with foo_discogs and i would like to have a filter panel that searches both (multiple-)fields.
it seems i am just too stupid to figure it out by myself.
thx!
Columns UI
Reply #5640
How do I get the default buttons back? (The Foobar2000 ones not the Columns UI ones)
EDIT: Where's the other visualizations gone?
Columns UI
Reply #5641
In Items Detail panel the variable %isplaying% works only when Displayed track is selected to Automatic or Playing item (returns 1). In case of selecting Current selection/Playlist selection it returns "?", which is a bit annoying... Is it by design? Selecting Current selection/Playlist selection doesn't mean that selected track can't be displayed as the "Playing one" (i.e. adding progress in case selected track is actually playing ATM)
Columns UI
Reply #5642
How do I get the default buttons back? (The Foobar2000 ones not the Columns UI ones) ... EDIT: Where's the other visualizations gone?
Both Columns UI and the Default User Interface have their own button set. So either you have to switch back to the DUI or you have to customize the buttons in CUI (right-click on the buttons toolbar -> Options).
The other visualizations (I assume you mean Oscilloscope, Peak Meter, Spectrogram, Spectrum and VU Meter) are accessible through the main menu "View -> Visualizations", but they can not be integrated into a CUI layout as this is possible with the Default User Interface.
Columns UI
Reply #5643
How to make column to appear on particular playlist, but also to be available on other playlists (with right click on titlebar)?
If this is not possible as I think, any chances of implementing it?
Example:
%last_played% column - if I enable show only on "*played*" then I won't be able to use it in other playlists and I don't want the column all the time with enabling "show on all"
This is example for just one column so someone can say just enable it on all and use it when needed, but what about many columns:
i.e. I want to use %last_played%, %last_modified%, %play_count% on "*played*" playlists, but not on all playlists while being able to choose those columns as needed
I tried with show only on "*played*; *" but it's not working as I want - it's showed or not showed on all playlists.
Only solution right now is to multiplate columns for every example usage
Columns UI
Reply #5644
For some reason, I can't change colors/fonts when I use this...?
qq
Columns UI
Reply #5645
I am using columns UI, but can't get my album art to show up.  I am a recent convert from Winamp, which made the .jpg file the name of the album, as opposed to folder.jpg.  Is there a way around renaming all the album art to the "folder.jpg" name?  Or should I just wait for columns UI to be updated and this is a known issue that will be fixed?
Columns UI
Reply #5646
enter: $directory_path(%path%)\%album% for front cover in CUI > artwork preferences
Columns UI
Reply #5648
...I would expect that higher ranged filters (precedence set to "by field list") should reset the lower filters, but that isn't the case: If I go to Genres and select "All" - nothing happens, but I need to select some genre and then select "All" if I want to reset filters.
I hope I'm clear: Is this behavior for some purpose or it can be changed?
I understand this behavior: If some items are filtered by some means, then selecting filtered result and changing some upper filter, the results are re-filtered by selected filtered result if it's valid result for new upper filter or reseted if they aren't valid
It confused me because my filters were in tab stack so "all" was always passively selected on tab change and can't be changed directly but with selecting some filter then selecting "all" again
Columns UI
Reply #5649
Is there any way to deselect all files in the NG playlist? It works when i click on empty playlist area, but that's not possible if the 40 or more tracks are on playlist..
I use foo_run to check out wikipedia and stuff for currently playing song, but if some track on playlist is selected, this cannot be done (i get wiki page for selected track).
Disregard the constabulary.
